Wireless printing how do i set up to print from a printer hooked up to another computer?
You will need to first share the printer on the computer. If machines are than part of the same workgroup or domain you will be able to connect to it by searching for a network printer.
Posted on Dec 07, 2007
SOURCE: HP laserjet 1020 one page only when usinga printserver.
I have same problem and have just learned that HP LaserJet 1020 is a host-based (i.e. GDI-based) printer that makes use of the processing power of the host it is hooked up locally to. No GDI based printers works with print servers.
Posted on Mar 07, 2007
  • 93 Answers
SOURCE: how to hook up this printer wireless to my main computer
We cannot connect the pro l7680 printer wirelessly. Connect the printer to the router via ethernet cable and connect the desktop to the router wirelessly.
Posted on May 26, 2008
adonscott
  • 106 Answers
SOURCE: Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
Posted on Jul 07, 2008
  • 92 Answers
SOURCE: Wireless Printing set up
In order to print via Bluetooth communication with Macintosh, the following system requirements must be satisfied.
Computer
A Macintosh with an internal Apple Bluetooth module or a Macintosh attached D-LINK DBT-120 USB Bluetooth rev.B
OS
Mac OS X v.10.3.3 or later
In order to connect the Bluetooth unit and print via Bluetooth communication, the following steps are required.
STEP 1
Check that the Bluetooth unit is properly attached to the printer.
STEP 2
Install the MP Drivers.
STEP 3
Check the device name of the printer using the LCD.
STEP 4
Register the printer as a Bluetooth device using Bluetooth Setup Assistant.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 26, 2009
  • 685 Answers
SOURCE: I have lost the software to setup my HP J4680
Go here to get the software.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3692888&lc=en&cc=us&dlc=en&lang=en&cc=us
Choose your operating system and then download and install the FULL version of the software. I do NOT suggest using the basic print and scan driver.
Posted on Oct 26, 2009
I have my Canon MX420 printer hooked up, my computer recognizes it's existence, and the printer prints fine by itself. However, every time I try to print from my computer via wi-fi, my computer says...
If your printer has the network cable plugged into it then your halfway there. Make sure that as well as having a hard line network cable plugged into your router, you need to connect the printer to the wifi signal as well. On your printer, push your settings button, scroll to your wireless lan setup, and connect to your router and if password protected, enter in the password and you should then be connected to you router, now try printing using your laptop or device through your wireless connection, and it should print. Please post back if you need further instructions or help!
Aug 24, 2011 | Canon Pixma MX420 All-In-One Printer
I need to get a wpa passphrase how do i get 1
Difficulty: Moderately Easy
Instructions
Things You'll Need: · Wireless print server
· USB printer
· Ethernet cable
· Computer
1. Step 1
Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address.
Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit.
Step 10
Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
Can i hook my printer to this router Linksys wireless-g 2.4ghz
You want to connect a printer to the network.
If you have Ethernet port on the printer then you can connect it to the router with the ethernet cable. IF it is wireless printer then you will need to connect to the wireless network on the printer. In both the cases you will need to set up your printer as a network printer. If you contact the manufacturer of the printer they will tell you how to do it.
If you do not have ethernet port on the printer and it has only USB port and it is not a wireless printer then you will need a print server. You can purchase a wireless print server and you can set it up so that all the computers will be able to print onthe same printer.
If you have only the USB port and you don't want to use print server, then you can connect your printer to one of your computer. Enable File and printer sharing on all the computer. If you go to microsoft.com and search for file and printer sharing, you will get steps to enable file and printer sharing.
If you want to check the wireless settings of the router, you will need to open the set up page of the router .
Click here for more information about router and networks
Mar 21, 2010 | Linksys Wireless-G WRT54G Router
I have a sony vaio VGN-FZ430E for a year now. It is set up on a new printer, a lexmark X4690 wireless. Right now we don't have wireless internet so we have to computer hooked up to a non-wireless network....
