Question about Maytag MEC5430BDS Electric Cooktop
Maytag,electric stove- i have,maytag precision touch control 500 electric smoothtop stove,its four years old,first front cooktop is not working.can you show me how to fix it.
  • 7 more comments
  • zlajo Dec 07, 2007
    in advance thank you so much.
  • Anonymous Feb 02, 2008
    Same exact problem. Can it be replaced?
  • zlajo Mar 11, 2008
    hi zlajo,here!i dont think that costom control kit is going to help me,i need to know how to taketop assembly (bsq) out,then i knowif i need control ki or mabe new element.can you tell me how to take element out.thank you.all the best. zlajo
  • zlajo Mar 12, 2008
    thanks for trying,but you canot lift cooktop up before you take something out first,i dont know what but samething is holding the glass.zlajo!
  • Anonymous Dec 21, 2008
    i smelled electrical wires burning on my build in cook top, I believe it is the switch or electrical switch. I believe it is a G. E. make. I was giving off a sizziling noice.
  • Anonymous Dec 27, 2008
    Same problem, guessing we must call maytag with this issue.
  • Anonymous Mar 12, 2014
    new induction maytag stove
  • Anonymous Mar 29, 2014
    I have a Maytag precision touch control 500 the large and medium elements are not working. they both started going really hot, now they stopped working right?
    the large and medium elements started going really hot when used, now they stopped working
    President:
  • Maytag Master
  • 2,651 Answers
You need to order a custom control kit, electronic switch that contorls onlly that one burner
Posted on Mar 11, 2008
  • Ron Coons
    Ron Coons Mar 12, 2008
    you remove the top, by first lifting the cooktop up from counter and remove all the screws in the perimeter of the housing just below the glass line probalby 12 or so all to gether, then the glass lifts right off. and its been my experience on this particular unit the custom control goes bad. youll see its the only circuit controlled switch under there.
  • Ron Coons
    Ron Coons Mar 13, 2008
    there should be nothing holding the cooktop in the counter other then gravity, its resting on a lip all around the perimeter. youll be able to push up from underneath. give a look under there. There may be a ***** style clamp holding it down( usually never installed though). just look under through cabinet. if theres an oven you'll need to pull that out first
Model # RY 160LXTS sometime the broil come on by it self, causing the smoke alarm to goes off, what can I do to fix this problem, the range is 2 1/2 years old
if this is the model with the touch control buttons on front , ive seen a stove top spill that got down inside there cause some missoperation ,id start to look there for a reason , then id move on to replacing the control panel and last the logic board (its on back of front panel ) but I will say id unplug it till I resolved this problem if it turns itself on and your not home ,what could happen !!!!
Apr 09, 2016 | Whirlpool 4.5 cu. ft. Electric SlideIn...
Maytag precision touch control 500 electric smoothtop
The heating coils in the oven need to be inspected very carefully where they plug in to the oven wall. You will need to remove the back covers and check the insulators and wiring harnesses. Over time the insulation can break down and oxidize the metal connections. You can use a voltmeter or test light to verify that the coils are getting voltage from the thermostat/switch. replacing parts is cheaper than buying new if you can find the parts.
Oct 04, 2017 | Cooktops
MY maytag flashes a error code while trying to self clean. It is a MER7765
No the stove don't work right then you have to have a repair man look at that.
Jan 19, 2013 | Maytag MER7765WW Freestanding Smoothtop...
On indicator light on my Maytag touch control 500 electric smoothtop range will not turn off, even though all burners are turned off. I also shut the power off but the light still stays on
I can't help you with this if the light will not go off on one burner then replace that switch . but if you turn the power off and the light still is on. the unit is getting power from another unknowen source . mm
Jul 08, 2010 | Maytag MEC5430BDS Electric Cooktop
The on indicator light stay on all the time on Maytag touch 500
you have a bad switch, you need to unplug the wire going to the conector marked P on one switch at a time til you find witch switch is bad. if you have turned off the breaker to it and the light is still on then the power is not off to it there is not a batery in it, careful that glass breaks easy when out of it's can
Dec 25, 2009 | Maytag MEC5430BDS Electric Cooktop
One surface element went dead.
Make sure that element didnt come unplugged. Just push it in firmly and it should be fine.
Mar 18, 2009 | Cooktops
Maytag, precision control 500 [canada]
the infamous "custom control kit" its an electronic board that only control that one precision temp burner all other elements ar regular switches, if thats the one where the sound os coming form replace the control. .nothing else to do
Dec 26, 2007 | Maytag MEC5430BDS Electric Cooktop
Maytag MEC5430BDS Electric Cooktop Logo
910 people viewed this question
Top Maytag Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
