Question about KitchenAid 32685 Mixer
KITCHENAID MIXER I TOOK OUT THE PIN GUARD AND I STILL HAD IT PLUG IN, IT SPARK I NOW CAN'T GET IT TO WORK. HOPE YOU CAN HELP. THANKYOU
  • COYNE 2006 Dec 08, 2007
    it won't power up
  • 4,889 Answers
Cant get it to work means.. It wont power up or ..it will power up and the blades dont run?
Posted on Dec 08, 2007
  • eagle338
    eagle338 Dec 08, 2007
    Well this can be due to a bad motor or bad power supply.. switch off the power supply, open your mixer and see if you can find any burnt or disconnected wires.. IF you find any just fix it.. otherwise you will have to check if the motor is working.. first check the power supply so that we can proceed further..
  • eagle338
    If you want to make it easier you may have to check using a multimeter..
  • 456 Answers
I think that the power supply wire is damaged check it out then tell me.
Kitchenaid Mixer Planetary becomes sluggish when met with resistance.
The problem will be with the worm gear, if the gear is not stripped then check that the locating pin for the worm gear is not broken or missing. Occasionally the plastic gear can detach from the aluminium boss between plastic and shaft. The worm gear is the 99.9% place where drive can slip. Afterthought, I suppose the planetary pin is not missing or broken??
Jun 28, 2013 | KitchenAid KSM150PS Artisan Series Stand...
How do you get the planitary pin out of a kitchenaid mixer?
What model is your mixer? How old is your mixer? I hate this problem most of all and it is at the beginning of every mixer fix. in the worst situations I have had to drill it out and replace the planetary and center shaft, I have used a torch which is a good solution except that it trashes the finish, the easiest way is to use a drift punch that will go all the way through the center shaft and a non metallic hammer, turn the mixer on it's side on some towels, find something to put under the mixer to support it so that you do not break the locking handle or the speed switch handle. the n as straight as you can start tapping the pin. I have found some pins actually broken inside and took forever to get out, some bent from being driven in too hard, some have the ends banged out of shape creating a lip that will not drive through the shaft, i usually start with any punch that is smaller than the pin shaft opening to get started, then when the pin is driven in enough to get the drift punch in without hitting the out side finish of the planetary i drive the pin out and yet it may require a good tap especially if the pin is bent inside, try both ends before you try getting brutal with it. one end may go smoother than the other especially if a lip has been created on one end and not the other. I hope this helps. let us know.
Feb 21, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Please help
I just took a look at my wife's... all you do is line up the pin and the slot in the attachment. Then push the attachment up over the pin and give it a twist... this will hold it on....just that easy!!
heatman101
Jul 25, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid Heavy Duty 325 stand mixer. Making cookies and now the motor runs but it doesn't turn to mix. PLease help/.
kITCHEN AID ARTISAN 325 WATTS TILTING HEAD PIN CAME OF WHILE MIXING DOUGH. HOW IS THE EASIEST WAY TO INERT PIN BACK OR LINE UP THE HOLES TO INSERT PIN?.
FRANKAMOR
Feb 06, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
DONT WORK
Hi. Before you get too far, call kitchenaid parts to find out if they still have parts for your mixer. They no longer show a parts list for the KSM90 so your mixer may end up in the trash.
Go to mendingshed.com and select the Kitchenaid products button then select Kitchenaid mixer parts. Near the top of the page locate the button for the free kitchenaid service manual. Download the manual and read about the disassembly and reassembly of your mixer.
This manual does not cover your mixer but is a usefull tool for working on any mixer. Good luck with it.
If this solution has assisted you, please rate it. ricardok45
Apr 18, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid Artisan Stand Mixer missing plug/where is outlet?
I can only imagine you have a shop display machine and they took the plug off. Otherwise it should be obvious.
Mar 22, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Power On Problem
Check to see if the contact points on the control board are working. Adjust the screws at the top of the control board until the contacts make contact. That should fix your problem.
Feb 13, 2009 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid stopped working Modle KSM150PSER
Hi Phyllis. Unplug the mixer, lay it down on one side and look for the pin that holds the planetary shaft in place next to (where you attach beater). The pin may have worked itself loose. If this pin is not all the way through it's opening, the shaft will not turn the planetary unit. Hopefully the pin did not come all the way out and you can tap it back in. If the pin is gone, It's in one of your cookies and hopfully you'll find it before anybody else does. Hope this helps. Ricardok45.
Dec 17, 2008 | KitchenAid KSM150PS Artisan Series Stand...
I have just purchased a kitchenaid ksm150psob from america and have changed the plug and sparks came out of the back.HELP!!!
You probably have a different voltage than the US. Now the control board is shot, and needs to be replaced. Kitchenaid does not recommend a step-down transformer due to the difference in freqeuncy (50 vs 60Hz).
Sep 30, 2008 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid 32685 Mixer Logo
196 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
