Question about Dishwashers
Has made a growling noise (water) since it has been installed. has to do with water pressure? I installed it, old one made no noise
  • 512 Answers
While filling? If while running, make sure there is nothing in water return area that might be touching the pump blades. Didn't misplace a screw while installing it did you? I have......
If while filling, you can slow the water down by closing the valve to the supply line, only turn it a little at a time so you keep flow as high as possible but below noise causing flow.
Posted on Sep 03, 2009
Dryer is growling when spinning heavy loads.
The bearings may be gone, but I don't know how old your machine is or the brand. If it is over 8 years old, consider replacing it. Maybe get an estimate from a repairman who knows your brand.
Jun 09, 2015 | Dryers
When started, dishwasher making growling (hungry stomach) noise before filling with water
That would be your pump priming, however I would check the sump or filter in the bottom sometimes they get debris caught in them. Some have a filter others have a screen.
Jan 07, 2015 | Dishwashers
What is the growling noise coming from my 94 civic motor
Water pump or pulley most likely.
Always replace water pump and pulleys when you do the timing belt.
Also you may have overtightened the belt.
NOTE, Kevlar belts will make a "whirring" noise for a few thousand miles after replacement, but not a growling.
Dec 29, 2014 | Cars & Trucks
Lg ldf7932ss growling noise at wash cycle
The LG is known for the main motor bearings (2 small cheap) bearings that are of poor quality and become noisy (growls) after a period of time. I pulled the motor and replaced the Korean bearings with quality German equivalents. This is cheap and solves the problem. (the front bearing closest to the plastic pump is the culprit.
Mar 15, 2013 | LG LDF7932ST Builtin Dishwasher
2004 saturn vue engine growls after it is shut off
Could be the a/c pressure equalizing, or pressure in the cooling system.
You may need to open the hood and listen to see where the noise is coming from.
Jun 30, 2012 | 2004 Saturn VUE
Started making lud growling noise
growling noises??? hmmm? well if it starts to bark at you,,, feed it?
this sounds like the old problem,,, its about to pop its socks,,, or drop dead on you,, its clearly an inside job, there is most likely a leek in the capacitor, most comon, realy not worth repearing it, and please dont go getting inside it yourself,,,,you cant fix it,,,but you could easly kill yourself,,, that capacitor holds 1000,s of volts,,, trust me on this!!!!
it could easly kill you in one hit!!! just look at what a stun gun can do??
and thats only a small capacitor, whats inside your microwave is its very big brother! so if its growling at you, its about to go bang!
Oct 21, 2009 | Kenmore Microwave Ovens
Fridgidare affinity washer will not spin, makes a growling noise
use a shop vac and attach it to the end of the drain hose remove all the water then you need to check the drain pump and see if there is anything blocking the pump.
Sep 27, 2009 | Frigidaire Affinity ATF7000E Front Load...
On startup printer growls
Hi Charlie, These machines have a history of growling, however usually they growl before changing the fuser. The fuser is most likely the problem maybe you got a bad one. If you still have the old one and it was quiet you could pop it back in to confirm. Ther is also a gear kit available to replace the fuser drive gears but usually the noise is in the fuser.
Another growling noise can come from optional tray3 if installed. Easy to diagnose just lift machine off the assm. and print.
Hope this helps
Mar 19, 2009 | HP LaserJet 2420dn Printer
Growling noise in high gear
sounds like the air filter/silencer is loose
Nov 06, 2008 | 2002 Mini Cooper
Dishwashers Logo
74 people viewed this question
Top Dishwashers Experts
Owen Barnes
