Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Tv problems My tv just started messing up yesterday. The color has alot of pink and green in it. When you hit info for next show the line is curved and doubled. I don't know if I should trash tv or not ? It's not 2 yrs old yet.
  • Anonymous Dec 18, 2007
    I am trying to adjust the focus lines together to make one line
    President:
  • 4,402 Answers
I think you might have a convergeance problem, check this out.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 07, 2007
Got it new at Walmart in 2006? Never had any problems with it, and always had a surge protector. I know the kids have abused it though. Anyway, yesterday they had a pink, washed screen, turned it off/on...
No.The tv video board have dead components,that the board where it is connected to the CRT-(tv picture tube).Troubleshooting that video board and changes parts should fix ur tv problems.Hope ur tv problems,it is not the video board main big IC colors processor inverter.This big IC is a pain to change and probally not in the market anymore.Troubleshoot test all the capacitors around that big IC colors processor inverter alot of times just those few capacitors are dead only.
Apr 02, 2011 | Sanyo HT30744 TV
I have pink and green wavy lines. Most pronounced at the bottom of the screen.
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | Panasonic PT-47WX49 47" Rear Projection...
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
I have bright pink and green on tv
this is a typical symptom of convergence. i.e red and blue beams arent not focus.
the convergence ics need to be replaced (check for open resistors), followed by a refocusing
pls rate me!
Mar 21, 2009 | Hitachi 53UDX10B 53" Rear Projection...
56 inch projection tv
This is a convergence problem. If you would please post the make and model, I can provide you with some details about the probable defective parts etc.
Thanks,
Dan
Sep 08, 2008 | Akai Televison & Video
Hitachi 57SWX20B 3D Effect due to green light convergence problem
I'm trying to fix the issue on my 43FDX20B. So far, I'm able to move the lines up and down, but can't get the left/right motion to fix it. The attached link has the dynamic mode instructions, so you can correct this issue yourself.
http://home.comcast.net/~leebailey00/Hitachi_DCAM_Manual.pdf
The only thing I didn't have was the screen overlay jig the manual talks about. I decided to create one myself and use the screen as a beginning template. I went to our local hardware store and picked up some home window weather covering. The roll cost about $15, is a clear strong plastic and the template was very easy to create. I used a straight edge after I put dots on the plastic and measured the lines for being square and equal after I took it off my tv. Good thing is that if you don't like what you make the first time, you have a 25' roll to use to try again (ha).
Mar 01, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Seeing alot or green lines, test somewhat double vision
there is a screen the light shows through to project to the screen when this starts to fail the screen will have lines. it sits at the end of the light chamber. these are expensive to replace on some models.
May 30, 2017 | Mitsubishi WS48511 48" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
Jerry Greenberg
Jerry Greenberg
