GE GSH22JFR Side by Side Refrigerator
Problem for GE GSH22JFR Side by Side Refrigerator
How do you adjust the doors to closed completely?
By jeff_king on Sep 03, 2009
Door height and close adjustment?
Solution #1
posted on Sep 03, 2009
Somewhat Helpful)
woodchuck789
Rank: Guru  GE Refrigerators  Expert
Rating: 91%, 642 votes
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Was this helpful?
Yes
No
Solution #2
posted on Sep 07, 2009
Not Rated)
aasc
Rating: 94%, 637 votes
Loosen the top door hinge on the freezer door . Pull the top of the door as far to the left as possible ( with the door closed ) . Re tighten the hinge screws . On the fridge door , do it the same way , except pull the top of the door to the right . Also , there is a screw at the bottom hinge , which can be turned to raise the door to even level with the freezer door , to make them even in height .
Was this helpful?
Yes
No
Popular Solutions for GE GSH22JFR Side by Side
Questions and Unsolved Problems for GE GSH22JFR Side by Side
Do you recommend GE GSH22JFR Side by Side Refrigerator?
Answer
Answer
Hi: The door for the refrigerator model TFX24R do not stay closed. I need the PN for the magnet.... (More)
Answer
It is not cooling or freezing very well. We turned the numbers up pretty high. Can't find manual.... (More)
Answer
i dont have this exact model but somthing simular. The same problem is arising though my fridge wont... (More)
Answer
My 15 year old ge profile refrigerator door handles are worn to the under material. I want to paint... (More)
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in Newport, KY
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
