Question about Homelite Mighty Lite Lawn Trimmer
It runs normally at high revs but dies on idle
    Champion:
  • 205 Answers
The units came out with EPA carb's some have idle screw adjustment and preset high jet, or the other way depending on the unit. try and change the fuel, use only high octane fuel for 2 cyc no ethanol with fresh oil mix, run for about 5 to 10 min's. if your carb has adjustment screws set your low side idle screw but still change the fuel.
Posted on Oct 13, 2009
Engin rev up and down what can iet be
check die idle beheerklep it foutiewe kan wees
check the idle control valve .it could be faulty
google translate
I have a spark in 2013 when my engine to shut it rev very high and therefore the revs back a bit or if I applied the brakes rev you very high
Oct 16, 2016 | Office Equipment & Supplies
What are the air and gas settings for a poulan micro XXV chain saw
adjust the L screw in fully till right in,then out 1.5 turns,same with H screw.Then start saw,adjust L screw in or out slowly till you get max revs.You may need to lower idle via idle screw if revs too high.When screw cant acheive better revs,reset idle.Then,rev saw to max revs,adjusting H screw to get max revs,then when max revs acheived,turn screw anti clockwise 1/4 turn out.That gives it enough petrol to cool the tip of the plug
Aug 12, 2014 | Garden
Poulan chainsaw, I rebuilt the carb with all new everything. Now it will start with choke all the way out. Idles really high. If I push choke in, it dies instantly. The hi-lo and Idle is off I know for...
get it running on idle,adjust the idle down till it runs hairy,then adjust low speed mixture screw till you get it highest revs,then keep repeating that till you get it idling normal.rev saw up max revs,adjust high speed jet, in or out till you get max revs,then screw out one quater of a turn.That lets enough fuel thru to cool the sparkplug tip..If thats no good,redo the carbi.Check the tiny filter under the needlevalve hole.Check the needlevalve diaphragm height.recheck gaskets are right way round
Nov 03, 2013 | Husqvarna Chain Saw 20" Bar
I have a Stihl 009 chain saw that I just rebuit the carb on and when it runs at high speed it does so only for a few seconds then dies. It will idle all day long. What could the problem be?
Have you replaced the fuel filter in the tank? it will idle as the engine is not calling for much fuel, however at full revs it calls for a greater amount of fuel, if that fuel is not available the saw dies.
Dec 29, 2012 | Garden
Atv hanging idle
check your float height? sounds like its high and runs normal when cold like the choke is on but when warm its getting too much fuel.
Apr 20, 2017 | Honda 2004 FourTrax Foreman ES
My 4 wheeler will idle, but dies when I give it gas
check to see if the choke is stuck or the carb could be dirty (gummed up)
Sep 05, 2010 | 2001 kawasaki KLX 300
Starts just fine but dies at idle. will keep running when stepp[ng on gas pedal
if the car runs fine at high revs, I suggest just turning the idle revs up 150ish, it could be a block cat converter, or restricted airflow making it die. but quick fix turn revs up 150rpm will do no harm and if it dies at higher revs, take it 2 the garage to see if they can find the thing.
Aug 15, 2010 | 2000 Toyota Camry
Does not idle and revs up and down and then it
You need to rebuild your carb. ----------------------------------------------------------------------------
Note: When you remove your idle/high speed jet screws be sure to count the turns...the ideal way is to count the turns when you bottom out the screws and the when you replace them, bottom them out and turn the screws to the same position before removal ----------------------------------------------------------------------------
The problem you described is normally caused by debris in the carb. While you have the carb apart, it would be wise to replace the diaphrams also, they will harden in time and cause hard starting and sporatic running I hope this helps, good luck Please rate me, Thanks
Dec 13, 2009 | Garden
Have 1987 nissan sentra wagon 1.6 carb.engine the problem is an idle problem when I start in the morning or when its had time to cool down I depress the accelorator pedel to set the choke and high idle cam...
Check your Ignition timing before anything
check your plugs see what color they are
red or orange means carb is to lean , black
or oil means to rich then you can go from there
and set mixture screws on carb , let me no how you make out .
Mar 09, 2009 | 1987 Nissan Sentra Wagon
Homelite Mighty Lite Lawn Trimmer  Logo
216 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
