You have a circuit " vertical " with a problem maybe the ic trouble , a capacitor or a voltage if you are not able to repair it you must call a repairman
Samsunghttps://www.samsung.com > ... > TV & AV
Apr 13, 2023 - Troubleshooting. 1 Check whether the lines on the screen are moving or permanent. 2 If the lines sway, check the input source (HDMI 1, Video, ...
Make a fist with ur hand and bang on the tv bazel frame.The tv picture flickers back or bounces back to a normal picture.The tv have a vertical or a horizontal hold ics have coldsoldering joints and requiring resoldering.If u bang on the tv bazel frame picture don't flickers back or bounces back to a normal picture.The tv have a vertical or a horizontal hold ics are dead require changes those ics chips.If u don't have all the tools.Can't do a basic soldering work or able to changes those ics chips.Shop around for tv shops for estamate and repairing prices for repairing.
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alingments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK comvergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost like $300-350 for parts and labors.
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
it could be an electrolytic capacitor or the vertical output I.C. in the vertical circuitry,if you remove the rear cover tap on the board in different places and see if the picture fills out or atleast jitters like it might fill out,then it could be just a cold solder joint,then remove the main board and resolder all joints and this should repair the condition you have
Hi, I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen. Let me now are you tech guy or know how to repair TV to guide you further.
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines.
good luck.
