Question about Brother MFC 6490CW InkJet Printer
Will copy but get paper jam every time I try to print
Even using the same tray 1 or 2, it will copy ok but I get a paper jam every time I print......??
Anyone else get this or know a fix
Malc
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
Samsung scx-4521f "paer jam 2"_ i've checked paper inside but i can't see any thing is jammed. if i turn off and on that time 1 paper will be printer ofter one same problem is repete. any advice sir
Sanjay,
I think you should take all unused papers out, close tray and predd print button. If there is paper in the system, it may come out. A red light may also flash asking you to load papers. Now lod the papers and the red light will go off. Put a printed paper and try copying. If it copies, you are ok. Now print from your cpmputer command. If it prints you are ok. If it does not and you get paper jam warning, there may be a small piece of paper stuck in the system. You have to open each feeder and see if you find anything. Good luck.
Jun 02, 2014 | Samsung SCX 4521F All-In-One Laser Printer
My HP4100 keeps jamming under the toner cartridge. I have a repairman look at it 2 times and he cannot figure it out. Does anyone know what would be causing the jam. It seems to happen mostly on short...
1) Check all the paper jam locations (see "Clearing paper jams" in your printer manual). A piece of paper might be stuck somewhere in the printer. Even a small torn piece of paper in the printer path can cause repeated jams.
2) If you are using a duplexer, check all the areas (including under the duplexer).
3) Check that the paper is correctly loaded in the tray - that all paper tray adjustments have been made, and that the trays are not overfilled. Make sure the paper is under the front and back tabs. (See the section on "loading paper" from your printer manual.)
4) Check that all trays and paper handling accessories are completely
inserted into the printer. (If a tray is opened during a print job, this might cause a paper jam.)
5) Check that all covers and doors are closed. (If a cover or door is opened during a print job, this might cause a paper jam.)
6) Try printing to a different output bin or tray
7) The sheets might be sticking together. Try bending the stack to separate each sheet.
8) If you are printing from tray 1, try reducing the size of the stack.
If printing from the envelope feeder, make sure it is loaded correctly,
9) If you are printing small sizes, feed paper short edge first (see
the "Guidelines for printing custom-size paper" in your printer manual).
10) Turn over the stack of paper in the tray. Also try rotating the paper 180 degrees.
11) Check the characteristics of the media you are using. Use only paper that meets HP specifications (see the "Paper Specifications" in your user manual).
12) Try using different paper to see if the problem goes away. Do not use curled, deformed, damaged, or irregular paper.
13) Check that the environmental conditions for the printer are met (see the "Environmental Specifications" in your printer's user guide).
14) Avoid using paper that has already been used in a printer or copier.
15) Check that the power supplied to the printer is steady and meets printer specifications (refer to the "Electrical Specifications" in your printer's users guide).
16) Clean the printer and rollers (refer to the "Cleaning the Printer" section of your printer's user's guide).
17) Perform preventative printer maintenance if maintenance is due (refer to the "Performing Preventative Maintenance" section of your printer's user's guide).
Nov 21, 2013 | Office Equipment & Supplies
Will only print 1 copy then says paper jam, but I think it is not picking up the next sheet of paper. I have taken the paper out fanned it and replaced it only to have the unit make 1 copy and display...
Clean the paper feed tire. If it is not picking up the paper this is the most common cause.
Just remove the paper tray completely from the machine. Now look into the port where the tray was. The tire is in the center from left to right and on the top side right at the front edge where the tray goes in. Just use a cloth and some glass cleaner or even dampened with water as we are just trying to remove any paper dust/dirt buildup on the roller. Just clean the part you can see then rotate the tire around to clean the rest. I think on this model the tire will only rotate 1 direction.
Once clean just re-install the tray and test.
Good Luck and thank you for using Fixya.
Aug 05, 2010 | Brother MFC 7420 All-In-One Laser Printer
Copier jamming/copy printing sideways
If it jams every copy then it sounds like the paper tray size is not programmed properly. This is also why the print is the wrong direction on the page. So the copier thinks it has 8.5X11 loaded like this > -- and instead it is loaded like this > |
I hope that makes sense. So this not only causes the print to be the wrong direction but since the paper dimension are different that what the machine expects then it throws the sensor timing off and results in a paper jam. So just open your paper trays and check the paper size dials in the trays to make sure they match the paper size AND direction of the paper loaded into that tray.
Good Luck and Thank You for using Fixya.
May 13, 2010 | Canon imageRUNNER 2200
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
I can only print by manually feeding in each page -HP 4MV Printer
Good old 4MV.
paper jam is just the way the printer i stelling you "something" wrong with paper feed".
you need to locate a "4MV repair kit" , they are not cheap. but, if you wan to keep the printer, it is worth it.
http://www.fixyourownprinter.com/kits/hp/K78 cost of the ket is $50
includes Instruction CD rollers, and other repairable parts.
Dec 15, 2008 | HP LaserJet 4mv Printer
Printing crooked from one drawer, and no option to print from another drawer
Try this spray on a little WD40 on the GLASS and wipe it off.
Yes, you heard me correctly, make sure you wipe it off leaving no residue, but it's still slippery.
the problem may be coming from the glass being too dry and the paper is getting stuckand shifting.
If the paper itself was going crooked it would get jammed or ripped. There is no room for the paper to go through the path crooked so the only way for it to copy crooked is somewhere in the optics.
try doing 1-2 on the glass itself and see if it copies crooked.
The envelope tray is a By-pass tray and can be used for any size paper.You can switch which tray it copies from on the panel tray button.
Aug 28, 2008 | Canon imageRUNNER 2200
Brother MFC 6490CW InkJet Printer Logo
249 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
