Hotpoint Aquarius+ WD645
Hi There,
I was wondering if you know why my washer/dry has stopped drying?
The wash cycle seems fine and the drum rotates etc in the drying cycle but clothes don't dry as its not getting hot?
Is the dryer heater seperately fused? Where would I find it? I can't seem to see it anywhere obvious.
Thanks For your help.
Regards,
Andrew.
  • 2SpottyDogs Apr 21, 2008
    Our WD645 dryer has stopped getting hot. we have replaced the thermostat and the dryer element and it's still not getting hot. we've been told it could be a wiring problem.
  • 76 Answers
Yes, you will need a test meter. unplug machine, remove to, in the middle on top you will see a heater, you will need to test this. there is also a fusable link, that is incorprated in one of the wires that go to the heater. you will also find to thermostats linked through the wiring, one of these may have a reset button on it.
Posted on Dec 07, 2007
My Hotpoint Aquarius WD420 does not wash properly. It doesn't seem to take in any hot water and the drum does not turn, it just sways from side to side and does not move on from wash to rinse and spin....
For those problems, you have multiple issues and need a service engineer. It may be just the hot water intake solenoid, but may also be a problem with the logic board or both.
Nov 13, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
My hotpoint aqaurius WD420 is not drying.
Could be stat or heater .Remove the top cover, and you will see the heater manifold on the right side of washer drum.
The element and stat/s are located on the top of the manifold box.
You willneed a meter to test with, also check for broken wires.
Feb 05, 2010 | Hotpoint Aquarius WD640 Front Load...
Dryer does not work drum rotates but does not dry on hotpoint aquarius washer dryer model wd64. all other functions operate ok
Probably open circuit heater element, or thermostat/s
Remove top cover, and you will see the heater manifold on the top of the drum.
It is a long aluminium box.
The element and stats are located here..
You will need a meter to test the appropiate components for continuity.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Wd645 has no power to on/off switch. changed plug
Could be mains choke. Mains power comes into mahine via wall socket /worth checking this then onto mains filter/Choke..then to switch..So if no power here check this..wish you well
Oct 07, 2009 | Hotpoint Aquarius WD640 Front Load...
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
No heat
Check on the back of the drum for a thermal fuse or relay. Common fault on tubledryers is no power to heating coils becuse of blown fuse or most likely the relay to heating coils is dirty. have to be cleaned about every 2/3 years depending on use.
Aug 09, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Tumble dryer isn't woking
You may need to replace the thermostat or the heating element.
Apr 13, 2009 | Hotpoint -Ariston Aquarius WD645 Front...
Dryer not drying clothes
If you remove the lid you will see the element on top of the drum.
There are a couple of thermal cutouts mounted on it which would be the first thing to check.
Also look for the obvious broken wires etc.
Also can you hear the fan running when machine is in operation?
Hope this helps & thankyou for using Fixya.
Feb 20, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
Drying cycle runs but does not dry clothes
more than likely that your thermostats have blown if you could smell the heater element getting hot then this will be the case m8
Nov 23, 2006 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
146 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
