Question about RCA D52W135D 52 in. TV/DVD Combo
Power problems Every time i push the power button whether it be on the remote or the unit itself a green light will turn on and then off 3 times yet the unit dose not start. Then i usually have to wait about 20seconds before the unit will read that i am pushing the power again and once again the green light will blink 3 times and then still no power... I usually have to repeat this process 3 or 4 times before the tv will get power and turn on. Can you help me?
  • 1 more comment
  • crazyguitarc Sep 03, 2009
    What can I do to fix this problem?
  • 63 Answers
You have bad capacitors in the power supply.
Posted on Sep 03, 2009
My Phillips 42PF7320/79 Flat Panel TV won't turn on, screen stays black but green pwr light is on, after a lil while the green light flashes a couple of times then goes off itself completely
This idea may be worth a try. Look at the buttons on your remote. If you see a button that is marked "TV" give that button a push and then give the "Power" button a push. Wait for a while! sometimes this takes a while to turn the TV on or off. You may have to do this a couple of times depending if the power was off or on when you started doing this. If you started with the set off, sometimes it takes a while for the set to turn on.
Jan 04, 2015 | Televison & Video
I have a Denon 1708 receiver. When I push the "on" button, either on the unit itself or using the remote, the light flashes green for a few seconds, then flashes red. When it turns red, all of the info...
Your result indicates the unit is not passing its power up self test. The first thing to try would be to remove all connections to the unit and try to power up. If it still mis-behaves, the unit has an internal problem best left to pros unless you're pretty good digging through circuitry. If it comes up stable, then reconnect things one at a time until the issue occurs again. Detach the offending connection and look for issues in the cables or the connected unit.
Oct 23, 2010 | Denon AVR-1708 Receiver
TV won't turn on...after hitting the power button, the light turn green for about 3 seconds, then turns red and the screen never come on. Pressing the power button again turns the whole thing off (no...
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 22, 2010 | NEC PlasmaSync 42MP2 42 in. Television
ViewSonic N3250w
The defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Turns OFF by itself.
Needs to be unplug to make it work.
Works for a few minutes then turns OFF.
I repair these power supplies, if you need further assistance jah2mil@hotmail.com
Aug 22, 2009 | ViewSonic N3250W Television
TV won't turn on even though it starts green, then goes off
Although my tv still does the "turn green and turn off" thing, I simply unplugged and repluggd the tv. After I did that, I pushed the "ON" button on the tv itself, unplugging and replugging the tv until it finally came on. I think the "instant warm-up" switch is going out.
Feb 18, 2009 | iLO 3200 32 in. LCD Television
S9000 canon printer ink tank full
Hi
Try this see if work for you.
may work
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 02, 2008 | Canon i950 InkJet Photo Printer
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
TV turns on at odd hours by itself
Hi, I had the "Ghost In The Machine". I tried out what I descibed in my original posting.
#1. I unplugged The Set.
#2. I pushed in and held in the power button in for about 5 minutes before bedtime. ( The PC trick I learned) I gave it 5 minutes because a tv set has much more power inside it.
#3. I again pushed in and held the power button in again for 3 minutes the next morning.
#4. I plugged the tv in again. The red standby light was lit. The set did not immeadiatly come on when I tried to power it up.
#5. 5 Minutes later I returned and hit the power button on the remote and it came on like nothing ever was wrong.
#6. It has been fine now for 3 days!!! Powers up when commanded and shuts down like normal. It has yet to come back on or act up as it was doing.
I will keep a watch on it and if it starts up acting again I will repost. I hope this information will be of use to anyone who experienced the same problem. It didn't cost a dime, just some patience. Thanks for a forum that people can exchange information and save trouble and money unless all options are exhausted. Bill
Mar 09, 2008 | Philips Magnavox 20MS3442 20" TV
Red then green blinking lights.
push power on at button (no need to hold button)and press proceed button for 2 secounds at the same time you turn on power and it should reset.
Dec 24, 2007 | NEC PlasmaSync 50MP1 50 in. Television
Power cuts out on PT-53WX42
unplug tv check the fuse and the rating on it,.see if filament inside is burnt
Oct 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
RCA D52W135D 52 in. TV/DVD Combo Logo
317 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
