Question about Microsoft Windows XP Home Edition for PC
Search indexer bogging down system - my system cahe shows using nearly 1/2 my available memory - can you help?
  • 44 Answers
Go to My Computer, either through the Start Menu or by a desktop shortcut. Right click your C: Drive (or any other drive you don't want indexing), then choose Properties. This opens a new window. Under the General Tab, you'll find a checked option that says, "Allow Indexing Service to index this disk for faster searching." Uncheck that box.
Indexing doesn't use up enough resources to bog down a system, though. It will cause your HDD to constantly be working anytime the computer is on, but it's using very little of your available memory or CPU power. I would open msconfig from the Start >> Run Menu. Click Services, then the box that says Hide All Microsoft Services. You don't want to disable any of those. Go through the list and disable anything you don't want running, then do the same on the Start Up tab. Microsoft Services will still be hidden. This will cause things you don't always need running (like msn messenger, for example) to not automatically start when Windows starts. They are still 100% usable. Note that my experience with msn messenger is that it will automatically reconfigure itself to start on start-up anytime you run it.
Another handy option is to download a program called Ccleaner. Install it, then run it to clean out both Application Data and Registry. Be sure to save all back-ups when prompted. Restoring them is simple if necessary. Following running Ccleaner, download and install MalwareBytes AntiMalware. Run a scan then use Control Panel >> Add or Remove Programs to uninstall it when you're done, it's not an effective active scanner.
Hope all this helps. How much RAM are you using?
Posted on Sep 03, 2009
The Windows Search service stopped working on my Win 7 machine. Said indexing was not turned on. I used event viewer and found the following error message: The Windows Search Service has failed to...
1) Insert your flash drive
2) From the Start Button, type "services.msc" in the "Search programs and files" box
If prompted for Admin Access, answer yes
3) Scroll down to the "Windows Search" service, select it, and click Stop.
4) From the Start Button, type "regedit"
5) Browse to [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Search]
6) Verify that the values DataDirectory and DefaultDataDirectory are set to %ProgramData%\Microsoft\Search\Data\
7) Remove the flash drive
8) Reboot (or restart the Windows Search service)
Jul 26, 2011 | Microsoft Computers & Internet
Tip
Heres a Few Tips to Speed up WIndows Vista...
1.Turn off Windows Search Indexing
Windows Vista search indexing is constantly reviewing files on your system to make their contents available for quick searching. This is handy, but can severely impact system performance.
To disable this constant indexing:
* Click Start then Computer
* Right Click the C: Drive
* On General Tab, Uncheck Index this drive for faster searching
* On the subsequent dialog box, Select Include subfolders and files
2. Turn off Remote Differential Compression
Remote Differential Compression measures the changes in files over a network to transfer them with minimal bandwidth rather than transferring an entire file that has previously been moved. By constantly checking for file changes, this service can hinder system performance.
To disable this service:
* Open Control Panel
* Switch to Classic View
* Select Program Features
* Choose Turn Windows features on and off
* Scroll down and uncheck Remote Differential Compression
3. Turn off Automatic Windows Defender Operation
Windows Defender real-time protection against malware continues to run despite having Automatic operation disabled.
To disable this feature:
* Select Windows Defender
* Choose Tools from the top menu
* Select Options
* Uncheck Auto Start at the bottom of the window
4. Turn off Automatic Disk Defragmentation
Windows Vista and its always-on defragment feature isn’t really that necessary and can cause system slow down. Just remember to run a defrag manually every week or so.
To disable this:
* Select the Tools Tab
* Uncheck Run on a schedule
5. Add a 2GB or higher USB Flash drive to take advantage of Windows Ready Boost (Additional Memory Cache)
Ready Boost is Microsoft’s name for using a USB thumb/flash drive to provide some quick access memory the operating system can use as extra RAM. The Ready Boost system can significantly improve system performance.
To set this up:
* Insert a USB Flash Drive (preferably 2GB or more)
* Right Click the USB Drive in My Computer
* Select the Ready Boost Tab
* Choose Use this device
* Select as much space as you can free up for RAM usage vs. Storage
6. Turn off Windows Hibernation
Windows hibernation background services can use a large amount of system resources. If you don’t use the Hibernate feature on a regular basis you may want to disable it to give Vista a performance boost.
To disable Hibernation:
* Select the Control Panel then Power Options
* Click Change Plan Settings
* Click on Change Advanced Power Settings
* Expand the Sleep selection
* Expand the Hibernate After selection
* Crank the selector down to zero
* Click Apply
7. Turn off System Restore
Analysis and restore point creation by Windows Vista can eat a fair amount of system resources. Disabling this service will obviously mean the system restore feature in Vista will not be available in the event of a system crash. Change this at your own risk.
* Control Panel>System
* Click System Protection on the left panel
* Uncheck the main system drive
* Agree to the confirmation
8. Disable User Access Control (UAC)
This much-loathed new Vista feature attempts to protect your system from malware infection by making you manually confirm a whole host of everyday user operations. While it doesn’t directly impact performance, it can be annoying and might be more hassle than good.
To disable User Access Control:
* Click Start then Control Panel
* Select User Accounts
* Select Turn User Account Control on or off
* Uncheck User Account Control Box
* Restart as recommended
9. Disable excess Windows Services that Auto-Launch at Startup
Just like Windows XP, Vista ships with all kinds of services enabled that load at startup and may never be used by most users.
