Each time I send a document to print I get a fatal error code 070. What is that error code?
  • editor205 Sep 03, 2009
    It is not a computer error, it is a printer error message on an xante ilumina. Sorry I forgot to tell you that part.
    OSX 10.4.11
    It was working fine a couple hours ago. We've had no power outages or spikes. Wierd.
    President:
  • 2,777 Answers
Could mean various things, what operating system are you running?
Let me know and I will help you out here.
Thanks
Tim
Posted on Sep 03, 2009
  • Tim Grayson
    Tim Grayson Sep 03, 2009
    That is strange. Have you tried turning off the printer, then unplugging it from the wall / power outlet. While it's off and unplugged restart your computer. After your computer has come back up completely (and the printers been off for at least 2 minutes) go ahead and plug the power back in.
    Then try sending a document it's way =).
    Let me know what you find, thanks!
    Tim
Error: printer error. turn off then on again. for details, see your documentation.
Hi I have a similar problem with Epson px660, it does not complete the self test after powering on then it flashes all lights with a printer error of fatal code 0x71, can you assist me kindly.
Best regards
Mar 13, 2015 | Office Equipment & Supplies
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
What is a Fatal Error: 140 on a Xante HSE?
That error is image yellow drum up/down senser. Shut down your printer and reseat the drum make sure it is loose and not tight when placing it into the unit.
Oct 02, 2014 | Xante CL30 HSE Laser Printer
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
Fatal error when installing HP Officejet 8500, fails at 96%
hi did you get any particular error during the installation that said fatal error 1935 or 1709 or some other message if you get any error message please mention the specific error code and try the step mentioned below
insert the cd in to the computer and then go to computers and right click on the cd icon and open it now you will see a Util folder open it and then open CCC and in CCC you will se some files like uninstall_L2, Uninstall_L3, Uninstall_L4
if you have a HP computer then open uninstall_L3 and continue to clean the printer entries If you do not have a HP computer then open UNINSTALL_L4 and continue
after cleanup restart the computer and then go to c drive >>Program files >>HP and delete the digital imaging folder
now install the printer software once again if you still get a fatal error at 96% then do not click on the ok button of the error screen directly restart the computer and when it restarts go and try to print in will print fine
and still if you have any problem then you can call the HP helpline for free support that is 18004746836 24hrs support
Sep 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Deskjet F2280 - It scans but doesn't print. Shows fatal error.
Hi Amnasaeed
Follow this document, even I was facing the same problem and this document has taken care of my issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01430567&cc=us&lc=en&dlc=en&product=3390947
follow the document and get back to me if the problem is still not fixed.
Thanks & Regards
Santhosh
Jan 27, 2009 | HP DeskJet F380 All-In-One Printer
Canon clc 1150
9 times out of ten that means you need a new drum when it does print does it look ok?? if yes then its definatly the drum it measures the voltage on the drum when its worn this code happens sorry
Jan 16, 2009 | Canon CLC 1150 Color Copier
Need list of Fax result codes for Canon MF5550
NG 070 = Issue: ERROR LCD: CLEAR ADF, DOCUMENT TOO LONG
Solution: Reduce the length of the document
Reduce the length of the document to within 14" (356 mm).
Sep 03, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Fatal error 17H
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing rack rotation
<Remedy>
Electrical components for detection of the malfunction
Rack motor (M2)
Rack clutch (CL1)
Rack home position sensor (PC4)
Master board (PWB-A)
Controller control board (PWB-P)
Rather than try to explain in more detail i can forward you the service manual (4.17mb) if you update with an e mail address
Jun 05, 2008 | Konica Minolta magicolor 2300DL Laser...
Oki Data Series 5000
This is a PS Can't Happen Failure and occurs when an error has been detected in the PostScript core.
If an address is displayed on the LCD, note it down for future reference.
Restart the printer and it should be cleared.
Oct 11, 2007 | OKI C5400tn Laser Printer
15 people viewed this question
k24674
