Question about Insignia Digital-to-Analog Converter for Analog TVs
I need the code
I have a insignia converter box but i got a universal gamer remote how do i program it i tried all the code in the book
Bubbabear64
  • 2794 Answers
SOURCE: INSIGNIA NS-DX-A1-APT remote won't work to install converter box
Sounds like the remote sensors aren't working. Since you purchased them at Best Buy, Geek Squad should be able to test them for you at no charge.
The conversion date has been moved to the middle of June now by the government a few weeks ago. You have some more time to get them working.
Posted on Feb 18, 2009
SOURCE: Programming Insignia Digital Box to Phillips Universal Remote
I have the Phillips Universal Remote (model#SRU4208WM) and I have the Insignia digital converter box (model#NS-DXA1-APT). The code was 0267. The Insignia converter box is the one the government grants work for.
Posted on May 03, 2009
SOURCE: looking for code to run Insignia digital converter box
According the Insignia DTV Converter Box instructions (pg. 3), you can use the manufacture codes for LG or Zenith to program your remote control (http://www.ezdigitaltv.com/Insignia_NS-DXA1-APT.html)
Find the appropriate codes for your universal remote control on the following websites, and follow the manufacturer’s programming instructions:
Toshiba CT-90037: http://remotes.com/remotes/documents/Toshiba/CT-90037.pdf
Sony RM-V301: http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMV301&LOC=3
Magnavox/Philips: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SRU5108/27&scy=US&slg=en
Sony: http://esupport.sony.com/perl/select-system.pl?PRODTYPE=32&DIRECTOR=RCODES
Or go to one of these sites that provide codes to several manufacturers.
http://www.tvcodes.com/
http://www.xdiv.com/remotes/
http://www.remotecentral.com/features/remotes.htm
http://www.remote-codes.com/
I hope this helps!
Posted on May 17, 2009
  • 3 Answers
SOURCE: problems with insignia remote control on converter box
Well, try it two different ways, as follows: But be sure that the tv-channel that's selected for tuning will be identical to the "output-channel" which you'll then select for the Insignia converter-box. So, if you first select Channel 3 for tuning the tv set, then you must later select Channel 3 on the "Output Channel" choice for the Insignia "set-up" menu. Similarly, if you first select Channel 4 for tuning the tv set, then you must later select Channel 4 on the "Output Channel" choice for the Insignia "set-up" menu. Be consistent! If you find that the Insignia menu-screen does not subsequently appear after tuning the tv to Channel 3, then start-over with Channel 4 as your proper tv-tuned station to initiate the pop-up screen for the Insignia menu. Now, here's an example that assumes Channel 3 is the proper tuning-station for your tv-set within your particular region: You will first tune your tv-set itself (by means of its handheld tv-remote) to Channel 3. Be sure, however that your Insignia converter-box is turned-on and properly connected to your tv-set and antenna. On your tv's hand-held remote-controller, you should find a button that serves as its "input selector" -- with a typical descriptor such as "Input" or "Line" or "Video/Antenna." Press that button, and enter successive channel numbers until you get to Channel 3. You may need to press the digits 03 to signify Channel 3. The tv-screen may be colored bright blue at that point. Then, as you switch to holding your Insignia remote-controller, press the "Menu" button. (Please note that you will need to press hard and firm upon the buttons of the Insignia hand-held in order to get proper responsiveness; a quick touch of the button will not be effective.) After pressing the "Menu" button, the Insignia menu should now appear on the tv-screen. Now, you need to use your Insignia hand-held remote-controller (not the tv hand-held remote-controller again) to travel through the menu-screen to the "Setup" feature. Then, select "Output Channel." Proceed to select Channel 3 -- which will then be printed for you next to the Output Channel feature. Finally, under the same Setup menu, go to "Auto Tuning" -- which will commence a complete scan of all available channels. Remember, if tuning by Channel 3 is inappropriate for tv-tuning within your particular geographic region, then repeat the above process by substituting Channel 4. When you are done, you will rely almost exclusively upon the Insignia hand-held remote controller. You do not especially need to use your tv hand-held remote-controller again. However, be sure to avoid standing in front of your tv-set to change channels by buttons or knobs upon the tv-set itself. Tuning again upon the tv-set itself will negate your prior tv-setting for either Channel 3 or Channel 4 -- and thereby sabotage your working set-up! I myself incurred chronic anxiety yesterday (June 13), as I was stunned that the Insignia menu-screen did not appear immediately when I pushed "menu" on the Insignia hand-held. The only buttons that worked on the Insignia handheld remote-controller were the Power-on for the converter-box and the Power-on for the tv-set. (continued next page) Because my expectation had been this process would take just a few minutes, I was deeply frustrated and impatient. However, I recognized that my apprehension of impending loss was absolutely appropriate as emotional "signal-processing" for me personally -- in contrast to my formerly high expectation of immediate fulfillment, completion, and gratification. Instead of my intention for quick success, I faced the stunning dread that the Insignia box had become defective or that I'd fail to ever figure-out the problem. I would not have been so impatient if I hadn't expected immediate success for the set-up. I rejected the slogan that "I just want to get this over with!" I rejected the option of stomping upon the Insignia box! Amidst my hour-long anxiety, I summoned "Courage" -- a mode of patience to accompany my internal "quivering." I did a Google search. From this Fix-Ya web-site and other troubleshooting sites, I had strong clues that improperly setting Channel 3 or Channel 4 was a primary culprit for the failure of the Insignia's menu-screen to appear. When I finally succeeded, my anxiety dissipated quickly with a temporary relief. But then came the anger that the Insignia "User Guide" had not been clear to explain the process. From that aftermath of outrage, I decided to promptly compose this protocol to assist others who have been similarly tormented -- perhaps to the extent of incorrectly believing that the Insignia converter-box was a defective product requiring prompt replacement.
