Question about RCA 27F530T 27" TV
Cant read espn scores
How do I expand this TV to fit better into screen so I can see the updates on espn. It cuts off half of the scores
  • Anonymous Dec 17, 2007
    the vertical length is to long...cant read anything at the bottom can see the top of things but dont have a clue how to fix it...
    Problem Solver:
  • 7 Answers
Your need to check the picture mode as it sounds like it is zoomed in or stretched. Go to the settings options on either your TV remote or sometimes your cable/satellite box as well. You'll see settings such as Zoom, Stretch, normal, Movie etc. Just select whatever works best for what you watch.
Posted on Dec 27, 2014
Same problem...screen seems to be to long. i cannot see all objects on bottom...no solution in the menu...help plz
Posted on Dec 17, 2007
Watching espn hd, the picture cuts off on one side. How do I adjust this? The ESPN bug is well within the border in the right hand lower corner, but a chart that comes on perodically during play...
There's a resolution/aspect ratio you can adjust in the picture menu, or straight from the remote. Choose the size you want on ESPN that best fits the picture while watching it.
Jun 16, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
I cant get the whole picture to fit the screen. When I watch games the score is cut off.
This is most likely a setting on your TV, like stretch, or fit, or possibly on your cable box, or dish receiver. look at your dish or cable box settings and turn off any screen adjustments. Example under wide screen setting is strech , zoom, letterbox (choose letterbox).
The TV has these settings as well.
Aug 24, 2009 | Samsung LN46B650 46/49.5 in. LCD HDTV
Picture is too big for the screen
go to page 37 of the manual and read through to RESET TO FACTORY SETTINGS
Thanks for using FIXYA
May 30, 2009 | Syntax Olevia 532H 32 in. LCD HDTV
The whole picture doesn't fit in the screen.
If u are using a cable box there maybe a format button on that as well. So use it in conjunction with your tv format button to get a picture that fits the screen. Make sure no zoom format is selected
Apr 09, 2009 | Televison & Video
Toshiba tv model 57HC85
Go to settings and change to 16.9 widescreen
If you use 4:3 or zoom or fit or anything else, it will do that...use 16:9 or "regular".
Jan 31, 2018 | Toshiba Televison & Video
Unable to see scores
you have to hit aspect on the remote until it fits the screen right
Jan 14, 2008 | Hitachi 51G500 51" Rear Projection...
Picture size won't fit screen. Can't see scrolling text at bottom (e.g. sports scores on ESPN)
hi there,
its probably not the tv but the set top box you need to fix. go to the settings and select the mode you want ie. widescreen 16:9 etc
then go to the tv and select the full mode or widescreen mode at 16:9
that should solve your problem. it takes some time to find the combination between the set top box and the tv to get it right
good luck
smeags
Dec 30, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Image size too large, cannot see all of sports scores scrolling on the bottom
hey voiolentce. if you press the # button on the cablebox remote control you can fine tune the zoom by those 20 pixels you want. you are most likely set at zoom 1 currently. thats where i was when i had this same problem and it took me days to figure out that all i needed to do was press the damn # button. i couldnt see any of the scores on espn sports games and its been driving me crazy. hope this helps!
Sep 10, 2007 | RCA R52WM24 52" HDTV Projection Television
Bottom of picture is cut off
Usually when the vertical starts shrinking slowly, it is due to capicators getting out of tolerance in the vertical output section of the chassis. If it can be adjusted out through a service menu, you'll probably need a tech with the right equipment to perform it.
Jan 01, 2007 | RCA F27440 27" TV
RCA 27F530T 27" TV Logo
281 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
