Question about GE Spacemaker JMS08 Electric Kitchen Range
When baking the temperature is wrong or varies. The result is cake burned on outside and uncooked inside. Is it the thermostat?
    President:
  • 1,723 Answers
Put a 'oven thermometer' in the oven to verify the oven thermostat. is correct...or not
Posted on Sep 03, 2009
Testimonial: "Thanks. "
    New Friend:
I was in the same situation today as well. You only need to fold the batter properly with a whisk as to let a lot of air into the mixture, and take the measurements of the fluids accurately. I used a lot of pineapple syrup. It ruined my cake. It turned out to be more like a pudding.
Posted on Dec 29, 2012
I have FGES3065KFA gallery and I have baking problems. It bakes outside of the cake but inside of the cake stays raw. Me and my husband check the bake and broil element they work fine. We change the...
read the mixture instructions
try preheating the oven for the required temperature or when the thermostat turns the light off
insert the cake to be cooked and leave it there for the desired time
Too hot will burn the outside with out cooking all the way through
check the ingredients carefully as if the mixture is too wet ( butter, milk, water all make it wetter than required )
Place the cake in the center of the oven ( not on the bottom shelf or the top shelf)
All these may sound mundane but they all point to getting a good cake result
Sep 14, 2015 | Frigidaire FGES3065KF Gallery 30" Slide In...
The half of my cake burned when I bake
i would check the over temperature sensor as it can cause variable intermident heating
Apr 05, 2015 | Ovens
Why is my oven burning baked goods on the outside but still raw on the inside, when baking at the correct temperature setting?
Sounds like you need to set your thermostat as its not reading properly. Ours has a little screw on the side of the thermostat and I use an oven thermometer to make sure the heat is right. Ours was twenty five degrees out.
Dec 16, 2014 | GE Profile Spectra JBP95 Electric Kitchen...
Brown cake and burn
Most devices like this are gimmicks. Nothing beats a real oven and and a real cupcake pan, a good recipe a lower temperature and a longer baking time. I always put a thermostat inside the oven to verify that the inside temperature matches the one on the dial, but never assume the dial is even close. Once you become good using an oven you will never go for the gimmick appliances.
Nov 08, 2013 | Bella Cake Maker Fluted Cake Maker
Cake flop in the middle what can the problem be
You should always buy an oven thermostat so you can verify the temperature inside before putting the batter in. I also use magic cake strips soaked in water and pinned all the way around to even out the temperature so that the cake rises the same time on the edges as the middle without the outsides baking too fast. and staying stumpy.
Sep 23, 2013 | Ovens
Baking cakes and quiches
i use the micr-convention mode to bake and preheat it at 200 C ,the cake rises unevenly and falls unevenly .i open to check if the cake is done .why does it rise unevenly and why does it fall ?
Jul 18, 2012 | Microwave Ovens
Why do cakes sometimes collapse while baking?
helllo dis.... There are many things that can cause cakes to fall in the middle.... Jumping, etc., around the baking area is unlikely to be a problem except with very delicate sponge or angel food cakes. More likely, cakes fall when the crust appears to be done, but the batter is not baked through the middle. An uneven baking temperature is a frequent culprit; check the temperature of your oven with a separate baking thermometer, and be certain that your oven holds a steady heat through the entire baking period. Some older ovens preheat properly, then cycle off and drop the temperature after 15 or 20 minutes, which causes the uncooked portion of the cake to fall.
Less likely but possible problems could be inaccurate proportions of baking powder or baking soda if the cake is made from scratch. This could occur with cake mixes if sour milk or buttermilk is used instead of regular milk; the additional acid in sour milk requires additional baking soda to rise properly. Eggs that are not beaten properly, or perhaps beaten too much for the type of cake being made, might also cause problems. Joe
Mar 12, 2011 | Tecnik Ovens
GE Spacemaker JMS08 Electric Kitchen Range Logo
173 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
