Question about Lightning Audio b2.250.1 Car Audio Amplifier
R262 burn the r262 burn don't see the colors
  • elmunra Dec 07, 2007
    thanks i will check the other components
  • 631 Answers
R262 is a 51 ohm resistor. If it burned, there's a really good chance that other components are also defective.
Posted on Dec 07, 2007
2007 BMW 328i IAT Wire Colors in MAF Sensor
If you are installing a so called "chip" don't do it, it can harm the engine due the changes it causes in fuel control as related to Intake Air Temperature and burn holes in the pistons. All that little part really is, is a $.50 (50 cent) resistor that you can buy from Radio Shack, it is smoke and mirrors and it also will void any warranty you may have. I for one strongly advise against installing it, it will make not difference in power and all there claims are just lies and falsehoods..
Jun 08, 2012 | BMW Cars & Trucks
How do you fix the color to a model 43fdx11b hitachi
Hello!you mean: colors out of convergence? nothing you can do about that, unless you replace 2 convergence amplifiers I.C. chips, plus all those burned 1 watt low ohms resistors with exact values, which only could be obtained via service manual or schematics. After resistor is burned, there is no way to read color code properly, due to partial evaporation of pigments. this is a "pro" job. If you try or tried, already to converge those "stubborn" crosses, there is more to do, even after you removed and replaced two 20 pin I.C. chips, soldered dead into sweep module, plus located and replaced resistors with precise values, you need to get your settings back to normal, by going into "factory service mode' or, at least into "convergence alignment" menu and fight with those crosses!Don't forget the white "****"! Otherwise, you will be re-servicing your set all over after 30 days of usage.good luck,Alex.
Feb 01, 2012 | Hitachi Televison & Video
The picture has a green tint to it.
If the green is all dominating then it is the red or yellow that is missing in the spectrum. The likely problem is that one of your color guns has burned out. good news is they can be replaced but you have to determine if you have three individual color guns, or one that projects all three colors. (don't skip the easy analysis first though) Check your cables to make sure they are not worn, cut, nicked and most certainly check to see that they are plugged all the way in. Try jiggling the red and yellow inputs while someone watches the screen to see if it flickers. If it does you could just need a new cable. Swapping it out with a known working cable also will work for testing.
Jun 16, 2011 | Hitachi 53UDX10B 53" Rear Projection...
The electrical windows were not working this morning. Did a fue burn out? If so, what color & identification number is the fuse? I don't have a car manual.
How would someone on the internet know all that
You need an owners manual if you own a vehicle
Look up the fuses & check them,then ask your
questions & provide technical info
Without the car all we can do is guess
Jun 07, 2011 | 1998 Ford Taurus
I change my furnace filters once a month and lately I have noticed that the filters are black in color. It is not just dust as it would be when normally change them, just recently they are sewity. I rub my...
I have only seen this happen from two things. One is from burning candles in the house and the other is from a cracked heat exchanger. If you burn candles there is no emergency, however if you don`t, you need you furnace inspected ASAP by a qualified HVAC person. A cracked heat exchanger can emit carbon monoxide gas into the house which is poison, has no color and no smell. A sign of carbon monoxide in the house is headaches and sick to the stomach. If you have had these symptoms get out of the house and get the furnace checked.
Feb 01, 2011 | Heating & Cooling
Well i don,t know what i did but there appeared light color of light black back ground i can not remove this background picture how do i shut it of thank you.
U turn to another channel,now it look like u have a picture of a shadow behind it?Yes,than u have freeze a picture on the tv for a long,might have a tv screen burn in.Tries go into tv menu go to colors setting.Tries contrast setting all the way up to maximum.Tries colors a third of a setting.The brightness half of it setting.Should or might help to solved this problems.
Dec 06, 2010 | JVC AV-32D305 32" TV
My TV shows the picture in green. I had it for about 3 years. What can be done about it?
If its a LCD projection TV (such as Sony Wega, Hitachi, Epson, Philips, and some Panasonic, some Mitsubishi), and the green image is in the whole screen or just one part as a blob. Is most probably that one of your LCD Color Filters is damaged (burned out or starting to get busted), I don’t know if you can just replace the color filter, I believe you need to change the whole light engine system or the optical block. There are some places around, I found some on ebay but you should definitely try on discountdashmerchantdotcom their price range $260.00 - $330.00
Jun 24, 2009 | Insignia NS-24 TV TV
GE D52GW12 52 how can i fix color burn help me out
Color burn. i assume u are talking about crt burn. spots in picture. i know of only one solution that is to replace the tube or tubes that are burnt
Jan 17, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Lightning Audio b2.250.1 Car Audio Amplifier Logo
Top Lightning Audio Car Audio & Video Experts
80stech
Richard Lukszys
Richard Lukszys
jason
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
