ESP7 will not recognize color print cartridge. I have changed the print head and the color cartridge but it still tells me to replace the color cartridge. I can't print or scan.
After changing ink cartridge incoming faxes won't print. Does something have to be reset?
Some machines recognize you changed the ink cartridge and some do not. If you shut it down and restart it, this usually helps it reset.
Feb 28, 2015 | Brother Mfc-j6710dw Multifunction Printer...
Printer will print color test pattern but will not print characters
MY kodak 9200 did the same thing,I resolved the peoblem by removing the ink cartridges,then removed the ink cartridge holder by slightly raising the metal tab on top and pulling the holder forward and up at the same time,then I removed the plastic barrier behind the holder,then re-install the holder in and under the metal tab,let it click twice the second click was where the barrier used to click,this will put more downward pressure on the printer head,mine works just fine now,I threw away the barrier,be careful not to break the metal tab.
Jan 12, 2015 | Kodak ESP7 PP All-In-One Printer
Color not printing
Ensure the cartridge(s) are fully seated and locked down. Replace the color cartridge with a Brother Original cartridge. If the problem went away, your old cartridge is either empty or, the printer does not recognize your recycled cartridge. The only other possibility is a clogged print head. You can try to clear it yourself or, take it to your favorite repair shop.
Aug 25, 2013 | Brother DCP-J140w Compact Color Inkjet...
Kodak esp 7 all-in-one printer. I have just replaced the color ink cartridge. The machine keeps telling me to reinstall the printhead and ink cartridges. I have done this over 5 times. It still will not...
I have had the same issue - only bought my ESP7 last month - have been on the chat support with Kodak in US and they advise that the print head will need replacing but they couldnt send one from US and advised me to ring the 0870 Kodak support number in UK - this is a premium line and lucky I took out an instant replacement policy when I bought it so I am off to PC world to get another! Good luck with yours - suggest you phone Kodak and ask for a print head replacement which should be free if you have had the printer less than 12 months - make sure you have the serial number of the printer with you when you phone. Good luck!
May 21, 2010 | Office Equipment & Supplies
PRINTER (not web camera!) HP Deskjet 712c Printer began printing mostly blackPrinter began printing mostly black & magenta so I replaced the color cartridge. Color did not improve and then black...
First run the CLEAN HEADS and see if that helps. If you don't use your printer at least once a week the Print Heads get dried out and will not allow the ink to pass through to the paper.
Go to control Panel and click on Printess. Then when the window comes up, CLICK on Properties TAB and then in the next window, CLICK on CLEANING.
You may have to replace your PRINT HEAD if that doesn't work.
Hope this is of some help. Bud
Feb 06, 2010 | Computers & Internet
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
Kodak esp-3 cannot purge air from print head
WE HAVE AKODAK ESP-3 ALL IN ONE.
RAN OUT OF BLACK INK. HAVE REPLACED BLACK CARTRIDGE 2 TIMES BUT CANNOT GET BLACK TO PRINT. WHAT SHOULD I DO NEXT???
Apr 23, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Black Ink won't print on my Cannon ip90 Printer
Here's the link to the transcript..
http://www.fixya.com/support/c36778-black_ink_print_cannon_ip90_printer
Please post your comments there if you are not able to reconnect to the session with me..
Mar 20, 2009 | Canon PIXMA iP90 Mobile Printer
Mp370 nnot printing color even after changing ink tank
take out both ink cartridges, lift up head clip and take out printhead block
stand printhead block in a shallow dish of windex overnight, rinse it off, place back in printer, replace ink cartridges
do a clean cycle
Nov 21, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
56 people viewed this question
jasbo
jasbo
