Home | Acer | Aspire E360 PC Desktop | What seems to be the pro...
Acer Aspire E360 PC Desktop
Problem for Acer Aspire E360 PC Desktop
What seems to be the problem with my Acer Aspire
By insatiablev on Sep 03, 2009
what seems to be the problem with my Acer Aspire ASE 360-U-A3503 desktop computer. Turned computer on monitor is blank/black On the CPU the battery light is on fan is going very loud and when you go to press the power button to shut down the computer, it just stays on and you would have to unplug the power cord in order for it to go off. Now nothing is happening. What is my problem please?
Solution #1
posted on Sep 03, 2009
Not Rated)
alc03
Rank: Wiz
Rating: 78%, 9 votes
When you want to turn-off the computer hold down the power button until it shuts and it will.
It seems to be hardware problem...
So we have to proceed by elemination here...
Now if you see absolutly nothing on the screen, chance are that you have a memory problem, maybe it just need to be cleaned, maybe you need to change a stick.
First, take away the side cover of your desktop on the side that you can see the interior of the computer then you will see a/some slide(s) cliped-on the MotherBoard, unclip it clean the dust, you can take an eraser to clean the gold connector (you erase them and it will clean the gold). When it's clean, make sure there is no dust inside the slot of the slide and then replace it/them then try to boot the machine. If it work, your a winner, if not you come back to go further in the diagnosis.
Thank you.
Was this helpful?
Yes
No
Solution #2
Not Rated)
gvctts
Rank: Guru
Rating: 88%, 54 votes
Please remove RAM and then check your system if it comes on and off properly with the power button then please replace the RAM. if problem still persist then remove all hardware connected to motherboard likeRAM, PCI cards, CD/DVD ROM and HDD. and then check your system to Give beep and startup and to be proper on and off. if motherboard works proper then connect your hardware one by one and check which one is causing to stop working the motherboard. and even if the problem still persist then there is problem in your motherboard.
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire E360 PC Desktop
Questions and Unsolved Problems for Acer Aspire E360 PC Desktop
Do you recommend Acer Aspire E360 PC Desktop?
Answer
Answer
new to computers and want to type my memories but cant get "type" folders to come up
Answer
I disconnected my compaq Rresario S5500 to clean it, but when I put the power cord back in, it... (More)
Answer
when trying to upload application programme for external dvd writer once nero 7 has been installed,... (More)
Answer
Hi, I have installed Realtek ALC888S driver on an Acer lowcost PC but the device 'HD AUDIO' shows up... (More)
Answer
I cant get my Toshiba Equium to work off the mains. I have had it on charge over night to try and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire E360 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
