Question about Kenmore Dryers
Gas clothes dryer starts to heat. gas shuts down minutes later, igniter restarts looks like working fine. gas will not restart. changed thermal sensor
  • Kenmore Master
  • 3,361 Answers
If the high limit thermostat is good,the gas valve coils need replacing.
Posted on Sep 03, 2009
I have a Gas Whirlpool dryer model GGQ9800PW3. The dryer stops before the cycle is complete. It can be restarted, but again it will work for a while then shut off. I changed the temp setting from med
Oh oh sorry to say this but sounds like the motor windings are going bad? does it shut off then about 30 to 60 minutes later u can start agin? a bad cycling thermostat or thermistor could be culprit but I doubt that in ur case.
Sep 27, 2014 | Dryers
Ignites on start up ,but after initial heat cycle will not ignite again until I shut down for a few minutes then restart.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 07, 2011 | Kenmore 75944 Gas Dryer
Maytag gas dryer, gas shuts off after the 1st heat cycle.
As long as your ignitor is heating up enogh. The most likely cause is the valves are not opening. you can usually get just the solenoids on the valve which is much cheaper than the whole valve and easier to replace. Please rate my response.
Dec 14, 2009 | Dishwashers
Heats and runs, but not long enough to dry clothes; then would not turn on and run at all. maybe dryer ''thinks'' clothes are dry?
Hi, After the dryer shuts off, can you restart it right away or does it need to cool down before restarting? If it needs to cool down for a bit, the motor is going bad. If the dryer is running a full cycle but not completely dry, check your venting to the outside and make sure it is clean.
If this is a gas dryer, the coils on top the gas valve might be shutting down early and not reopening later in the heat cycle.
I hope this gives you some direction. Please let me knwo if I can assist you further on this problem
Vic
Jun 13, 2009 | Dryers
My kemore dryer model 11071812001 not drying clothes
Sounds like the problem is the solenoid coils on your gas valve. easy to replace and inexpensive + common. their are 2 coils on the valve that have 2 wires each going to them. Let me know if you have any other questions,
Phil
Jun 10, 2009 | Kenmore 73952 Gas Dryer
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Location of the thermal fuse on the kenmore gas dryer 80
Feb 03, 2009 | Dryers
Maytag gas dryer fires, then shuts down
may be the coils on the gas valve. there are 2. usually they need replacing when the ignitor glows but no flame
Nov 20, 2008 | Maytag Dryers
Frigidaire AEQ8000 dryer doesn't completely dry clothes
1. Gas valve coilsIgniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Sep 15, 2008 | Frigidaire AEQ7000ES Dryer
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Dryers Logo
111 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
