Question about Audio Shelf Systems
Mw10 in garageband
I have a yamaha mw10 mixing desk which i use in cubase but i'm finding it impossible to use in garage band can you help.
0 characters
1 Points
Cd drawers won't open, may have cd stuck in #1 slot
How to Fix a stuck CD Tray - YouTube
? 6:24
Mar 24, 2010 - Uploaded by Guy Techie
Pin won't open my tray :( Help please?. Read more ... I was lucky to find a rubber band in my junk drawer and it ...
When a CD or DVD is stuck or the drive won't open ' PCWorld
Dec 09, 2015 | Audio Shelf Systems
Where can I find drive belt for rca rs-9150a (opens the cd door)
I have had this unit for a number of years. Can't find the original drive belt so I've been using rubber bands. They work for a while till they dry rot. If you're doing the job yourself, go to a hardware store and get an assortment of rubber O-rings for plumbing. A little tricky to get one on the gears but I put one in a few months ago and so far it's outlasting a rubber band.
Feb 14, 2015 | RCA Audio Shelf Systems
Disk will notcome out
Hi Carol,
This is an educated guess but if your deck is older there are eject mechanisms on them. They are belt driven if they are stretched out or broken the disc will not eject on most of them.
Depending on age the belts which are glorified rubber bands last about 10 years or less then need replacement so my best guess is the drive band for the ejector is in pieces in your deck.
Replacement bands are available on ebay, this is not the only possibly answer to your problem but my best guess from your limited description. Note you cannot replace a broken band with an o ring or rubber band or a similar band as they will not work correctly...
Apr 11, 2014 | Sony CMT-HP7 CD Shelf System
Need capstan band on turntable...old one broke so turntable will not around
Take the broken one to a hardware store and check the o-rings. You just might find one the right size.
Jul 02, 2012 | RCA Lawton Turntable with Analog Radio/CD...
I need a technician to fit b&o system without
Northwest doesn't narrow it down much.
Finding one at all is the trick. Qualifying the rate you will pay is impossible.
Do you have manuals for the equipment?
Search engines lead to some resources which may help you self-assist.
For example...
Is there a specific question?
Jul 13, 2011 | Bang and Olufsen Beocenter 9300 Shelf...
I have a Yamaha dvd-E600, is there a de zoning code?
Please try the instructions found here:
For unlocking multi-region on this dvd player.
Hope this helps,
Mar 01, 2011 | Yamaha E600 Shelf System
Cannot tune radio station manually. Only browse by band memory scan, help
Ok to set Manually Turn on radio Select Tuner select band. Press tuning mode button. The window should switch from preset to manual then tune up or down using the tuning preset time buttons left side/ top / Next to volume knob
Nov 03, 2010 | Teac EX-CD3 CD Shelf System
My RCA Stereo system 5 disc cd drawer keeps opening. When I put a cd in it, the unit opens and keeps opening. It only stays closed when I turn off the unit and manually push it closed. What could be...
These units are actually nice units. There is a "loading belt" inside that controls the tray movement as well as the final "load" of the mechism into the play position. If the load does not complete, the unit will "eject" or open up. This is most often cured by replacing the loading belt. This is a common problem with any rubber component. As it ages, it gets a little slippery and thus will not have the grip to complete the loading sequence. The belt for this will run about $5.
Aug 26, 2010 | RCA 100-Watt Stereo System With 5-CD...
Need the elastic band that helps run the tape deck. using a bog standard band from work but not sure how long this will last. any ideas regards spares???
Have you kept the old belt? If so measure the diameter and then look around the net for "Belt ??mm". If not measure the diameter of the one you have in.
Belts are standed and are not specfic to any machine.
Feb 17, 2010 | Bang and Olufsen Beosound 2000 Shelf...
Connect to computer
hi, you will need some cables for this job. to connect ur GX to the comp will take a stereo RC to EP cable, the RC connectors will go to the line out of ur GX and the EP will go to the line in of the comp sound card.. let me know
Dec 29, 2007 | Yamaha GX-70 CD Shelf System
Audio Shelf Systems Logo
76 people viewed this question
Top Audio Shelf Systems Experts
Are you an Audio Shelf System Expert? Answer questions, earn points and help others