To see what loads at startup and disable the ones you likely won’t be needing (they can always be started manually later):
* Select Administrative Tools
* Choose System Configuration
* Click the Services Tab
* You can safely deselect:
– Offline Files (unless you’re using Offline File Sync)
– Tablet PC Input Service (unless you have a tablet PC)
– Terminal Services
– Windows Search (If you have already disabled indexing)
– Fax (unless you’re using a fax modem)
10. Disable Excess Windows Features
Windows ships with other features that are listed separately in the Vista operating system from the startup services.
You can view and disable these features by:
* Clicking Start then Control Panel
* On the left panel, select Turn Windows Features on or off
– Indexing Service
– Remote Differential Compression
– Tablet PC Optional Components
– Windows DFS Replication Service
– Windows Fax & Scan (unless you use a modem for faxing)
– Windows Meeting Space (unless you use the Live Meeting Service)
on Jun 11, 2010 | Computers & Internet
Tip
Refine search for MP3 with GOOGLE
Many times we search online for different MP3s but we need to go to multiple websites to get a free download available. The below mentioned string will help you ease the search and the results will be refined.
You can use the given string : -inurl:htm -inurl:html intitle:"index of" "Last modified" mp3
Now an example to show you how to use it:
-inurl:htm -inurl:html intitle:"index of" "Last modified" mp3 "Ronan Keating"
OR
-inurl:htm -inurl:html intitle:"index of" "03/02/2010" exe "Photoshop"
This will do an index searching and the results will be refined and fast.
Regards,
Shrey
on Mar 03, 2010 | Computers & Internet
Trying to increase broadband speed.
There are software programs that claim to do this I have really used all of them pretty much and the only real way to speed up a connection is to set up browsers and use a different browser than IE8 like Google Chrome which is quick. Or the best way is to increase the speed with your ISP and call them to ad more speed if available it is more money per month but worth it. If this option is not available to you try another ISP for more speed options.
Speed depends upon what your ISP is offering you as well as you computers capabilities to handle software and its configurations, try reseting the routers do this by turning off the computer and hit the reset button on the router as well as memory and making sure that other programs are not using this speed as well when trying to download or other tasks. Try doing a good cleaning on your computer as well. Often times if the system is bogged down so will your internet be bogged down as well. Thanks for using FixYa! John
Mar 01, 2011 | Computers & Internet
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
Tip
Speed up vista !!1
  1. 1. Shut Down Remote Differential Compression
  2. Remote Differential Compression checks the changes of your files over a network to move them with as little bandwidth as possible instead of transferring an entire file that has previously been moved. With in constantly checking for file changes, this service will greatly slow system performance.
    To shut down this service:
  3. Control Panel
  • Change to Classic View
  • Choose Program Features
  • Select Turn Windows Features On And Off
  • Uncheck Remote Differential Compression
    1. 2. Shut Down Windows Search Indexing
    2. Windows Vista search indexing is constantly checking the files on your system to make their information available for quick searching. This is helpful, but can severely slow system performance.
      To shut down constant indexing:
    3. Select Start then Computer
    • Right Click your C: Drive
    • General Tab, Uncheck Index this drive for faster searching
    • On the next dialog box, Choose Include subfolders and files
    1. 3. Add at least a 2GB USB Flash drive to take advantage of Windows Ready Boost
    2. Ready Boost uses a USB flash drive to provide quick access memory for the operating system. The Ready Boost system can greatly improve system speed.
      To set it up:
    3. Plug in a Ready Boost Compatible USB Flash Drive
    • Select Start then Computer
    • Right Click Your USB Drive in My Computer
    • Choose the Ready Boost Tab
    • Click Use this device
    • Choose as much space as you can free up for RAM usage vs. Storage
  • on Jan 29, 2010 | Computers & Internet
    What are the exact instructions for upgrading my
    Crucial has a very good guide:
    http://www.crucial.com/install/dimm.aspx
    And they also have a auto system checker that will detect current ram Spec's and show you whats available .
    http://www.crucial.com/systemscanner/index.aspx
    Jun 09, 2009 | E-Machines eMachines Desktop PC
    How to disable cahing or shadowing
    You can do this in your BIOS settings. When you reboot the computer, look for a message that states what key on the keyboard to press to enter BIOS settings. Usually DELETE key, F1 or F2 key. Look for advance settings tab in BIOS menu. You will see it under there.
    Mar 28, 2009 | Microsoft Windows XP Professional With...
    Computer slow or hangs up, 1 gig of memory in use
    before installing norton just give a try to avast 4.8 you can down load it free from avast.com, your pc is infected by viruse, just do a scan by disabling the system restore,post back your findings
    May 24, 2008 | Toshiba Satellite P105-S6024 Notebook
    Dell laptop memory install
    available physical memmory is what all your programs on your comp is using like windows virus software drivers im thinking you probably have spyware or bugs in your comp that could be bringing memmory down
    total physical memmory is what you just put in
    May 09, 2008 | Dell Latitude C640 P4 Mobile Notebook
    Microsoft Windows XP Home Edition for PC Logo
    110 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
