Question about Wolfgang Puck 781698 Indoor Grill
New new part for modelBRG 0010
I need to buy the plastic base for the reversible girll model BRGG 0010
This is the bottom base that holds the gease pan.
Where can I purchase this part?
  • GJAW Feb 11, 2008
    I need to buy the plastic tray that holds the grease pan.. where can I buy this part.. Gary
I have not been able to locate replacement parts either. I dropped mine from the top of my pantry. Only the handle of the griddle part broke, If you need the part, you can have mine as I am off to buy another.
Posted on Dec 30, 2007
I have a model RK 17 Cordless electric jug kettle from cuisinart that I just love because of the old fashioned design. I need a new base because a mouse decided to chew the cord and was incinerated.
Jul 18, 2012 | Cuisinart RK-17 Cordless Electric Kettle
Trigger on my dc07 does not open cylinder flap,what can i do
Hi Stephen,
This is a pretty uncommon problem and it is not terribly easy to fix. I suspect Dyson became aware of it and changed the mechanism as I have only seen this issue with Dyson DC07. Basically there is a long plastic rod from the trigger to the bottom flap when you pull on it the latch is released and the flap opens. Your plastic rod has most likely broken. The unfortunate thing is you cannot buy that rod you might have to buy the complete radix assembly. It normally happens that the bottom end breaks off when someone holds the base in place and pulls the trigger.
If this is the case then you may be able to super carefully glue the pieces back together. Watch the video I linked below it shows how to get the radix apart. The tricky part for you is that you will then need to insert a coat hanger or some other slim long thing into the centre and manually push the release which is right at the base of the radix in the middle this will release the flap.
From there see if you can find the broken bit and repair the pieces. Super glue wont hold, you will need araldite or some other super strong compound.
Of course if this sounds like too much trouble just buy a new radix.
May 24, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Im have problem whit front weel..where im finding replasming kit?
You need an axle kit and cone wrenches plus good bicycle gease. Depending on what type of wheel, sometimes it is almost as cheap to buy a new one.
Oct 01, 2010 | Cycling
Agitator not moving--seems loose
This washer has what we call a bionic agitator and this agitator has a 2 parts:
it has a base and a top section.
IF the BASE IS NOT WORKING AT ALL, please have the transimssion checked and also check the coupling.
IF the BASE is working and the top is NOT
THEN replace the 4 plastic AGITATOR DOGS that are in the agitator.
Remove the CAP from the agitator...remove any plastic cap.
Get a socket wrench and get the socket that removes the bolt.
remove bolt...
PULL the agitator from the base and separate the top from the bottom.
Take the top and turn it upside down to remove the platic interior part that holds these 4 dogs. REMOVE the old dos and replace with new and do a reverse engineeriong putting agitator back.
Nov 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
How to change the battery in a 2000 venture
1. Remove the rubber hood gasket at the base of the windshield along the car-right side by pulling up on it
2. Pull up and remove the triangular plastic shield in the car-right rear corner of the engine compartment
3. Remove the rear bolt on the large diagonal bar holding the fuse box
4. remove the two front bolts on that diagonal bar, and the other nearby car-right bolt holding the front of the plastic shield to the front rail
5. Pull up and right on the large bar and fuse box to position it out of the way to expose the battery
6. remove the bolt and spacer at the rear lower base of the battery
7. first remove the negative battery cable (8mm), then the positive cable
8. pull the battery out
9. swap the thermal cover onto the new battery, remove protective terminal caps (if there), and reverse the procedure to reinstall the new battery. Always install the positive cable before the negative to avoid welding your wrench to the car.
Nov 06, 2009 | 2001 Chevrolet Venture
Moen single lever kitchen faucet leaking at base and through spray. Can it be fixed? I lost my installation manual. Are there any online?
base leak is from bad o ring or loose spout very easy fix you can get a washer kit at lowes all you need is a allen wrench(sometimes comes in kit) a pair of channel lock pliers
May 09, 2009 | Moen 7840 Camerist Single-Handle Kitchen...
Need to replace the passenger side mirror,glass only. does anybody know if the plastic backing plate the mirror is attached to pops out of the holder? If it does, it would make it easier to fit the new...
Just replaced the mirror glass myself. Don't have all the answers but can tell you this much.
The passenger side mirror on my 2004 Odyssey was hit by a projectile which caromed off the upper door frame. Left standing was a functional mirror base (motor driven part which has four, short, horizontally mounted rods) still attached to the mirror shroud and a separate assembly of the mirror glass and plastic mount.
I purchased the mirror glass alone online from a Honda dealer, removed the old mirror glass from the mount, and mounted the new mirror to the mount. To do this, look at the tabs which hold the mirror to the mount, and slide the mirror across the mount in the obvious direction. It will take some force. I had the benefit of having the mount/mirror glass blown out of the mirror shroud so it wasn't too difficult. If the broken mirror is still mounted to the mount and inside the shroud, push the bottom of the mirror inward so the top edge of the mirror can clear the top of the shroud. Then pull up on the mirror glass to slide it off the mount. This will take some force but fortunately, the mirror glass is already broken so you don't have to be gentle. Wear gloves or protect you hands while doing this.
Reverse the process for install the new mirror glass.
Now for my key tip. I had to remount the plastic mount/mirror glass assembly onto the motorized mirror base. I could see that it snapped in, with proper alignment, by pushing straight in. I applied quite a bit of force and simply could not get it to snap in place. My solution, was to put the assembly in a 200F oven for 15 minutes to heat the plastic to make it more flexible. Using paper towels to handle to avoid burns, I aligned the closures with the four, small, horizontally mounted rods, and with a moderate amount of force, the assembly snapped into place.
Hope this makes sense. I believe most people will only have broken mirror glass and not have the plastic mount with mirror glass come off the motorized base as I did.
Apr 19, 2009 | 2004 Honda Odyssey
Powermate plastic bottom broke
Go to, click on parts, the part you need is:
BASE-NOZLE 8191779 (4370725) 11650812007 $ 33.09 $ 33.09
You can order it thru sears online. Cost is $33.09, plus tax and shipping.
Dec 31, 2007 | Kenmore 23612 Progressive PowerMate Bagged...
Broken gear on BFP-703 base
The drive is replacable and available from Cuisinart, you will have to sign a waver to get the part. the drive is screwed onto the motor shaft with reverse threads. the plastic drive will have to be completely broken off of the unit to expose a brass"nut" which was internal to the drive. depending upon your model you may have to remove the lower half of the base unit to access the lower part of the motor shaft. there will be a slot in the end of the shaft for a large flat blade screwdriver. this is used to hold the shaft still while turning the drive "nut" with a vice grip pliar or similar. the new drive is just threaded onto the shaft and normal operation tightens it.
Feb 14, 2007 | Cuisinart BFP-703 Blender
Wolfgang Puck 781698 Indoor Grill Logo
366 people viewed this question
Top Wolfgang Puck Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Wolfgang Puck Kitchen Appliances - Other Expert? Answer questions, earn points and help others
