Question about Sony Ericsson Walkman® W995 Cell Phone
The down button stopped working and answer and end call stopped to
Have 1739 system, How do I get English?
Press and hold SETUP button until you hear "Voice is", press ANNC/SKIP button or MEMO/REPEAT button to choose the language setting, press PLAY/STOP button to end programming.
Jan 24, 2011 | AT&T 1717 Digital Answering Machine
How to change from 7 ring answer to 4 ring
Press and hold SETUP button until device announces 'Voice is" then press SETUP button and release until device announces "Number of rings is". Press ANNC/SKIP button or MEMO/REPEAT button until device announces the the number of rings you want. Press PLAY/STOP to end.
Jan 24, 2011 | AT&T 1738 Digital Answering Machine
How do I program my answering machine--model # 1738? After the city was done working on the power lines, the answering machine no longer answers with a message. When one calls, all one hears is a soft...
To record a message,hold the ANNC button and follow the prompts.Yours also looks similar to mine.If there is a Clock button,hold it down to open the options menu.Use the button on each side of the bottom middle button to change the number.When that option is good,press the clock button again and change with the same buttons.When you get to the end,it should auto read everything you set.If anything is not as I mentioned,please comment here with all your button labels and I will reply ASAP.Greg
Jan 10, 2011 | AT&T 1738 Digital Answering System with...
Hazard lights won't turn off. Disconnected battery now hazards won't stop.
I see this is an old question, but I'll answer it because I ran into it myself - after hooking the battery up again, hold down the lock button on your little lock/unlock remote. If that doesn't work, hold down the unlock button. I always forget and end up doing one and then the other. In any case, it resets and the hazards should stop flashing!
Dec 22, 2010 | 1997 Subaru Outback
Number of Rings, I want to reduce the number of rings
Press and hold STOP/SET button for two seconds to access the set-up menu. Press STOP/SET to continue. Press STOP/SET over and over until the Machine says "Rings to Answer". To set the rings to answer just press NEXT or PREVIOUS to select how many rings you would like. Toll Saver option answers after 5 rings unless you already have a message, in that case it will answer after 2 rings. After you hear the option you like, Press STOP/SET button to store it. Now just press STOP/SET over and over until you get to the end of options, it should beep when you get there. Once you get to the end the machine will announce all the settings for review.
Aug 13, 2009 | GE 29878GE1 Digital Answering Machine
My samsung J700's buttons wont work
when i try to turn my phone on it only displays the make and model of the phone then switch off and on then repeat the same thing over and over again
Mar 09, 2009 | Samsung J700 Cellular Phone
Uniden cordless phone
I found that if I hold the "find hs" button on the BASE unit (right above the red charging light) for a few seconds, it works!! Thank goodness there is a solution! Thanks for the help.
Feb 07, 2008 | Uniden Cordless Phone
Won't go into pairing mode no matter how long I hold the answer/end button. Yes, I start with the device powered down, hold the a/e button, blue light flashes every few seconds but never goes solid. Any...
You need to turn it on so you get the intermittent flashing blue light then hold down the + button and answer button at the same time until you get a solid blue light. Then get your device to search for the headset etc......
Nov 27, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra bt160
hold the button down for a long time
Apr 17, 2007 | Jabra COMMUNICATIONS BT160 Bluetooth...
Sony Ericsson Walkman® W995 Cell Phone Logo
118 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