Posted on Jun 14, 2009
dauerc
SOURCE: Spare remote control for insignia converter box?
Look on eBay, there are people selling spare remotes, have her pick one up now, because if she waits, they will probably not be available. So far, there are no universals that I know of that work with these, in the future it is possible.
Posted on Jun 16, 2009
Insignia Converter Box - need remote
You may have to order one from Insignia. Converter boxes tend to use unique codes so universal remotes don't work
Jan 20, 2013 | Insignia Televison & Video
I own an Insignia flat screen tv, NS-LCD27, & I was given the Insignia converter box, NS-DXA1; how do I program tv remote for the box? Thanks, frances b.
The digital to analog converters did not exist when the TV was built and the remote programmed. Thus you will have more luck programming the converter box's remote to control the TV. (At least with my converter box, the included remote could only turn on and off the TV. It would only change channels on the converter.)
Most universal remotes only have codes for devices released 6 months or more before the TV was programmed. So a new universal remote will probably control both the TV and the converter box. (Program the converter box using a code for LG or Zenith set top boxes if Insignia isn't listed. LG makes Insignia video products for Best Buy.) The remotes that are programmable by a USB connection to a computer are the fastest to set up.
A replacement remote for your TV is available here: http://www.mcmelectronics.com/partfinder.aspx?brand=&mdl=NS-LCD27&mode=part . An exact replacement remote for the converter box can be purchased at: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13055197980390&smodel=NSDXA1&brand_pn=INSIGNIA_NSDXA1 . The manual for the converter box (as a PDF) is here: http://cbsdallas.files.wordpress.com/2011/01/insignia-ns-dxa1-manual.pdf .
I hope this helps.
May 16, 2011 | Insignia Televison & Video
I need to program a universal remote, a ge modal249 my Insignia modal NS-DXA1-APT digital analog converter chgang4895@yahoo.com
Since Insignia and LG share compatible codes for digital-to-analog converters, review your remote control's manual for LG VCR codes as they should work to control our converter.
Apr 19, 2010 | Insignia Digital-to-Analog Converter for...
Universal remote - program digital converter box and Roku?
if you still have your remotes you can program the buttons for each funtion.
1. Hold down P until the red light blinks
twice.
2. Press 9 7 5. The red light blinks twice.
3. Press the device key that corresponds with
the desired device's remote (TV, CBL/SAT,
DVD, VCR or AUD).
4. Press the desired learning key. The red light blinks rapidly.
5. Place the device's remote control head-to-head
(about 2 inches apart) with the
11
Gamer Remote.
6. On the device's remote control, hold down the key to be learned until the red light on the Gamer Remote blinks twice. If the red light does not blink twice, repeat Steps 1- 5.
7. To lock in learned functions on the Gamer Remote, hold down P until the red light blinks twice.
8. To test a learned function, press the learned key on the Gamer Remote and use the function as usual.
Jan 14, 2010 | Radio Shack (15-2147) Remote Control
Cant get program codes to work on AKIA tv with rca converter box
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Jun 13, 2009 | RCA Universal Remote Control
Will a universal remote work on a insignia digital converter box?
doublecheck the paperwork for both the converter box and the universal remote. the universal may be too old to be used with your converter. look in the back of the universal's manual to see if your box's corporation has a code you can set.
Jun 12, 2009 | JVC TH-C4 System
Feb 03, 2009 | Insignia Digital-to-Analog Converter for...
Universal remote programming
Since Insignia is really Zenith, a universal remote that can work on Zeniths should do the job. I have this converter box and use a RCA universal remote. I code that works is usually reserved for Zenith satellite boxes (5203).
Oct 26, 2008 | Insignia Digital-to-Analog Converter for...
Insignia Digital-to-Analog Converter for Analog TVs Logo
60 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
