Question about Saeco Incanto Rondo Fully Automatic Coffee Maker Black Espresso Machine
New boiler and o-rings
I have a saeco magic and it is not producing very much coffee, but the water tray is full, so I am guessing that the boiler and o rings have  a leak. Where can I get new parts that I can install. I live in Montana in a very rural area and there are no techinicans close. Thanks
  • hansvdm Oct 18, 2008
    the o-ring of my boiler are dripping too.
    Spidem Trevi Digital where can i get a new O-ring
The O-ring on the plastic pipe into the boiler deteriorates due to the high heat attained by the boiler. The O-ring can be replaced with a : #61 O-ring from Ace Hardware. STK No. 35775B Size 9/32 x 5/32 x 1/16
You will need 2.
I just finished the same repair and the leak is gone.
1. Remove 2 screws under the front lid and 2. Remove  2 torque head screws under the water reservoir.  The plastic head on the steam spigot needs to be removed.    - Twist the plastic nut at the top and slide the assembly off the tube.       Note the order of parts for reassembly. 3. Lift the cover assembly off. 4. Remove the spring clip from the nut on the plastic tube into the boiler. 5. Pull out the plastic tube. 6. To properly clean out the old O-ring, Remove the nut from the boiler. 7. Reassemble the nut to the boiler using teflon plumbing tape. 8. Slide the 2 O-rings onto the plastic tube.  9. Give the O-rings a light coating of vaseline and insert into the nut. 10. Slide in the retaining ring.      This will require that the brass ring on the plastic tube be pressed firmly into the nut. a small         screw driver seems to work well. 11. Reassemble cover.
This repair is valid for the Saeco Magic automatic coffee maker.
Posted on Oct 20, 2008
  • 515 Answers
Do you have any type number on the machine?
Posted on Jul 30, 2008
Saeco Intuita adjust water volume
Press and hold the coffee button the entire time until the cup gets to the length that you prefer, then let go. That will program the cup to that length.
Saeco Parts
Saeco Espresso Parts Brew Groups Pumps Boilers Water Tanks Drip trays
Sep 14, 2013 | Saeco Magic De Luxe Espresso Machine
Coffee doesnt flow but water gathers in the drip pan instead.
Hi Your problem is probably the boiler leaking. Its located just above the drip tray in the center of the machine. When it starts leaking it goes into the drip tray or on the counter top. If you can remove the top, you can see if the boiler is leaking. There will be a white line between the 2 halves of the boiler.
Feb 09, 2010 | Saeco Magic De Luxe Espresso Machine
Coffee is not dispensing during brewing, water dispenses in the tray
There is a lot of things that can cause that. The first place I would look is the injector behind the brew unit. Remove the brew unit. The injector is the finger with the 2 orange O-rings on it. If it is loose it will not go through the brew unit, just into the tray.
If the boiler is leaking it will go into the tray and under the machine. Any other leak would be coffee going into the tray.
Jan 09, 2010 | Saeco Magic De Luxe Espresso Machine
Boiler not keeping pressure
mostly your boiler gasket is gone, or a line has blown might be lucky with a leaky o-ring
Dec 03, 2009 | Saeco Magic De Luxe Espresso Machine
Temperature control on Saeco magic deluxe
No it cannot. I am not sure why you would want the water hotter. It is designed to be at the perect temperature for passing through the brew group for coffee brewing, its kind of a simple science.
If your machine has been producing less hot coffee gradually, that marks an issue. Try descaling the boiler per the manufacturer's inscrutions even if the warning light isnt on. The other option is that the thermal fuse mounted to the boiler is bad and turns off the boiler prematurely, those cost about $15 and are simple to replace. Lastly, the boiler heating element may be 'burnt out' new boiler is $120+
Aug 15, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco magic deluxe is leaking water
Either two faults, one is that the boiler is leaking ( fix this straight away as water can spray on main circuit board and short out ) very costly to repair if both needs replacing. Second the water runoff to the front tray is blocked with coffee grime . Instead of the water left over when the brewer dissengages running off to the front tray it overflows into the machine. Hope this helps
Aug 10, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe - Coffee Cold,Lights not working
The thermoblock (boiler) element is burnt out and must be replaced.
Feb 10, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco magic deluxe - no water flow
How old is your machine?
Do you descale it regulary?
I think it´s your boiler that has to be replaced
Aug 05, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic de luxe SUP 012
open the machine up and follow the line from the spout (which should give the coffee) till the boiler. The spout most likely is clogged.
Follow THIS LINK for parts etc,
Jun 01, 2008 | Saeco Magic De Luxe Espresso Machine
Water leaking into machine
This happens when the boiler develops a leak, usually due to scale buildup. Order a new boiler and o-rings and replace.
Sep 29, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Incanto Rondo Fully Automatic Coffee Maker Black Espresso Machine Logo
339 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
