Question about Samsung SGH-E900 Cellular Phone
One side of my slider came off it's track
I dropped my slider and only one side came off its track. Anyone know how to fixed it?
  • solvethem May 11, 2010
    take to the shop you did buy the phone from and get the sliding key cover replaced
  • 700 Answers
Take it to a shop. They have slider prying tools( a simple plastic tool to take care of that notch lock).
It should be aligned at the same time before reinserting the back portion.
Posted on Sep 12, 2009
    Problem Solver:
  • 15 Answers
Take to the shop an get sliding key cover fixed
Driver side window rolls down fine, but will go crooked if not held in place when rolling it up. does anyone know how its held in track?
I had the exact same problem on a 2003 Montana. I thought it was a problem with the tracks or the lifting mechanism ( it is a "scizzor" style lift-not a cable style). after careful study I came to the conclusion that the glass was binding at the point where it comes into contact with the window frame....I simply applied some disc brake caliper "silglide" slider lube (it was handy and being silicon based would resist water) to the inside of the window seals...problem solved!
Feb 24, 2013 | 2000 Pontiac Montana
1999 Ford Explorer Sport. Cracked Lower Seat Frame front of left side hinge attatchment/recliner handle. Lower seat frame needs to be replaced or welded. I am working out of town and can't get to a shop...
I have seen both wood and bricks used to put under a seat frame. Some of the seat mounts do not give you much room for using a wrench. They give you room for a 3/8th air rachet and socket. Especially if you are a little shorter you can elevate the frame and then put wood in the cavity and then lower the seat for a temporary fix.
There are some operating parts I have no name for, but they connect the gears on each side of the seat track. So the wood blocks have to fit between these parts. I can recommend a Salvage yard called "Parts Galore" which is expanding Nationwide. Again wrenching on this stuff is hard without power tools.
Can't address swapping passenger and driver tracks. Check out small "C" clamps or conduit clamp.
Jul 24, 2017 | Ford Explorer Sport Cars & Trucks
Have a 1999 Chevy 1500 extended cab. Driver seat is not powered. Won't lock into place, keeps sliding back and forth. Was told I have to replace the whole seat and sliding track by Chevy Dealership. Anyone...
Remove the seat assembly turn it upside down cables come off the handle you pull on to slide seat, Follow these cables to 2 pawls that pivot on tracks and see if they are broken,bent,or just stuck and need cleaned and lubed.If you need new track slider assembly I use to be able to get them all the time from GM parts department and just replace tracks themselves.
Dec 23, 2009 | 1999 Chevrolet C1500
I need to know where to buy assembly tracks for Cosco crib.
I just posted a similar answer to another person looking for hardware for an older crib. PLEASE do not use this crib. Any crib with hardware missing is an accident waiting to happen. Even if you were to find the tracks, if you are screwing those tracks into wood, then the screws will not be as secure as the original ones and can and will get loose and back-out of the wood. If that happens and the track comes loose, that corner of the drop side can come off which creates a death trap for your baby. A crib is the ONLY place a parent can safely leave their infant alone. So you want to make sure you have the crib in the safest condition. This means all original parts, nothing broken, bent, cracked or repaired. Too many babies die each year because parents attempt to repair or fix a crib with missing parts.
Jan 12, 2009 | Baby Gear
Bottom Draw Wont Close
Check the sides of the drawer on the dishwasher and make sure that the sliders that the drawer rides on are not locked in place you will notice on the front of the slider near the door panel there are plastic clip like press in tabs that hold the drawer securely in the tracks try to put your hand up under the door and move the track if the track moves in the slider you will need to hold the door secuely with one hand while sliding the track to the most open position on the slider track. if the sliders are not locked in you will be able to pull the slider forward and the slider should clip into place.Repeat this for both sides and the door should operate like new once again.
Jan 08, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Sliding drawer in the top refrigerator section
hi i have the 700tc as well,,ok the best way to place the drawer,,,extend the 2 sliders all the way out,,there is one pin at the end of each slider and 1 hole on each side of the drawer lip which lays on the track ,,,the holes on the drawer must fall into the pins otherwise it will not close,,,so place the drawer on top of the slider ,,,what usually happens is the sliders tend to roll back into the housing of the fridge,,,so while the drawer is resting on the sliders reach under the lip of the drawer and pull each slider until the the holes of the drawer falls into the pins,,,when the drawer is seated in the pins it will close smooth,,,hope this helps
Feb 10, 2008 | Sub-Zero 700TC Bottom Freezer Refrigerator
Samsung d807 slide problem
take both phones to a mobile service center or a professional mobile tech and have the phones sliders fix.
Jan 13, 2008 | Samsung SGH-d807 Cellular Phone
Slider popped out
Unless part of the plastic slide has broken off, you can simply "snap" it back in place. Being careful you my need to use a little force but it should just snap back into the track.
Dec 28, 2007 | Samsung SGH-D600 Cellular Phone
D807 off track
okay just take the phone to a mobile service center and have them fix the slider back onto the phones for you or a mobile technican.
Dec 19, 2007 | Samsung SGH-d807 Cellular Phone
Slider disaster
I have exactly the same problem. Can somebody help?
Nov 28, 2007 | iRiver H10 MP3 Player
Samsung SGH-E900 Cellular Phone Logo
101 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
