Question about LG Secret ? KF750 Cellular Phone
Screen is blank.
I cannot get my screen to come on,the phone powersa up but the screen is totally blank.So therefore unless I know the persons phone number I can call out!!!
Purchased in sept 2009 and screen went blank in oct 09.they replaced it and now its doing the same thing
can you still receive calls even when the screen is blank?
I don't think the screen is the problem of your phone, but a flex problem. This blank screen issue is a common problem with slide and flip phones.
This occurs as a result of constant opening and close of flip or slide phones which makes the flex to worn out.
The flex is the one that connects the screen to the phone main board, and once this flex is weak/worn out or loose contact, there won't be any display on the screen.
Therefore check the phone flex and not the screen. Screen doesn't just get spoilt, except it hits the ground or something.
Take care.
Mar 19, 2010 | Motorola Mobility Rival A455 Cell Phone
Both screens totally blank
friend had this problem try pressing the screen down with ur finger (the inside screen)
Jul 17, 2009 | LG VOYAGER VX10000 Cellular Phone
Phone display is very dim-can barely read
Well, first you will have to check your options, if you can read it enough to get in there.  You may have the backlight turned off.  If the backlight is not turned off, then you probably have a bad backlight and will have to take it to your provider to get it fixed.  Replacing a screen/backlight is not something I would attempt to do unless you are certain you know exactly what you are doing as you can render the phone completely useless.
May 28, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Samsung G600 mobile phone blank screen
sgh d880 screen is totally blank & everything is ok widout screen. everything is ok when connected to tv output, the screen is displayed on tv bt it is white on phone plz solve my problem.
Apr 10, 2009 | Samsung SGH-G600 Cellular Phone
The Screen on my phone is blank/white
Dear,
first of all tell me what kind of model u have and the brand of ur phone.
if u have any kind of flip or slide phone then it is because of strip brakage. Totally or partially. If the strip is partially broken then can be repaired if totally or more than repairable then u have to replace the strip and ur cell will be in working position.
do it plz.
dont forget to rate it as it will fix the issue.......
Feb 19, 2009 | Cell Phones
Blank or White screen on new Motorola Krzr k1 cell phone
If the phone still works, check to see if the left side of the hinge (when the phone is open and facing you) is loose. If you can wiggle the top 1/2 of the phone, the hinge is damaged, therefore damaging the flex cable that runs through it. If that is the case, replace the hinge assembly and the flex and you're good.
The K1 is no joke to take apart. Flex replacement requires full disassembly. I would recommend checking out www.wirelessunlimitedinc.com, or www.myspace.com/wirelessunlimited to have it done professionally, less than Motorola will charge you.
Or give it a shot if you want, you need a T5 Torx and lots of patience and care.
Jul 31, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
BLANK SCREEN
well you need to try and have the LCD or flexcable replaced.
Mar 31, 2008 | Motorola Mobility RAZR V3
Audiovox PPC6700 Blank White Screen Plugged In, Black Unplugged
One thing you can do if you have backup all your info is hard reset the phone. If you do not know how to do so please contact me and i will give you instructions.
Mar 18, 2008 | Audiovox PPC 6700
Blank screen
their is a small ribbon wire connecting the screen to the rest of the phone, look on the net for tutes. and find the best one (read many) or let a qualified teck. look at it... good luck.\
Oct 09, 2007 | Samsung SGH-D600 Cellular Phone
LG Secret ? KF750 Cellular Phone Logo
156 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
