Question about Acer Aspire 3000 Notebook
Virtual memory it says its low so can i get help with that
  • 34 Answers
Yes upgrading your ram (random access memory) helps alot
also incressing your virtual memory paging file might work if it is set 2 low.
Windows XP loadTOCNode(2, 'resolution'); 1. Click Start, right-click My Computer, and then click Properties. 2. In the System Properties dialog box, click the Advanced tab. 3. In the Performance pane, click Settings. 4. In the Performance Options dialog box, click the Advanced tab. 5. In the Virtual memory pane, click Change. 6. Change the Initial size value and the Maximum size value to a higher value, click Set, and then click OK. 7. Click OK to close the Performance Options dialog box, and then click OK to close the System Properties dialog box.
Posted on Dec 07, 2007
3 Suggested Answers
zohail
  • 1223 Answers
SOURCE: low virtual memory
wgich windows XP or Vista tell so i can tell u in detail
Posted on Mar 04, 2009
  • 3940 Answers
SOURCE: dell inspiron me051 virtual memory low message
Adding RAM will help. but normally virtual memory errors occur when the hard drive is nearly full and the system doesn't have room to write to the swapfile as much as the system wants to write.
To run optimally, the system should have at least 10% of the HDD free for WIndows use.
Posted on Jan 12, 2010
System says low on virtual memory even after I zero & format the hard drive with new operating installed?
this is virus instaled on computer bios or defective memory boards.
1st replace memory, and check-it.
2nd find a original bios on IBM website, and flash-it.
Nov 22, 2009 | IBM NetVista PC Desktop
Tip
Virtual Memory too low Warning Trouble in win xp and vista
When there is less physical memory than needed, then some virtual memory (virtual RAM) is created on the disk. When there is a limit set to the size of virtual memory usage and there is not enough of it present there is a warning that frequently comes "Virtual Memory too low". Solution 1 : This problem occurs when physical RAM + Virtual RAM (usually created on hard disk) together are not sufficient to take care of the currently needed RAM size, or this situation is about to arise. This usually happens when some fixed upper limit for Virtual Memory has been set. To solve this problem, you can either upgrade you physical RAM on your computer (recommended), or you can set the Virtual Memory to system managed size or you can do both. Setting Virtual Memory to system managed size means windows will set it to higher size whenever needed automatically,for this, <br /> Right click on My computer --&gt; goto properties, goto advanced tab, click on performance settings, now click on advanced, now click on advanced, now click on change button for Virtual memory. <br /> On this screen select the System managed size, press OK. After this re-start your computer. This will solve the virtual memory too low problem. Solution 2: Recommended solution is to upgrade your physical memory (RAM) according to requirements of the kind of applications that you run on your computer. If you upgrade RAM or not, the following procedure will help prevent this warning by increasing the virtual memory limit. <br /> Right click on My computer icon and click properties. <br /> This will show system properties window. Click on a advanced tab and click on the settings button under heading performance. This will open performance options window. Click on advanced tab and click on change button under heading virtual memory. Check if the space available is set to some custom value or double the RAM size ? If it is not double the RAM memory size , then select the size option set the virtual memory size double the RAM Size and press set button and press OK button. Restart the computer
on Apr 04, 2011 | Computers & Internet
Tip
Solution to Virtual Memory Too Low Problem
This problem was reported by one of our readers that in spite of having a sufficient amount of RAM, he is running out of Virtual Memory and his Windows PC gives the following error:
Your system is low on virtual memory. To ensure that Windows runs properly, increase the size of your virtual memory paging file. For more information, see Help.
This is a common problem and you may have seen it if you are trying to open many heavy applications at the same time like Microsoft Office.
Let’s see what the causes are and what can be done at this stage.
Windows XP or Vista uses the concept of Virtual Memory that aims at providing the additional memory from the Hard Disk if most of the RAM of the computer is already occupied. This memory used from the Hard Disks is called Paging File. Windows reserve some part of the memory for this purpose only (this is one of the reasons why we see less memory than specified on the hard disk).
Virtual Memory also known as Page File or Swap File can be located at C:\pagefile.sys (it is system hidden and can be viewed if you Uncheck the option of “Hide Protected Operating System Files” inside Folder Options).
on Nov 17, 2008 | Microsoft Windows XP Professional With...
Windows XP Virtual Memory is low. How can I regain memory?
Virtual memory is "memory" on your hard drive, not actual memory. The best way to regain this is reboot and shut down some of the stuff that runs automatically when you DO boot up.
(This Virtual memory is space set aside on your hard drive that the processor moves data into and out of like it would put data on a memory module ... but in comparing the two, the virtual memory is SLOW.)
You can increase the size of your virtual memory to anything you want. Some say too large a allocation will slow you down and too little will cause crashing or slow opertion. You are 99.44% probably set to let Windows manage your virtual memory (default) at this time.
thanks for posting your question to FixYa.com
positive comments are welcome
a
Nov 02, 2009 | Gateway Essential 500 PC Desktop
Virtual memory is low computer is very slow
hello frnd, you can increse your virtual memory manually...
1.go to properties of my computer
2.go to advance tab...
3. there is option to change virtual memory.
4.click on it and change virtual memory accordingly..
hope this will help you
Jun 30, 2009 | Dell Dimension 2400 PC Desktop
Low virtual memory
You have to increase the Virtual memory.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Dell Inspiron 1300 Notebook
Windows Virtual Memory Minimum is Low
fairly normal occurrence but you should have a look at your performance settings
go to control panel
double click system icon
click the advanced tab at the top
by performance click settings
in pop up window click advanced tab
at the bottom you'll see virtual memory
click change
most common option now is to set the radio button to system managed size
you should then ok each window.....
Dec 30, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Virtual memory
You have to set your system to control the virtual memory....
In the Virtual Memory settings you have 3 options:
1- personalized size
2- size managed by the system
3- without pagefile
Select and set the second Option....apply and click in Ok....
Good Luck!
Dec 09, 2008 | Toshiba Satellite M105-S1021 Notebook
Temporary Internet Files
Temporary internet files could harm your pc if the files contents virus, this could also slow your pc because if you have files that was infected with virus specifically the application files. Those files were automatically load into the services and in the processes and also in the start up without your consent. If all these files will run in the system this will cause " a low virtual memory" because the memory speicified was use by these useless and annoying application.
If you encounter these problem i would suggest that scan you computer with a potent antivirus, you should empty the temporary files and the recycled bin.
If you are sure that the computer is virus free and still encountering the "low virtual memory" you can increase your virtual memory by doing these:
1 right click my computer and then properties
2. click the advance tab
3. in the performance., click setting
4. then " advance tab"
5. in the virtual memory click change
6. check custom setting
7. in the initial size double the size of your memory
7. maximum double the initial size you setted.
If these will not solve the problem i would recommend you to format and reinstall your system.
Hope this help
Jan 22, 2008 | Computers & Internet
Acer Aspire 3000 Notebook Logo
166 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
