Question about Maytag MSD2432G Side by Side Refrigerator
ACTUATER PAD I actually have a Maytag Model MSD2732GRW but the lever that you place the cup against and push for ice and water keeps getting stuck and the water or ice will continue to poor until I either open the freezer door or just keep pushing the cup against it until it stops. Now, also the light keeps coming on and getting stuck also and usally solved by opening the door serveral times or pusihng on the light button several times. Any suggestions?
  • Maila Dec 08, 2007
    Thanks for the help. I will try it.
  • 447 Answers
Yes sounds like you need a new actuator pad. I had one do this this week and a new pad resolved it.
Posted on Dec 07, 2007
Ice and water keeps coming out
Cup lever isn't returning to the off or close position completely. Suggest checking for rusty spring, dirty parts restricting lever and other parts there from moving freely. Could be the switches are worn out as well. Dis-assemble and clean all parts and inspect or replace old worn switches. Inspect ice drop/ flap door for mildew, sticky residue from drinks and ice build up.
Feb 09, 2014 | Kenmore Elite 31 cu. ft. Grab-N-Go...
Maytag MSD2732GRW ice maker quit.
Hi dsandcs, how many water supplies does your fridge have?
I mean if you look at its back can you see one or two plastic tubes? (that transport the water to the frigde)
Dec 31, 2007 | Refrigerators
Maytag MSD2574VEM00 refrigerator - ice does not stop dispensing.
Check to see if there is a lock button that will stop the ice from comming out then check the pad that you push on to get the ice and see if its stuck in , there is a switch behind the pad and it will need to be replaced
Jan 18, 2014 | Maytag MSD2756G Side by Side Refrigerator
My Samsung Model: RF4287HARS refrigerator stopped DISPENSING ice. It makes it, but only water comes out of both push levers now. I get ZERO help from samsung customer service. There is nothing in
The problem is actually in the dispenser lever. The paddle that you press to dispense ice has a plastic lever/arm that extends behind it (you can't see it, it's up high in the assembly.) This plastic lever presses upwards when you push the paddle and presses into a switch. The switch actuates the ice. This little lever is also the ONLY thing that stops the paddle from continuing to press into the water paddle. So when the lever breaks, it creates your two symptoms - no ice and if you press further, you press the water switch and get water.
You need part# DA97-08519A. This is the lever assembly with the switches. You pry the control panel assembly (the whole digital display above the water/ice dispenser) out by inserting a slim pry bar (I used a pocket knife and didn't damage the finish) on one side and working my way around. The assembly is held in place by five plastic tabs (two on each side and one on the top.) When this is removed, the part# above will be obvious.
Sep 08, 2012 | Refrigerators
Not making ice has water though
when my unit did this it was because the ice full lever had by mistake been placed in the ice tray full
position see if the lever will go down and also see if a ice cube is stuck in the tray where the ice comes out
Oct 09, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house in June. The change filter light came on a few weeks ago and I can't get it...
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house the change filter light came on and I can't get it to go off. How do I reset the change filter light (it's not time to change the filter)? The model # is MSD2732GRW and I don't have a manual for this refrigerator. Thanks!!
Sep 07, 2010 | Maytag Refrigerators
Our fridge's water/ice dispenser will not shut off unless the child lock is turned on. Without it, the water/ice keeps coming out just like a cup has been placed there. What's going on and what needs to be...
in the back of the fridge u have a water solenoid itll be blue probably it has a wire harness that goes to it pull the wires off of it and see if it has constantly got power to it if u dont then ur solenoid is stuck and needs to be replaced if it does have constant power to it ur push button is stuck in the front where u push fpr the water to come out u have to find the lil switch and see if it is hung up u may can tap on it to break it loose but if it is stuck its gonna have to be replaced hope this helps
Mar 01, 2010 | Refrigerators
No ice to the door
The motor is behind the ice bin and yes, it can get water on it and freeze up. I actually fixed one a month ago that I had to remove the motor and let it dry at room temp for a week in order to get it to work when reinstalled. Two or three days and it would freeze right back up in a little while. This usually happens when you've had a problem with the waterfall into the ice reservoir that a bit pours over the edge or when you've defrosted the freezer or left it open long enough to let ice thaw to some degree. You can pull the ice bin out and twist the motor by hand. If it is stuck it is froze but if it moves it is probably bad. You can close the switch with the door open and check with a volt-meter to see if there is voltage going to it if the motor turns freely. It will have a lot of tension but you can turn by hand.
May 09, 2009 | Kenmore 53642 / 53644 Side by Side...
Switch sticks for the ice and water. It wont shut off
Remove the water drain and the two screws behind it and lift up to remove the push button panel,unplug the push button panel. remove three screws holding the dispenser unit in place,sliding the water uotlet out of the way as you do. Next get to back of rubber cover and put a little lubricant(silicone lubricant would work,not too much, then test.Then test and reassemble.
Burkes of Byron Ga and Orlando Fla.
Jan 29, 2009 | Maytag MZD2766GES Side by Side...
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Maytag MSD2432G Side by Side Refrigerator Logo
229 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
