Question about Kenmore 63942 Dryer
Loud Squeaking Noise kenmore gas dryer 80 series
There is a loud squeaking noise coming from the area the motor is located. The noise seems to be coming from behind the motor and it only squeaks if you turn in one direction. It sounds like metal on metal.
I have taken the dryer apart trying to find where the noise is coming from (unsuccessfully).then reassembled the dryer. The noise continues but the machine still works.
is it possible that the blower is making the noise, as it sound like the noise is coming from the lint trap tube.
  • Anonymous Mar 22, 2014
    dryer starts with a loud constant squeaking noise. Sometimes stops squeaking then starts again. Kids say it has been doing this for about 3 days.
  • Anonymous Mar 31, 2014
    When tire moves forward, a rubbing sound comes from the back tire area in center by metal piece in center of tire. No sound when I move tire backward, only forward.
    Scholar:
  • 146 Answers
You need to change your drum rollers. To get to them you take the dryer apart from the front not the back. There are 2 screws where the filter goes in on top. Then pull the top toward you and up. Then remove the 2 - 5/16 inch screws on each side of the front panel about 2 to 3 inches down. Then pull the front up and out. Then you will see everything. Replace the belt, drum rollers, and idler making sure to oil each as you re-install them. Then put back together and your on your way.
Posted on Dec 21, 2007
I take issue with this response. No mention of oiling in the Sears instructions. I believe that these are "Oilite" type bearings not requiring oiling. Who is going to go in and re-oil drum rollers periodically, anyway? Oil will be disappear relatively quickly, especially in the hot dryer environment. Also, insufficient information to actually carry out the repair. Much better info available on this particular issue at ehow.com.
Posted on Jun 10, 2010
SQUEAKING NOSIES
if you are mechanicaly inclined it is not to difficult
can't tell by looking for noise - to confined of space
have to take the drum out first then get at the rollers one at a time
If one is noisy (just turn by hand and apply side pressure)
might as well replace both
if not rollers than look at the pressure idler that sits against the motor
and look at the plastic bushings that the drum travels on they are probably worn out
have fun
Feb 06, 2012 | Kenmore Dryers
My Kenmore 80 Series gas dryer is making a loud thumping noise when running. It appears to still be drying, just making a very loud noise. What could this be? If it's the roller, approximately what is the...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 04, 2011 | Dryers
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
My series 80 dryer squeaks
do not lubricate anything in a dryer you will damage .locate the the squeek if it is coming from the rear of the unit most likly need to replace the drum support or wheels if its intermittant and has a squeek squeeek noise that either gets worse or goes away when the dryer heats up the tensioner pully or the moter berrings are bad
Aug 10, 2009 | Dryers
How to stop squeaking noise on dryer
The roller bushings/bearings and the motor need lubricating.
If you want help with how to do this, let me know.
Apr 30, 2009 | Dryers
Squeaking noise
Noise from dryers can be eliminated through the following checks
* Level the dryer
* Check the drum belt
* Check the drum support rollers
* Check the idler pulley
* Check the glides
* Check drum bearings
* Check the blower
* Check the baffles
Apr 10, 2009 | Maytag Dryers
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Noise
how to replace a fan impellar on a zanussi
Nov 09, 2008 | Dryers
Kenmore 63942 Dryer Logo
1,585 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
