Question about Vacuums
Need help with Hoover S3765-040 WindTunnel Electronic Bagless Canister Vacuum. The belt that rotates the brush keeps slipping off. what to do?
  • 144 Answers
The belt could be stretched and that could be causing the slip. Or you could have the wrong belt if you've replaced it recently
Posted on Sep 04, 2009
Hoover windtunnel t series belt is loose- roller brush doesnt turn. Its brand new belt is slipping. we bough new belts and putthem on same problem. Can not find solutio in manual. Is the belt supposed to...
I also have a loose belt and have bought additional belts but have the same problem. I put the it around the metal rotor and around the brush roller a shown by he Hoover video, and it is loose.
Nov 28, 2010 | Hoover S3765-040 WindTunnel Bagless...
The brush on my hoover windtunnel stopped rotating.We already replaced the belt, and that did not seem to help
Check to see if the brush is frozen up. If you can not rotate it by hand you need to remove it and clean as best you can. Add a bit of WD40 at each end by the pieces that hold it onto the vacuum and turn by hand to be sure it is free. When reassembling, make sure the belt is put on so that the brush turns in the proper direction.
Oct 02, 2010 | Hoover U5753-900 WindTunnel Bagless...
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
My daughter's S3765 bagless canister has good
That means that you need to replace the belt. Here is the belt you need for your model.
Dec 20, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hoover canister vacuum (windtunnel)- turned it on and it had good suction, then smoke came out and it smells like something is burning. Is it the motor burning up or something else?
Probably the belt..
Turn it over so the bottom is facing up..
Remove the plate that surounds the brush..
Check to se if brush is spinning frely and that the belt is on there poroper
Jul 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
The belt keeps on slipping off causing the brushes to stop
Over time the belt stretches and gets to big to stay put all of the time. Get a new Hoover belt and install it. That will solve your problem
Jun 16, 2009 | Hoover S3755 WindTunnel Bagless Canister...
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
Roller Belt Keeps Slipping Off
You could try contacting Hoover for parts availability. If it's and older WindTunnel and Hoover no longer has the part, try eBay.
May 14, 2017 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush on vac
I don't know how old your machine is, but the belt should be changed at least once a year and you should check to make sure the roller spins freely. There are bearings at either end of the roller and they will become contaminated with dirt and hair after a while and will need to be serviced. A new belt will help, but won't last if the roller is in need of service.
Dec 02, 2007 | Hoover U5753-900 WindTunnel Bagless...
Vacuums Logo
105 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
