Samsung HP-S5073 50 in. HDTV Plasma Television picture goes black, volume works
SOURCE: 50" Samsung Plasma with black screen
I had the same problem and had the TV serviced and found that the y board was blown $350 total. The repair guy explained that the board has a hot transister underneath that slowly leaked onto the board, but says that they can not get Samsung to admit to the problem. Works fine now but only have a 90 day warrenty on the parts.
Posted on Jul 01, 2009
dsacco86
  • 1077 Answers
SOURCE: HP-R5072 50 in. HDTV Plasma Television Samsung
Most likely it sounds like a Logic Board problem. The Logic Board is what controls images on the screen. It's a somewhat expensive part to replace. Maybe in the $200 range. Being that the part isn't cheap, best to have a TV tech come to your house to take a look at the TV to confirm the diagnoses before buying the replacement part.
Posted on Oct 25, 2009
futurework
  • 70 Answers
SOURCE: Samsung PPM50H3Q 50 in. HDTV-Ready Plasma will not power on.
could be a power supply failure or a control issue. I would take the unit to a repair shop and see if they can provide you with an estimate. You could try to buy a replacement power board and install it on your own if you are mechanically inclined.
http://www.shopjimmy.com/samsung-bn94-00494u-power-supply-unit.htm
Posted on May 05, 2010
  • 4090 Answers
SOURCE: Samsung HP-S5073 Loss of Picture
usually both boards are involved and unlike PC's board swapping is not the best way to fix it as they need to be setup correctly and tuned. This involves using a device that create a hatch pattern and the convergence is aligned to manufacturers specs.
There are other components that may also be involve and needd replacing ( like capacitors etc)
Those that have attempted to DIY are still here trying to find out how to fix them Often they burn them out trying to save themselves a repairman cost. If it was that easy we wouldnt have to spend 3 years learning the trade.But some people can't be told
please rate my help++++Thanks for using FIXYA
Posted on May 08, 2010
  • 25 Answers
SOURCE: HP-R5072 50 in. HDTV Plasma Television: i have one red dot on plasma screen. it is always ...
Unless you see more red dots, this kind of "defect" is under specifications for this size of PDP, if you do not like it, the PDP module must be changed
Posted on May 19, 2010
Samsung plasma 42" model HPR4252xlxaa only have picture in center of screne the rest is black or black mesh. sometimes the whole screne brightens up for 15 to 30 seconds with great picture then goes b
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 02, 2018 | Samsung HP-R4252 42 in. Plasma HDTV
I Have a Samsung HP-R4252 42 in. HDTV Plasma Television and the picture is not showing. It does have sound but no picture. Is there any ease way to fix this problem??
sounds like the video cable is not in the right input.
or maybe you have to redo the setup and be sure the tv is set to the right video input . HDMI or component etc. I hope this helps.
Oct 19, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Looking to buy a Samsung HP-S5073 Plasma, and the owner says that the screen goes blank sometimes. (But the sound still works while the screen is blank). This could happen for 5 minutes or an hour. Then it...
There is a possibility that this comes from poor signal quality. Re-booting the television may stop this behavior for a period of time, but if the problem is not corrected, it will return.
There could also be an internal problem with the television.
(Personally, I would look to buy something else.)
Hope this helps!
Jun 17, 2010 | Samsung HP-S5073 50 in. Plasma HDTV
Lg 42inch plasma
Sounds like main board failure and or power board failure. You need to contact manufacturer and describe problem for tech support. Some of the parts in Samsung TVs have lifetime warranties. Change out of two board is about an hour job and service call is usually comped. Hope this helps. J
Apr 09, 2009 | Samsung HPT5054 50 in. HD-Ready Plasma...
Black & white picture
IF YOU JUST PURCHASED IT, THEN CALL 1-800-SAMSUNG FOR WARRANTY REPAIR
Dec 27, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Plasma TV Background noise
Here's the number to HP case management 877-917-4380 ext.79, try this number and be firm that they need to fix this, I just had an HP plasma that was 3 yrs old replaced for free, no charge. Good luck
May 28, 2008 | HP PL5000N 50 in. HDTV Plasma Television
Plasma-No picture
Main logic board $124 fixed mine email me rudog3369@yahoo.com!!!
Apr 26, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung hp-p5031 problem
Dear friend the black screen you see is the Dual NTSC Tuner Built in with Split Screen PIP, and the only way to disable it is by looking in to the user manual if you don't have it you can download it from the Samsung website, here is the link:
http://www.samsung.com/ca/support/productsupport/download/FileView.aspx?cttfileid=221661&type=TV&typecode=200100&subtype=Plasma+TV&subtypecode=200102&cmssubtypecode=&model=HP-P5031&filetype=UM&language=
Dec 06, 2007 | Samsung HP-P5031 50 in. HDTV-Ready Plasma...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
