Question about Maytag Washing Machines
Their is an oil leak onto the floor under our washer. What is this and how can it be fixed?
  • 30 Answers
You will need to replace the transmission to fix the oil leak.
Really not worth the repair tho.
Posted on Sep 03, 2009
Oil leak under 1997 Pontiac sunfire convertible engine needs work
Most likely you oil leak is coming from your main seal . They wear out and get hard and brittle you could also have valve gaskets leaking and the oil is running down the engine and onto the floor.
Apr 20, 2014 | Cars & Trucks
Leaky rear main seal
I bought a 2000 RL used, with some factory warranty remaining, and then bought an extended warranty. While hnder warranty, car began to smell up my garage from fumes from oil dripping onto hot exhaust. Not enough oil at that point to show up on garage floor. Complained to dealer about the odor but Acura Master Mechanic (said he) couldn't find source of odor (although I told him I suspected an oil leak because I had prior experience with oil leaks and resultant smells on another car). On the next service visit after the extended warranty expired, same master mechanic said my RL's rear main oil seal was leaking onto exhaust causing odor. And the dealer wanted north of $1000 to fix it. I declined. Leak has steadily gotten worse - now visible drops on garage floor. An independent repair shop quoted $650 plus the cost of replacing expensive, special Honda transmission fluid. Took my complaint all the way up the chain to the head of Honda in Japan, but got no assistance. No more Honda products for me.
Apr 05, 2014 | 2000 Acura 3.5RL
Leaking on front driver carpet but no visual sign of leaking around door or windows. Carpet is drenched and so is cushion underneath carpet.
1. Have you been using your heater and is the smell sticky sweet? If so you're heater core might be leaking.
2. Have you been using you're A/C? If so you may have a clogged or disconnected condensation drain.
Jan 17, 2011 | 2001 Lexus RX 300
Oil leak onto garage floor either coming from oil pan gasket or oil filter not sure wich one
Clean the filter and pan with a spray cleaner, run engine for a few miutes.
recheck oil leak.
Probably is rear main seal leaking, very common trouble.
If not leaking much, keep drip pan under car to keep floor clean and drive on.
Most cars do leak after they age a little. The black line in the middle of the road is oil leaking from cars. Very common.
Sep 28, 2010 | Honda Passport Cars & Trucks
My Whirlpool washer is leaking oil out of the bottom and onto the floor. Model# LHA5500WI. How can I fix this problem? It has a 1/2 hp motor, 1725 rpm, 1440 rpm, rubber mounted.
The leak would be from the gear box. The seals on the gearbox are worn out.
Best to get technician to remove gearbox, and have it reconditioned.
Regards
Ash
Oct 21, 2009 | Whirlpool Washing Machines
Machine is usually very noisy ( like it was out of balance, but isnt) 90 percent time very noisy in the final expell of water, also some oil on the floor under center of machine ? this is a top load...
oil on the floor means your gear box is leaking
if it has been leaking. if it has been leaking for a while, it may have done major damage,and would be cheeper to replace the machine second hand than to fix.
if noise is happening while you are pumping , it may have a bra under wire or small coin in the water pump.
if it is sounding like it is out of balance it may have a support or spring broken or unhooked
as the tub is usually suspended by springs
May 05, 2009 | Maytag MAT12CSD Top-Load Coin Operated...
Tub leaks water during cycle out bottom onto floor
We had the same problem. There was a pinhole leak in the hose that connects the tub to the pump. Bought a new hose for under $10 and fixed the problem ourselves.
Feb 26, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Transmission noise
Washers normally don't have much grease in them at all....the transmission is full of oil....which on GE washers often gets dumped onto the floor.Remove power, tilt the washer back and check on/around/near the large center pulley under the tranny....often the belt and pulley throw the oil around inside the cabinet.
Some of the oils they use are a synthetic oil....acts a little diff than some other oils....sometimes if water gets into the tranny the oil can change foamy or black due to the moisture.
Feb 10, 2009 | GE WHRE5260E Top Load Washer
Water leaking onto floor from under washing machine
first off check for punctures in hoses,
a leaking pump (common issue, youll see water dripping from pump area)
search you tube for whirpool washer repair, for simple instruction for removing hte outer cabinet
Jan 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Oil leak from bottom of maytag neptune tl - about 4 years old
sounds like seal leak in tub water is leaking onto drive unit and washing over it bring and oil it can with it couls be big bucks some parts may be under warranty call service but be sure to get estimate first
Nov 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
113 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
