Question about LG LRE30755ST Kitchen Range
LG Range LRE30755ST
My front left burner on my cooktop came on by itself and will not shut off. I tried to turn it off and on on the range, and then went to the breaker panel and shut it off that way.When I turned it back on several hours later, it came right back on high.
Does anyone know what would cause this? This is pretty scary. I am just glad I was home at the time this occured. I have looked in the manual and there was no mention of this issue.
  • roberta3fan May 11, 2010
    had you been using it earlier?
SOURCE: Dacor gas range igniter clicking
I have one of these ranges too. This happens to all of them. EXTREMELY annoying. The problem is probably that cleaning fluid/water/materials break the contact between the metal parts. Solution: Take a wire brush and clean the igniter tip. Also brush the removable ring and the flat burner top, as well as the ring below these (the one coming out of the stove top.) You may have to do this several times -- brush every surface near the igniter tip. Then, turn on the burner and let it burn for 10 minutes or so. Sometimes the burner will not light even though the igniter is clicking. Light it with a match and let it burn 10 minutes.
Posted on Oct 05, 2007
SOURCE: LP conversion for Thermador 4 burner range top
I have a Thermadore 6 burner gas cooktop PCG366E purchased January 08. I purchased the LP conversion kit, they only make one kit for all models. The instructions included with the kit were written for an older model and have not been updated by Thermador. The gas regulator is located next to gas inlet pipe. You have to get at it from above. Remove the 2 star burners over that side of the cooktop. You will need a 20mm socket to remove the nut at the center of the star burner. Lift it off and disconnect the wire to the ignitor ( You need to push on the spring lock in order to seperate the the connector terminal). Remove the stainless steel pan and then remove the metal pan underneath ( you will need a Torxs bit for this screw or vise grips). You should now see the regulator. At the top of the regulator is a cap with the letters NG visible. Twist this a 1/4 turn ccw, lift up and turn over to expose the letters LP reinsert. The regulator is now ready. You will need to replace the orifice tips at each burner. Use a 7mm socket with an extension. Put a piece of tape in the socket to hold the orifice in place while you insert it. You also need to adjust the valves. You must pull off the knobs and and remove the trim bezel. If you look through the screw hole on the right you will see a screw head (bypass screw). Insert long skinny flat blade screwdriver through the hole and turn the screw CW all the way (about 1/4 to 1/2 turn in my case). My cooktop had two burners with a low simmer feature, This devise is located in front of the bypass screw. It has a hole in it but does not align well with the head of the bypass screw and makes it difficult to turn the scew. Thats it, I hope this info has been helpful. I have not yet connected the propane therefore have not tested the unit but it should work.
Posted on Feb 27, 2008
Skill Will
  • 53 Answers
SOURCE: rv cooktop range 22 series
hi,
it sounds like the oven safety valve is bad, it will reach a point when the pilot will make enough energy to keep itself lit, but not enough to open the gas valve to light. it will need to be replaced. if you are handy you can do this, but make sure you shut off the gas to the range first. you should be able to find a replacement online, if not check with a local LP gas company that sells parts to the public.
Posted on Mar 22, 2008
SOURCE: Converting Kenmore gas range to LP???
I had success with the conversion. The directions are very cryptic, but it can be done, without the professional emptying your wallet, for 5 minutes worth of work. No adjustments needed on the air shutters, once they are wide open. The orifices are the pain-in-the-a$$es. You need some small tools to get to them, or chance dropping them under the top....which wasn't fun. Oh...and watch which orifice goes where...there are 3 sizes. So, short version, change orifices, open shutters, and flip regulator setting from NG to LG. Orifices take the longest time. ~ sjDIY
Posted on Oct 31, 2008
SOURCE: DCS range igniter won't stop
Hey all ... I just had a repairman fix my DCS cooktop that was doing the same thing ... ignitor problem. He replaced it and it's good as new. (Cleaning also did NOT work for me.) It cost me $216 for the repair. If you can find the part, it's pretty easy to replace. Just take off the front knobs (be careful as there is a 'ring' inside the neck of the knob) and unscrew the front. You will need a special screwdriver - looks like a star - but just snip the plastic straps holding the original ignitor in place and put the new one on the same way as the old one. You should be good as new. REMEMBER TO TURN OFF THE BREAKER!!! I can't imagine it would take more than an hour (tops) 'cause it looked pretty easy.
Posted on Nov 18, 2008
NEED TO REMOVE RANGE TOP. THE LARGEST BURNER NUT HOLDING THE VENTURI IS STUCK. OTHER THREE BURNERS REMOVED OK. DO I HAVE TO SPLIT THE VENTURI NUT TO REMOVE RANGE TOP? I NEED TO GET INSIDE RANGE UNIT.
Yes keep playing with it and BOOOOM! Call in a professional. This is the law with gas appliances.
And turn off the CAPS lock. We heard you the first time :-)
Jan 24, 2016 | DCS "CTD-304-L 30"" Drop - in Cooktop, 4...
Replace burner
it should just plug in at the back wiggle it out
Oct 23, 2013 | LG LRE30755ST Kitchen Range
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
My Maytag kitchen range left front burner does not ignite/clic
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Sep 05, 2010 | Maytag MGS5770 Gas Kitchen Range
LG LRE30453 (Electric) Range Problem is front left burner is shut off but the burner remains hot ... Range won't stop beeping. ...
I have a lg electric dual convection range (Model # lre30757st) and the front left burner turns on and off on its own. (It will not remain off.)
Jul 15, 2010 | LG LRE30453ST (Electric) Stainless Steel...
My left front range has a spark and i didnt even turn it on it just did it by it self
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Mar 30, 2010 | Magic Chef 30 in. 8241RT Gas Cooktop
Presumed bad circuit board on my LG LRE30755ST electric range
You may wish to try removing and re-seting some of the connectors on the back of the control panel...worked for me when our oven and timers stopped working.....
Remove the sheet metal panel at the top of the back of the oven..three phillips screws....then slide the two blue ribbon, wire connectors out, and re-seat them a few times to get a good connection.
Try to un-seat and re-seat some of the others aswell...perhaps un-plug from the wall first....but make sure there is good connections....then re-plug in, and see what happens...
Jan 02, 2010 | LG LRE30755 Electric Kitchen Range
Left front burner will not shut off
Get the Model number of the data plate on the oven so I can help
Jul 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
The two large burners will not turn on, it started with just the inner burner on the dual size (the switch showed it on but it did not heat) now neither front burner switch will turn on
you are going to have to buy a new burner part. if you are able to open the stove top and look closely at the element inside you should notice that somewhere along the lines of teeth, it has broken.
Jun 28, 2009 | LG LRE30755ST Kitchen Range
LG LRE30755ST Kitchen Range Logo
80 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
