Question about Panasonic Audio Players & Recorders
RE: Panasonic surround system mod. #sa-ht920 no sub, center or
RE: Panasonic surround system mod. # sa-ht920 When it plays dvd's, no sound comes out of subwoofer, center, rear left & rear right channels. Only front left & front right work.
What could be the problem?
  • jiro Sep 03, 2009
    Re: Panasonic home theater 5 dvd changer mod.# sa ht920 .
    When it plays dvd's, no sound comes out of subwoofer, center, rear left or rear right channels.
    Front left and front right channels work ok.
    Any suggestions?
  • jiro Sep 04, 2009
    Thanks for the tip.
  • 3,741 Answers
Connection from receiver Subwoofer output jack RCA plug male go into your powered Subwoofer low level input with other end of cable, then you need to select Subwoofer YES/NO on the receiver speaker setup menu option, select YES if this is a powered Subwoofer you are using, should power up the Subwoofer, may have to adjust a test tone balance for multi speaker output also, try trimming up on the Subwoofer channel to initiate the signal on if the sub has an auto-on feature. ------------- Also check all the connections again.if anything loose or got cut in between.remove all the connections and refit it again.also interchange the connections and check. -------- thanks.keep updated.please do rate the solution.thank you for using fixya.
Posted on Sep 03, 2009
    President:
  • 1,734 Answers
When using a home theater system the best way to set everything up is to have the audio from all of your source devices(DVD player, Cd player, Cable box) going directly into the home theater bypassing the TV altogether.
I'm assuming that the audio feed from the TV that you are trying to get is for your cable or satellite but please correct me if this is wrong.
To get the sound from the Cable box you can use the Optical digital audio output on the Cable box and run this into the optical in on the home theater. This will require an Optical digital audio cable which is also known as toslink.
If the Cable box does not have an optical out the you would need to run two RCA cable(left and right) from the audio out of the Cable box and in the Aux audio in on the home theater.
once the cables are run select the input on the home theater (either optical "D-IN" or aux audio "AUX" depending on which one you use) and this should allow the sound to be played back.
As I have assumed a few things here let me know there is anything that will not work in your situation and I will go further to answer your question
should the solve the issue please feel free to accept the answer. If you need me to elaborate or need any clarification please let me know.
Sub woofer and rear speakers cut out
Check the speakers with an OHM meter to be sure that they are not bad. Switch the speakers so that the front is the back and see if the issue goes away. If it does not then it is the amp. It could be the temp sensor or overload sensor
Jul 29, 2013 | Panasonic SC-HT920 System
I have an older Panasonic HDTV Viera and I am trying to hook up a Panasonic DVD/sound suround model SA-HT920 and am not having any luck getting it too work. I have the sound turned off on the tv speakers...
What does the TV really need from the receiver in all of this? Minimally, Component video for the DVD and managing the SA-HT920, not much else.
A TV is not normally an optimal source of audio.
Your broadcast TV-related sound would be higher quality and easier to obtain if you got it from the Cable or Sat box you probably have. Route ITS BEST (digital multichannel) audio directly to the SA and and its BEST (HI-DEF) VIDEO directly to the TV. You could also run vanilla analog audio to the TV so you can watch news in lo-fi audio on the TV.
The exact model of TV would be helpful to know as audio capabilities may vary.
Should you still feel the need to run TV-originated audio to the SA from the Viera through its headphone or audio output, connect that to any available analog RCA input.
Connection of a jack into the audio output will pass unmodified TV audio to the SA. That's a good thing as the REAL audio electronics needs an unmodifed source for best results.
Feb 13, 2011 | Panasonic Audio Players & Recorders
How do I get my Panasonic sa-pt670 to play all the speaker. watching tv and with ps3
Does you Tv set have optical out? If so might I suggest running HDMI into your television set from the PS3, then run an optical audio line out from the tv into the optical line in on your HTIB
Feb 24, 2010 | Panasonic Home Theater System System
When I play a DVD in the system I can only get the surround sound out of the speakers but no voices. If I play a CD or hook it up to my tv everything is ok.I have tried a number of DVD's and all have the...
sounds like you need to surround modes. There is usually a Stereo, Dolby, DTS, "virtual surround", 4-speaker mode etc..
When you play a CD or connect to TV it likely defaults to playing stereo or virtual surround.
With real surround, almost all of the voices are coming from the center-channel speaker (normally placed closest to the TV).
Also, check to make sure the center channel is connected properly.
Aug 31, 2009 | Panasonic SC-HT930 System
Why does the picture flickers,keeps moving down but clear sound
yes this is a simple fix,change the tv channel up 1 or down 1
Aug 05, 2009 | Panasonic SC-HT920 System
Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Aug 04, 2008 | Panasonic Home Theater System System
SA-HT720 DVD home theater system
does anyone know were i can get a power cord for 1
Dec 26, 2007 | Panasonic SC-HT720 System
Panasonic SC-HT920
One option is to set the cross over to the sub so it knows when to send the low frequency to the sub and not the front speakers. 120 is a good setting. This can be done either via a know on the sub woofer or the setup screen of the main unit.
good luck
smeags
Sep 07, 2007 | Panasonic SC-HT920 System
155 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