If you're on a wired network now and the Printer used to be on a wireless network, your computer may not know where to print to anymore. You might want to try uninstalling the printer in full and then reinstalling it making sure to do it directly connected to the computer you want to print from.
Aug 06, 2009 | Computers & Internet
I Have an H.P. Office Jet J4680 and it prints only one copy.
uninstall the wireless drivers from your computer and reconfigure the settings.....these issues are generally related to the printer drivers.....
Jun 24, 2009 | HP J4680 Office Jet All-In-One Printer
Setting up printer on home network
Because your printer is not either wireless or network capable, the only way to get the results you need is to purchase a usb print server, hook it to your router, set it up through it's management console, and if your router is wireless, you can hook up to your router and print to your printer with your desktop turned on or off.
Apr 13, 2009 | Computers & Internet
Printer prpblems
All you need is to configure the IP address on the desire laptop that you want to hook the printer.
Check the printer preferences for colour print.
Feb 26, 2008 | Samsung CLX 3160fn All-In-One Printer
Setting up wireless connection to network
You have to set up a network and then make sure workgroup name is all same and make sure when you set it up you allow for printing on the network, Now when you go to print make sure the computer, the printer is hooked to it, and the printer is on, Now go to your control panel, Open your printer and faxes. on the left hand side it will say add printer, Click on that, Now click next, Now you want to select. " A network Printer, Or a printer attached to another computer". select that, and follow the directions windows will find the printer and install drivers so it should work after that, I sure Hopes that this solution fixes your printing problems. U All have a Happy Holidays, And if this don't work write back here and we will try something else. bear001
Dec 11, 2007 | HP Photosmart C6180 All-In-One InkJet...
Is there an instruction/users manual
You can use a computer as a print server, and the router will allow other computers to connect to it. But other than that, you'll need to buy a print server separately and hook it into your router. You can set your computer up as a print server by installing the printer on the computer and setting up file and printer sharing through the network setup wizard in Windows XP, this can be found in Control Panel. Once that is set up, do the same for all other networked computers and then you will be able to install the printer on all other computers and print wirelessly (or wired) from any computer connected to the router. However, the computer the printer is physically connected to will need to stay on all the time, or at least be on when you need to print from another computer. I'm not quite sure if you can get a router with a built in print server anyway. But you can certainly achieve what you're looking to do - but perhaps not an all in one package like you were asking. I hope this helps you.
Sep 06, 2007 | Actiontec GT704WG Wireless Router...
Open Questions:
ricoh aficio sp C232SF / c231sf When enabled, initializes but does not print Ricoh Aficio SP C232SF / c231sf The situation is. When enabled is initialized, writes that greeedy and is in readiness. No mechanism at this time does not work, except the scanner line. Scanning Starts, black and white is faster than the ruler, the color is slow. The document feeder works off a sheet and hands. After all the manipulations on the display Processig shines indefinitely no mechanism works until you press stop. The same situation when you try to print reports or when sending to print from a computer. the driver stood on the USB bus. Using command center see it all, but printing is also not achieved. Sees the tray and the presence of paper. Now this is the strange print though, and no, the black toner decreases. Already there was an inscription about it on the display and in commands the center shows the decrease in black. Only black. If you press for example copying, will stand and-writes about the heating of the stove no mechanical work and after a couple of seconds is ready. Stove at this time safely lying on the table next to the machine. the line Lamp is normal, but no power is supplied to it. The power supply did not find any problems. In the service you start the registration-work out the engines of development and tape, and a couple of auxiliary. Tried to make init EEPROMy, tried to rewrite the data in it, as if installing a new one-no changes Any ideas and assumptions are accepted And for dessert - a main Board, engine and the controller changed. The situation is quite similar. Sew and successfully both through the grid and through the USB port. I don't know where to look
Sep 23, 2018 | Ricoh Office Equipment & Supplies
706 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
