Question about Amana LWA40A
Water leak. noticing water under the machine and we are certain that it is coming from the. Also, there we are getting spots of grease on clothes when we remove cleaned clothes.
  • jpilon Sep 03, 2009
    Machine is approx 9yrs old. Is the seal visible with the agitator removed?
  • Wayne Holden May 11, 2010
    Pull the agitator and see if the case if broken or if the seal is just leaking. How old is it?
  • 41 Answers
Without really looking at it i would have to say it Sounds like water seal gone in drum. If back of drum at the bottom is wet with black or dark run stains this is the problem.
Good luck
John
Posted on Sep 03, 2009
Leaves spots on my clothes
Kathy, you may have the beginnings of a tub bearing failure. What usually happens is the water seal fails on the tub drum shaft. This lets water into the bearing cavity and usually some grease migrates out into the drum. What eventually happens is the wash water eventually washes the grease out of the bearings and they fail. You will notice your spin cycle getting louder and louder.
You can check for a loose tub bearing by lifting the drum gently at the top. Is there play where the drum can move vertically, independently of the outer assembly? That's my guess. You can do an internet search about tub bearing replacement if you want to get into that. Its doable, depending on your skill level. Good luck.
Been there and done that. Usually Frigidaire doesn't sell the bearings, but they are standard bearings and you can usually match up a seal.
Mar 17, 2014 | Frigidaire GLTR1670A Front Load Washer
GE WSXH208FWW washer leaving spots on clothes
If you are getting round dark spots on your clothes after washing, the problem would be cause by a bearing seal leak. What happens is water leaks pass the seal into the bearings, and the grease leaks back into the wash water. To fix it would require the machine to be literally taken completely apart to get to the bearings. Very costly to repair. Sorry.
Aug 24, 2010 | GE WSXH208A Front Load Washer
Noticed after I do a load of laundry there are black (grease) spots on my clothes. I found a grease spot on the bottom of tub. What could this be?
its the topseal on the transmission thats leaking,the term for this is called "back-wash" you need a new seal
Feb 03, 2010 | Washing Machines
Grease-like stains on clothing
hi. i can help. the grease is coming from one of two places. Either some item with grease on it got placed in the machine and the grease transferred to the tub where it will cause the problem until it is spotted and removed with a degreaser, or wears off.
OR the grease is coming from the washer itself. Perhaps some grease oozed out of the mechanicals related to the aggitator.
Either way I would get a strong flash light or trouble light and look carefully in the tub and around the aggitator for grease. Then remove it with a cloth and some degreaser, available at any auto parts store.
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Stains
Apparently the residue is fatty buildup from fabric softener. Try filling it up with the warmest water possible and add some bicarb to dissolve it, then rinse a few times to get it out of the machine completely. Then use vinegar instead of softener for most washes, or dilute fabric softener with water 1:4 and occasionally rinse with bicarb. This works for me.
Oct 20, 2008 | LG WFT1071TP Top Load Washer
6 years old hoover washer dryer. Not all, but some light colored tee shirts coming out with what appears to be oily spots. Tried bleach and dishwater tablet as suggested by another forum, but to no avail....
Hi there monobloc,
I've gone through this too. Dishwashing liquid soap, specifically with grease cutting properties. It does take a few cycles to clean it all out though.
Mike
Sep 01, 2008 | Hoover Washing Machines
Grease spots on clothes
That could mean your overloading your dryer to the point the wheel bearings are squished really bad. When loading your washing machine you should always be able to see the water level more than the clothes, your clothes should be floating in the water. That way, when you unload your washing machine and go to dry, you will have the right amount of clothes everytime
J
Jun 29, 2008 | Whirlpool LER5636P Electric Dryer
Front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Sep 18, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
262 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
