Question about Motorola Mobility H350 Wireless Headset
There is a long continous beeping noise on the recepiant's end of the call when i use my headset.
The person on the receiving end complains there is a constant beep or schreeching noise when i use the headset.
  • Anonymous Feb 29, 2008
    I have the same problem with the beeping noise. I hear fine but the person I'm talking to via my H350 hears a continuous beeping. Any suggestions?
Fix it or people will get angry
Posted on Feb 22, 2008
Are you are you around a computer or radio/stereo when they are hearing the noise?
Posted on Dec 31, 2007
X6dh8-g2+ no video continous beep
Hello here is the homepage:
http://www.supermicro.com/products/motherboard/xeon800/E7520/X6DH8-G2.cfm
Try to boot with only one stick of ram at the time, to find the failing ram module.
This is usually caused by a problem with the system memory, or possibly the video card. The memory is more likely--the system complains long and loud sound, if it can't find any usable memory, as there is no way to even start the boot process when this is the case. The motherboard itself could also be the problem.
The mainboard is useing Up to 16GB DDR2 RAM.
Try not to buy cheap ram, they are always failing.
Good luck
Feb 21, 2013 | SuperMicro Computers & Internet
We are using the Plantronics CS55 wireless headsets. The users are complaining that the '3-beep' incoming call alert tones are too loud. We have tried to adjust this tone level by manipulating...
Lowering the ring volume on the phone only decreases the sensitivity of the lifter, which generates the signal to the headset. The signal volume between the two is preset and cannot be adjusted.
Good luck from Headsets Direct!
Jul 20, 2011 | Plantronics CS55 Wireless Headset
Cannot hear phone ringing in headset, only on handset.
The HL10 handset lifer is what notifies your headset that you have an incoming call. If you are using the handset lifter and are not receiving the 3 short beeps in your ear piece there are a couple different things that could be going on.
1. The internal microphone could have gone out on the lifter. This microphone is what sends the signal to your headset that you have an incoming call. If the microphone is working you will hear 3 short beeps in your headset.
2. If the volume is too low on your telephone, the handset lifter will not notify the headset of an incoming call, so try turning the volume up on your phone and see if that takes care of the problem.
3. The HL10 handset lifter ships with a ring detector that has a 2.5mm jack on one end and a small round microphone on the other end. This ring detector is intended for phones that do not have the speaker located under the handset. You could try plugging this into the back of the lifter and setting the microphone next to where the lifter is mounted on your phone. This might help pick up the sound of the phones ring tone.
If you are manually lifting your handset out of the cradle and sitting it to the side instead of using a lifter, then you will not receive the 3 short beeps in your earpiece to notify you of an incoming call.
Nov 03, 2010 | Plantronics Voyager 500A Deskphone Adapter...
My samsung e250 has a problem. everytime i use the the headset theres no sounds coming from the headset, theres a continous beep in the phone whenver i attache d the headset
Did u try to change a new headset? If you did and its still the same, that means your headset slot has been damaged. If you did change to a new headset and it works, that means your old headset has been spoiled or damaged already.
May 03, 2010 | O2 Samsung SGH-E250 Cellular Phone
Mic not working (plantonics headset)
Your exterior mic MAY have been the one ACTUALLY working rather than the one on the headset. Some mics require a battery for the mic part to work, Not sure about your particular Plantronics. If it has a battery, then check the battery as the receiver part does not use it but the mic MAY use it.
Oct 06, 2009 | Plantronics Radio Communications
I have a gn9120 headset that i love. suddenly, callers are complaining that they can't hear me. Is there volume adjustment or is there a defect?
Volume adjustment is made by depressing the two + and - together until beep is heard
once beep is heard press the + button several times until louder bleep is heard this will increase transmission from headset and cure the problem
Steve
Jul 15, 2009 | GN Netcom GN 9120 Professional Headset
GN Netcom 9120 unexplained beeping
Actually what she was hearing was the ring tone in her headset when a incoming call comes in. The sensitivity on the handset lifter that picks up the ringing on a incoming call was set all the way up and was picking up interferance from the headset base as they have the tendency to buzz when placed right next to the phone. I just turned down the ringer sensitivity with the adjustment on the handset lifter and that took care of the problem. Thanks for your time.
Nov 06, 2008 | GN Netcom (9120-48) Wireless Headset
Buzzing on the other end
TAKE THE BLUETOOTH TO AN AUTHORISED SERVICE CENTER.
Nov 04, 2007 | Motorola Mobility H350 Wireless Headset
Samsung wep 200
Headset microphone may be off. Just press the volume up buttom and keep it pressed for 4 seconds or so, the pcs will beep twice to turn the mic on.
Aug 24, 2007 | Samsung WEP200 Headset
Motorola Mobility H350 Wireless Headset Logo
179 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
