Question about Indesit W 123 Front Load Washer
Machine wont fill with water.i have checked pipes and they are okay.if you turn program knob to the spin cycle it will try to enpty.also you can still open the door
    Scholar:
  • 123 Answers
Hi there....looking at the programe selector knob....you should see at three positions on the panel a black dot.....ok.......(1) close the door of the machine and switch on the power....(2) turn the programe knob to any one of the dot positions....(2) push the start button....a red indicator lamp should flash 3times and then remain steady indicating the program has been cancelled....(3) Now select a new wash program and push the start button....machine should operate ok....If not check the drain pump to ensure it is not blocked...or wiring loose ...or burned out....if this is ok...then your most likley looking at a module failure...
regards Sir Galahad
Posted on Sep 03, 2009
  • Jim Gallagher Sep 03, 2009
    regards Sir Galahad
Hoover 500mb washing machine failing to spin.
my does everything but it just wont spin drye
Mar 25, 2012 | Hoover HTC243 Top Load Washer
Only spin cycle works
hi, john have you checked the pump if ok the fault could be programmer i have repaired these the fault being dry joint on programmer circuit board
regards
shaun
Nov 10, 2011 | Washing Machines
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
My GE washer will not run a full cycle. It fills up non stop, while at the same time its draining. It was running the cycle and would get stuck on the rinse/spin cycle. But now the knob doesn't even move...
One very slim chance is that the waste water hose does not have an air break in it
The pipe is supposed to be placed into a drain which allows a flow of air to the pipe out of which the water is being pumped
If there is not an air break then the mchine can set up a syphon action which will not allow the unit to fill to the right levels
Quick check is to dump the oulet hose into a sink and run the machine , be sure to secure the pipe in case it slips out and also that the sink can empty fast enough for the water being pumped into it by the washer .
If you are saying that the machine wont stop filling try turning the water off at the fawcet
Jul 05, 2009 | GE Washing Machines
Cycle will not advance
ok turn off unit at power switch, turn knob to drain and spin, and turn back on that will reset its programming and force it to do the drain and spin cycle also check the drainage hose to ensure it's not kinked or clogged. If it's clear and in good shape
Jun 29, 2009 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Indesit W 123 Front Load Washer Logo
158 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
