Question about Toshiba Tecra M2 Notebook
Tecra M2 Top Cover Replacement
The top cover on my Tecra M2 is badly scratched, can I replace it and if so how?
  • 138 Answers
Yaaa you can change the whole laptop cover! but at authorised service station only!
Posted on Dec 08, 2007
Tip
How to change toner in laserjet printers
First Turn the printer's power off. Some power button is located on the control panel on the top of the printer, on the right side. Open the printer's top cover by pressing the top cover lever, which is located on the bottom side of the top cover. Lift the cover all of the way open. Locate the toner cartridge. It will be right in the center of the printer and has a handle on the top of it. Grab the handle and pull the cartridge out. Hold the replacement cartridge at its side and gently rock it back and forth. This will help to distribute the toner equally throughout the cartridge.Remove the paper cover from the top of the cartridge.Insert the replacement cartridge into the printer and close the printer's top cover.
on Mar 31, 2010 | Office Equipment & Supplies
I have a cracked screen (toshiba tecra m2) and have an opportunity to buy a replacement screen from a tecra m2 S630 that is broken. Are the screens interchangeable?
Can't answer your screen question, but I can propose a workaround - your Toshiba laptop has a
monitor port on the back - you can plug in a standard monitor, and ignore the cracked screen
temporarily until you can replace it. hope this helps
The monitor port is the 15-pin analog VGA D-shell (female) port.
The online User's Guide for your Toshiba Tecra m2-S630
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=596874&rpn=PTM20U&modelFilter=M2-S630&selCategory=2756709&selFamily=1073768664
Apr 17, 2011 | Toshiba Tecra M2-S630 Notebook
Please help! I have recently accquired a Toshiba Tecra M2 laptop 2nd hand. Ive had it for at least a week and now all of a sudden it will not boot up. Instead i can only see a cursor in the top left hand...
From your description it is the hard drive that is the problem and will most likely need replacing, you will need to take it to a computer technician for an estimate before you commit.
Jan 14, 2011 | Toshiba Tecra M2-S730 Notebook
Change the headlight on a 2006 Chevy Equinox
The front bumper cover does have to come loose at the top. Remove the retainers along the top of the front bumper cover on top by the radiator and loose the part of the grill that goes over the headlamp. cover with tape to avoid scratching the lens . then remove the 3 bolts for the headlamp. Two at the top and one down at the bottom inboard side. Then pull the headlamp at the outobard bottom to release the retainer and remove the headlamp.
Aug 17, 2009 | Street Glow Streetglow Streetglow H894...
Start from scratch Toshiba Tecra
You can reinstall completely by using the original discs. If you want to try to get this copy working you could always try downloading a trial of XP Manager by Yamicsoft and run through the Optimise Wizard which will prompt you to clean the correct areas.
Jun 03, 2009 | Toshiba Tecra M2-S730 Notebook
Changing power outlet on pc
Take out all of the screws on the bottom. Remove the hard drive and the dvd drive. Take out the keyboard, take out the screws from the top cover, remove the screws to the lcd assembly and take that out and any wires that are connected to the lcd.
Once this is done then take the top cover off and make sure you disconnect the ribbon cables before taking off the top cover.
Then after taking off the top cover remove any screws holding down the motherboard. After you get the motherboard out then find where the dc jack is and then you can either change it out with a new one or resolder the exising one back into place.
Then when your done you can put it back together again.
Jan 12, 2009 | Toshiba Tecra 8000 Notebook
Scratched top. Need part number?
assuming the very top cover on both units are scratched??? i have part numbers for you , but thinikin your gonna need to call cust service to order the parts, local part houses probably dont stock them(lg parts anyway).. washer part number( AGU30781501 $80US) dryer part number ( AGU30071202 $70 US)
May 10, 2008 | LG WM2487H Front Load Washer
Internal clock
That is correct. There is a battery inside that needs replace. You need to take the bottom cover off and find the battery inside and replace it.
It should be a CR2032
Here's what it should look like:
Dec 26, 2007 | Toshiba Tecra M2-S730 Notebook
Lid/Top Loose
I have a Tecra M2 S630 and was able to fix my left hinge by removing it and drilling out the rivet and replacing it with a 6-32x1/4 inch machine screw and a nut. Total cost was $4 for a package of nuts and screws from Radio Shack.
Nov 30, 2007 | Toshiba Tecra M1 Notebook
Toshiba Tecra M2 Notebook Logo
90 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
