Question about Konica Minolta DiALTA Di200 Copier
Help have a minolta copier model #EP3000 and it has a code C0500 How do i clear this code. thanks
  • Anonymous Jan 04, 2008
    We have a model #EP3000 and it has a code C0400 How do we clear this code. thank you
    Merus
    Problem Solver:
  • 18 Answers
Your heat lamp is not turning on, did you change it? generelly some copiers that old may have to disapate charge in the electronics after being worked on. if the copier did not initiate after rebuilding or doing work on the fuser, you may need to actually unplug it from the wall, like a reboot. the electronics are dated 8 to 10 years old. make sure, if it has a power relay or fuse, because of its age , they are good. generally older units will fire back up at off and on. if nothing works, let us kow.
Posted on Dec 08, 2007
  • rrralf Dec 08, 2007
    I,m NOT an apprentice!! just a bad typeist!
On display showing problem code 500
Sir,
To clear this code requires you to gain access to the System reset. Open front door locate a small panel with one screw to release it in side will find two small black buttons find service and let machine reset if the code persists then your fusers is gone, the EP3000 is a legacy equipment may find a problem in locating spare parts if the thermistor, thermosat or fuser lamp is shot. Ensure machine is on when you attempt above.
Sep 06, 2012 | Minolta Office Equipment & Supplies
Minolta error code c0500
A C0500 code deals with the fuser temp. You maybe able to reset the code, by pressing the trouble rest switch. If it will not clear you will need to look deeper into the fuser unit. I don't know what model you have, so I can not go any further. Good Luck
Nov 24, 2010 | Office Equipment & Supplies
Porque sale error c0500 en la dialta 470
plz chek the thermostate heater unit fuse and heater lamp and clear truble button and relase this code c500
May 28, 2010 | Konica Minolta DiALTA Di200 Copier
Minolta cs pro EP3000 copier. The copy is too dark even on lightest.thanks
Clean the optical parts:mirrors,lens and the charge and transfer/sepaRATOR CORONAS.
May 13, 2010 | Office Equipment & Supplies
EP3000 error code c0500 will not clear
Sir,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 02, 2010 | Konica Minolta DiALTA Di200 Copier
Code C0500
hold down exposure key (<) while turning on power, u-1 will display. prss start, select clear mode, prss clear/stop
Dec 15, 2008 | Minolta EP1030/1030F CS/PRO Copier
ERROR CODE CO5OO FOR MINOLTA CS/PRO 2080 ????
This is a lamp error, check that is not burned, or the thermal fuse.
1. Press the soft initialization on the right side of the control panel.
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
Warning: Be advised that with fuser codes, some RISKS are involved, PLEASE SEEK PROFESSIONAL HELP to reduce these risks.
Thank you and good luck!
Jun 18, 2008 | Minolta EP4000/5000 CS/PRO Copier
How do I get to Tech Rep Service Mode on Minoltas to clear C0500 error code?
power down copier at op-panel.straightend end of paper clip into little hole by op-panel power button.hold in till little dot appears on screen in middle to the left.press #3.that should get you to trouble reset.Or sometimes opening and closing rightside door can reset.
Dec 01, 2007 | Konica Minolta DiALTA Di200 Copier
Konica minolta Di3510...C0500 troubleshooting
C0500 refers to a low fuser temperature. You can attempt to clear the code by using the tech rep service mode.
Go to "Counter"
Go to "Trouble"
Trouble reset
If "warm Restart Swich" is asked for- This can be actuated through a small access hole on the right side of the control panel, using a straightened paper clip or something similar.
You may need to clear the counter by pressing "clear" and then "end".
After clearing the code, power cycle the copier. If it comes to "ready" you are all set. If not, you may have a blown heat lamp or thermal fuse which would need to be replaced by a technician. Good Luck!!"
Oct 30, 2007 | Konica Minolta DiALTA Di200 Copier
Code C0500
simulation = UTILIY -----> METER COUNT (on touch screen)->
STOP------> 0-----> 0------> STOP------>0------>1
Sep 07, 2007 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
99 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
