Question about Samsung Televison & Video
Samsung tv, when turned on tv cycles on-off again and again, goes on like this, then will stay on, will be fine till turned off.then starts cycle again
  • 76 Answers
SOURCE: After first Ignition cycle igniter stays on too briefly to open gas valve gas.
Valid Most likely the problem with your dryer is the coils for the gas valve. Remove the access door (on the bottom right side on the front panel) and you can see the gas valve with three coils on top of it. They are coming as a kit with complete instruction. The part number for this kit is AP2669614.You can buy it here http://click.linksynergy.com/fs-bin/click?id=SrmyP8LkIos&offerid=92089.542517043&type=10&subid=
Posted on Jan 16, 2007
techman
  • 3130 Answers
SOURCE: tv cycles on and off
Sounds like bad capacitors in nthe power supply, or maybe a regulator in the power supply. Have a tech take a look at this TV set for you, as there are no user replacable parts available in the TV set. Good Luck
Posted on Jun 09, 2007
localwonder
  • 6784 Answers
SOURCE: dishwasher wont go through the cycles
Hi. this will occur when the timer control or control board has experienced a major fault within the circuitry. in most cases, the actual timer mechanism will fail. this will stop the forward advancement of the wash cycle.
Total replacement of the timer control module or control board will fix this issue.
Posted on Jul 19, 2009
SOURCE: Samsung HL-S5679 turns on and off
I had the same issue about a year ago and they replaced the power supply on the unit. Just started doing the same thing again now on my end as well. 1 more repair after this and I can lemon law it on the warranty that I took out on it.
Posted on Nov 02, 2009
  • 927 Answers
SOURCE: tv doesn`t start
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts. The board on left, you will see the cap tops are swollen.
Thanks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
TV Samsung WS-32Z308P (Slim-Fit CRT). Chassi S62A. TV keeps turning on and off in a 15 min cycle.
mine had 6 bad capasitors on which i replaced for 3.99 and been fine since.heres where i got my guide from.hope it helps...
ELECTRONIC EQUIPMENT REPAIR CENTRE
samsung smart tv fix YouTube
Dec 03, 2013 | Samsung WS32Z308P 32" TV
Keeps cycling through channels
Check and replace its main system control memory IC. It sounds that it is faulty.
Nov 20, 2013 | Samsung TXN2020 20" TV
Hi my samsung crt tv come up on start up but couldn't stay for more than few seconds before it goes standby. I've tried to check settings but could not even get anywhere before it goes back to standby
Whenever a television starts doing this the motherboard/main board and or power supply is usually at fault. The power supply can usually be rebuilt for around $150 depending upon the knowledge and skill of your local television repair shop. To replace the parts is usally more expensive then it would be to purchase another television ($300 and up). Are you sure this is the model number of your television because this model number is not for a CRT television. For troubleshooting you can unplug it overnight to try and power cycle it but it sounds like your problem is beyond doing any type of power cycle to get the television back going again. It would need the repair shop or to be discarded for another.
Oct 29, 2011 | Samsung LNT3242H Television
It takes about 5 mintes for my tv to actually turn on. I push the power button and it starts to cycle on and off. Sometimes i get purple spots on the tv when it finally turns on. If I turn it off then on...
hello,
Cycling turn on off mostly from capacitors on PCB power board. Read my tips for cycling power on here. For Purple spot i think because capacitor efect i hope.
Good luck.
Apr 19, 2011 | Samsung LN52A580 52 in. HD-Ready LCD TV
Tines turning, mantis 2 cycle tiller
sounds like a piston seizure. are you using correct oil and ratio. carb could be going lean and causing the cylinder to over heat, adjust high speed mixing screw and hope no damage has resulted.
Jun 30, 2010 | Mantis 2-Cycle Tiller
Samsung tv power cycles when I get to higher channels pass 40. I attempt to change channel. Doesn't change and then front led blinks, tv screens goes blank, led flashes again and then screen is normal. I'm...
We have a similar problem when changing channels/surfing, the TV will begin to power cycle, until you unplug THE CABLE TV input, then it will turn on again and stay on as you rehook the cable and change channels....till it decides to do it again, DTV channels seem to trip it up, but not sure....if I leave it on the same channel it will run for days. Yep and the cable TV is grounded outside
Dec 19, 2009 | Samsung LN40A630 40 in. LCD TV
Oct 21, 2009 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
348 people viewed this question
Henry  Thomas
Henry Thomas
