Question about Craftsman Garden
Craftsman leaf blower will start but has no blowing power
    Problem Solver:
  • 5 Answers
Clean the carburetor and replace the fuel lines - The lines on mine were totally rotted - The larger hose crumbled in my hand - The fuel filter had long since fallen off....
Posted on Feb 24, 2010
Gas blower starts idles then when choke is opened stalls out. Gas bulb stays deflated when you push it down twice
If its started and idling,why are trying to choke it??????
Don't do that just start blowing dude. Good Luck......
Sep 16, 2013 | Craftsman Garden
Leaf blower is hard starting
check your filters clean,,if not that clean carb out
Nov 14, 2012 | Craftsman Garden
For a Sears Garden Blower Model # 257.796330, I need the Sears Vaccum Attachment Model 79988.
per sears's website there is no attachment for this electric blower, www3.sears.com
Nov 17, 2009 | Craftsman Garden
Won't start --has gas--has spark craftsman leaf bower
most likely the air filter is clogged, take it out blow it out or spray water through it and allow it to dry completely.
alterinavely, just pouring a small amount of gas onto the filter should make it work, i would do that even if you do clean it properly.
this method works for cars too!
Nov 07, 2009 | Craftsman 4 Cycle Blower/Vac
I have a Craftsman leaf blower - about 4 years old - that no longer works on high...any ideas?Starts fine, blows on low...just won't switch to high, stalls when I try.
May need carburetor adjusting or you could have some bad fuel mixture. I would try mixing up some fresh mixture, not from your can in the garage, and see if that helps.
Good Day.
Nov 02, 2009 | Garden
32 cc blower not starting
your problem is inside the carburator.there is a small screen inside that needs to be cleaned out.take the single screw from one side of carb.there is a small screen in side.carefully take an air hose and blow it out.do not blow to hard or the screen will blow out.once it's clean the unit will start right up.hope this helped,let me know.................................
Jun 29, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Craftsman leaf blower/vacuum
There is a round grille on the bottom of the unit. Insert a flat blade screwdriver into the latch to release it and reveal the vacuum opening. You should have a two-piece intake pipe that will attach to the opening.
The collection bag attaches to the smaller outlet where the blower pipe used to be (unscrew the wing nut to release the blower pipe). The bag clips onto the hooks at the base of the opening.
Nov 11, 2008 | Craftsman 4 Cycle Blower/Vac
Leaf Blowers Features
* CFM (cubic feet per minute) is the measure of vacuuming power. Ratings fall in the 350 to 600 CFM range. * MPH (miles per hour) measures blowing. Leaf blowers perform at levels from 125 - 210 mph. * Decibels (dB) is the noise rating. * Reduction ratio on mulching blower/vacuums calculates how many units of leaves the mulcher can produce. A 10:1 ratio means that 10 bags of leaves can be reduced to 1 bag of mulch. * Speed settings allow better control when blowing or vacuuming. * Attachments, such as extension tubes for cleaning gutters, are available separately.
Aug 27, 2008 | Craftsman Blower Attachment
Garden Logo
216 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
