Question about Canon imageCLASS D661 Digital Printer
Image classD661 blank copy
I put original face down on glass, copy comes out blank.
If you just changed the toner cartridge, you probably forgot to remove the metal foil seal, from the side of the new toner cartridge.
Posted on Jan 15, 2008
KHOW DO I GET THE PRINTER TO MAKE A COPY OF SOMETHING
No make/model, so here's a generic method:
[based on Samsung Multi-function]
Presuming printer is a MF unit:
Place paper-to-copy face down on the flatbed glass.
Close lid.
Ensure blank paper is correctly loaded in feeder tray.
For a once-off direct 'photocopy':
Press COPY on printer .
For copying (scanning) to a file:
Printer on, drivers installed, blank paper loaded, original on flatbed.
At computer, go to Start.
In search-box type in scan
Left-click magnifying glass to confirm search.
You should see Scan a document or picture appear in icon list.
Click this.
A scanning window should pop up:
Oct 11, 2017 | The Office Equipment & Supplies
How to use the Copier only, instructions please?
copy machines work by running a light along under the glass
anything on the paper is reflected and the image is captured for reproduction
so place the printed surface face down on the glass
Aug 30, 2015 | Canon PIXMA Office Equipment & Supplies
I have a Ricoh Aficio 1013 that prints fine but copies are unclear and off
Problem Cause Solution Colored lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About this Machine . Copies appear dirty. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies appear dirty. Auto Image Density is not selected. On the control panel, select [Auto Density]. The reverse side of an original image is copied. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . The reverse side of an original image is copied. Auto Image Density is not selected. On the control panel, select [Auto Density]. A shadow appears on copies if you use pasted originals. Image density is too high.
  • Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference .
  • Change the orientation of the original.
  • Put mending tape on the pasted part.
The same copy area is dirty whenever making copies. The exposure glass, scanning glass, or ADF is dirty. Clean them. See "Maintaining Your Machine", About This Machine . The same copy area is dirty whenever making copies.
  • The original that has already been printed is scanned.
  • Original Type is set to [Text / Photo], and an original with text and photographs that can hardly be distinguished from each other is loaded.
On the control panel, press [Generation Copy], and then begin copying. Copies are too light. Image density is too light. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies are too light. A light copy may result when you use damp or rough grain paper. Use recommended paper only and be sure its storage environment meets the recommended temperature and humidity conditions. For details about recommended paper and the proper way to store it, see "Recommended Paper Sizes and Types" and "Paper Storage", About This Machine . Parts of images are not copied. The original is not set correctly. Set originals correctly. See "Placing Originals", Copy and Document Server Reference . Parts of images are not copied. The correct paper size is not selected. Select the proper paper size. Parts of images are not copied. Even if you place originals in the ADF correctly, margin of a few millimeters on all four sides of the original might not be copied. Use "Create Margin" function to reduce the image of its original size.
For details about missing image area, see "Missing Image Area", Copy and Document Server Reference . images appear only partially. The paper is damp. Use paper that has been stored in the recommended temperature and humidity condition. For details about the proper way to store it, see "Paper Storage", About This Machine . Black lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The dustproof glass is dirty. Clean the dustproof glass. See "Cleaning the Dustproof Glass", About This Machine . Copies are blank. The original is not set correctly. When using the exposure glass, face the originals down. When using the ADF, face them up. A moir? pattern is produced on copies. Your original has a dot pattern image or many lines. Place the original on the exposure glass at a slight angle. Black spots appear on the copy of a photographic print. Because of high humidity, the photographic print has stuck to the exposure glass. Place the print on the exposure glass in either of the following ways:
  • Place an OHP transparency on the exposure glass, and then place the print on the OHP transparency.
  • Place the print on the exposure glass, and then place two or three sheets of white paper on it. Leave the ADF open when copying.
White stripes appear on the OHP. Fragments of paper are stuck to the OHP. Use a dry cloth to wipe any paper fragments off the back of the OHP. The image on the back side of duplex copies has mottled blank patches or is smudged. Missing patches and smudges are caused by moisture leaking from the paper.
  • Do not install the machine in areas that are susceptible to low temperatures.
  • Use paper that has been stored where temperature and humidity conditions meet the limitations we recommend. For details about the paper storage conditions we recommend, see "Paper Storage", About This Machine .
  • Install the Optional anti-humidity heater. For details about the anti-humidity heater, contact your service representative.
When You Cannot Make Clear Copies
Feb 02, 2018 | Ricoh Aficio 1013 All-In-One Laser Printer
Can print from computer but page comes out blank when trying to copy a document placed on the glass
In order to copy a document correctly, the document must be facing down onto the glass (text or images facing down), and oriented so that the (typically) top-right corner matches with the triangle next to the glass. Close the lid, then press 'Resume' or one of the buttons labeled 'Start Copy'. This should allow the printer to correctly copy the document.
Thank you for using FixYa! If you require additional assistance, feel free to reply to this solution, and I'll be glad to help you further.
Mar 28, 2011 | HP PSC 2210 All-In-One InkJet Printer
Do I load the original for faxing right side up or upside down? HP officejet v40
Look at the input tray it shows a symbol of an original.
If the lines on the symbol face you , then put the paper in face UP.
If the lines are on the folded corner of the symbol, then place the paper in face DOWN.
If you are still not sure, place the paper in face UP and press "COPY"
If it copies the page, then that is the correct orientation.
If thre copy is blank, repeat the copy test with the document face DOWN.
Sep 28, 2009 | HP Office Equipment & Supplies
Faxing
if using the feeder probably face up as it will likely pull the document in and invert it to lay face down on the scanning glass.
if you lift up the feeder (like lifting the top of a copy machine), then it would be face down on the glass.
there should be an image on the feeder illustrating how the document should be placed - if it looks like a page with lines on it with a bent corner then it is face up.
Apr 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
How do I stop a black line appearing on the copy of an original document
Try this- Make sure the whole glass area of the copier is covered with white paper,
ie. lay the document face down, and any glass area you can still see- cover with sheets of blank white paper
Good luck
Nov 26, 2008 | HP Office Equipment & Supplies
Blank printing
Make sure the original is face down on the platen (glass copy surface).
or u might download its manual from :
http://www.sharpusa.com/files/cop_man_AR5316.pdf
Nov 12, 2008 | Sharp AR-5316 Advanced Digital Imager...
Xerox workcenter XD120f
The small scanner glass (not the full size glass) has some dirt on it. Use a lint-free cloth (not paper) with alcohol or Windex and clean the glass. This should help.
Nov 14, 2006 | Xerox WorkCentre XD120f Copier
Canon imageCLASS D661 Digital Printer Logo
54 people viewed this question
old marine
old marine
