Question about Whirlpool Washing Machines
Water comes in but will not begin to wash - Whirlpool Washing Machines
  • Wayne Holden May 11, 2010
    Does it stop filling?
    Scholar:
  • 123 Answers
Hi there......this problem is usually related to badly worn brushes in the motor...a quick way to check this is.....(1) remove the machine from its position...bringing it foward enough to tilt it back sufficiently allowing you access to the botom of the machine...(2) insect the motor for signs of black carbon dust...indicating brush ware....gently tap the motor with a small hammer...or suitable object....stand the machine uright again...select spin....run machine....if all is ok machine will run indicating a set of replacement carbon brushes are required....failure to run indicates brushes very badly worn and possibility of damaged motor...remove the rear panel of the machine...remove the belt...remove the motor for inspection..of armature and brushes...any burn or discolouring marks on the copper brush track...indicates a failed motor..which will require replacing....
regards Sir Galahad
Posted on Sep 03, 2009
My washing machine is not filling up with water?
check either the water inlet valve or the water pressure switch with a multi meter for continuity
Mar 10, 2015 | Maytag Washing Machines
LG washer high pitch noise when water enters at beginning of cycle
Two possibilities: the water is coming in under pressure through a solenoid valve that is not fully open or the pressure pump is whining on its bearings.
Jan 22, 2013 | LG WT5170V 4.7 cu ft High Efficiency Top...
Washer will not spin water out
There is a flap inside of the washer that comes up as the washer begins to spin...Just replace that valve and everything should be fine. As long as its spinning and washing you will not need to get a new one :)
Nov 19, 2012 | Washing Machines
Laundry washing machine
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 26, 2008 | Washing Machines
Fabric softener dispenser
remove top of machine, there is a arm running across from programe dail, to drawer despenser,its spring loaded it determines which compartment the water gos into,check it
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
Water only fills the machine in certain parts of cycle
a 90* wash will fill mainly with hot water / a 40* wash will fill mainly with cold water, this is normal action, rinses fill up with cold water only
is this what you are describing, if so thats normal, especially if its doing the job correctly
Oct 14, 2007 | Frigidaire GLTF530DS Front Load Washer
Frontloader washes and rinses on cold all cycles but whites
drain hose maybe going down the waste pipe too far 4 inchs is about right,check it out,most machines take in extra water on a cold wash!!!close eire
Jan 31, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal De
