Question about Dryers
The dryer will not go ON. It was working and I
The dryer will not go ON. It was working and I opened the door while it was ON, now it won't go back on. I check the circuit breaker box, that's all good. Any suggestions!
Whirlpool LG9101XTW0
  • Dryers Master
  • 8,220 Answers
Replace this duct fuse mounted on the blower housing on back. Clean out the dryer and open the vent up.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 03, 2009
Ge repair manuals
The fuse is a we4x800. It is mounted on the heater housing on the back wall of the dryer.
Apr 30, 2013 | GE DCSR483EA Electric Dryer
Won't work. No service code.
the first things to check is the door switch,open the door and push in the switch,if it doesn\'t click when pushed in the switch is bad,next thing to check is the belt,on some models there\'s a switch on the pulley assy. if there isn\'t any tension on the pulley the dryer won\'t start.if you need more help i need the model number off of the dryer,open the door and lolook around the opening where you put the clothes in and you\'ll see a tag with the model number,if the dryer hasn\'t been taken apart and cleaned out the thermal fuse could have popped,if the dryer gets to hot inside from a blocked vent line or the duct that the lint filter slides into is blocked the fuse will pop and it\'s non resetable.
Mar 18, 2013 | Kenmore Dryers
My 2009 Frigidaire dryer door won't open
un plug the dryer for two minutes let it reset , then plug it back up. see if this helps you.
Feb 11, 2013 | Frigidaire Dryers
Admiral heavy duty super capacity dryer won't heat up.
see this causes , fix it. God bless you, use the common sense
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
Maytag Neptune dryer was always drying on high heat, now won't turn on
see this causes and fix it. God bless you
Power From The House
Door Switch
Wiring
Sep 27, 2012 | Maytag Dryers
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
Dryer was in cycle and shut off and will not turn back on. I turned the cycle off and tried to restart and it still will no go on. This is a new dryer, only 3 weeks old.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch this part testing video. On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Aug 27, 2011 | Whirlpool WED4900XW Dryer
Kenmore 80 series dryer won't start.
Aug 21, 2011 | Dryers
Dryers Logo
Top Dryers Experts
