Programming channels is it possible to programme channels without the remote control Can I program chanels with out the remote.
  • carwc Dec 08, 2007
    model number is SV2000 made by Philips
  • 203 Answers
Not knowing what TV you're talking about it's hard to say. Can we get a model number on the unit?
Posted on Dec 07, 2007
Lost my controller for my duraband ptv7017 and can't select the av chanels. How can I do this without the controller ?
Hello
Without its remote control, you can't select its AV channel. Just try to get a new remote control or buy a universal remote control, which have setup codes for Duraband Tv with it.
Setup codes for Duraband are:
0189 0135 0157 0153 0254 0458 0217
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Feb 07, 2012 | Televison & Video
Goodmorning, bought a zenith tv didn't get the remote. Wonndering how i can programme it using just the buttons on the tv. How do i get the menus up. it only catches threes channels as of now.
Hello
There are two types Zenith TVs. One type will have "Menu" button on its front panel and other will not. If your Zenith is the first type, you can programme it without a remote control. If it is the second type, you must have a remote control hanset to programme it.
Programming method
First connect the TVs antenna socket at its back with external antenna or cable.
* With the remote control in hand, press the POWER key to
turn on the Presentation TV.
** Press MENU repeatedly until the Setup menu appears.
*** Using the Up/Down arrow on the remote control, highlight
Auto Program on the screen
**** Press the Right or Left arrow to go to the Auto Program
menu.
***** Using the Up/Down arrow, choose either Cable TV or Off-
Air Antenna on the screen.
****** Press the Right or Left arrow to begin the Channel Search.
******* Press ENTER when the channel search is done.
Note: Auto Program finds channels being received by the TV
tuner
Cable will not work unless you subscribe to a cable service
OK.
Jun 17, 2011 | Zenith H27E35DT 27" TV
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
I hv PANASONIC COMMERCIAL TV - MODEL CT 2522 HE. I am facing problem to preogramme all channels.when I open MANU with univeral remote control,or panasonic master remote,I donot find option for PROGRAMME...
I am facing problem to preogramme all channels.when I open MANU with univeral remote control,or panasonic master remote,I donot find option for PROGRAMME CHANNEL.SOME OF THE CHANELS SKIP,I want all channels to be programmed..pls give the solution
Nov 24, 2009 | Panasonic CT25G7 25" TV
My 60'' LXI slimview television will only save one chanel.
If you have remote control for the channels on your set, try to push menu then choose "memorize channel" or choose "cable" then do the channel memory.
Thanks.
Aug 16, 2009 | Televison & Video
I have an old, jvc 20 inch, c2010 model tv without the remote and I am unable to place channel on 4 so it will be compatible with my digital comcast cable box. Any suggestions?
I hope you are able to get into the menu with the front panel.
when you are in the menu you want to be able to make the auto-programing feature works. The cable box has to be already installed and working. when the tv programming crosses the channel 4 and there is a signal there, pretty sure is going to look it. This is the easiest.
The other solution is the menu sometimes allows you to make programming manual. in manual you are able to search channels one by one and allow it in the memory or not, basically then go to manual programming scroll up or down to find the channel four and use enter (sometimes right arrow in order to change the chanel number from red to green) to record in memory this channel. Once again I hope helps you.
Apr 14, 2009 | Televison & Video
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Nov 11, 2007 | Samsung CXJ1352 13 in. TV/VCR Combo
PHILPS 29PT449A, FAULTY REMOTE, PROGRAMMING HASSLE
regarding tv remotes please check web site for proper help. www.remotes.com give model name in search. hope this will help.
Sep 30, 2007 | Televison & Video
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
