Question about Compaq NC4000 (DG987AABA) PC Notebook
Wireless connection The laptop will connect to an unsecured network but not one that is security enabled.
  • dborchardt Dec 07, 2007
    I am in charge of the network. I enter the key but then nothing happens. Netgear (the maker of the wireless router) said its the laptop. That it needs to be set to accept a security enabled network. It's already set to WEP.
  • 36 Answers
You will need to speak to the person in charge of the security enabled network, and obtain the type of wireless security (WEP or WPA) and the password.
You should also determine what security types are supported by your own laptop's wireless connection. If it is an older one, it may only support WEP, and you will be unable to connect to any WPA protected networks.
Posted on Dec 07, 2007
How do I turn on my laptop in order to use ot wirelessly?
Hi
Enable your wireless connections and search for wireless connection that in unsecured or secured connection. For secured connection, you need to encode the WEP password to be able to access into the internet. For unsecured connection, you can connect directly and automatically.
I hope it helps you.
Jan 10, 2011 | Fujitsu Siemens AMILO Pro V2010 Notebook
I have secured my router by connecting my laptop to the router by ethernet cable so now my network comes up as security enabled but I can't seem to connect to my wireless network although it shows the...
Remove the neighbor's network from the preferred network list.
add your own network in the list. If your router is old router then upgrade the firmware of the router. Firmware is the software of the router.
You have connected your laptop to the router, to secure the wireless network. When you connect the laptop to the router, make sure that the wireless network connection will be disabled.
Once you change the wireless settings, enable the wireless connection and connect to your network.
Apr 25, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Need to enable security -- had a power failure -- the computer with direct cable connection has internet access, but my laptop with a wireless connection no longer works -- says the network "is unsecured...
Log in to the router, check Wireless settings, Security is in the same area. I find that WPA-PSK[TKIP] is the easiest type to use, as you can use pretty much any sort of password longer than 7 characters. This can be done with the wired connection.
Nov 09, 2009 | Linksys Wireless-G Broadband Router
I have installed uninstalled my laptop to the netgear wireless. It won't connect to the secured wireless but only to tthe unsecured It then says TCP?IP disabled for this connection
Hi and welcome to FixYa,
Initially, which is the Netgear, the WiFI / AP router or the wireless networking card of the laptop?
Offhand, that there are at least two (2) networks that could be detected by the laptop indicates that the WiFi is both receiving and transmitting (it works and therefore the issue is settings & configurations). Which of the networks is yours; the secured or unsecured?
Alternately, determine the SSID of your WiFi network and the PASSKEY used or the security system used (if one is used in your system/network). Additionally, are you using the Netgear Smart Wizard Wireless Assistant or the Windows built-in Wireless Network Connection?
For the secured system, use the PASSKEY determined as per above; for the unsecured, it may be employing MAC filter, try manually inputting the IP Address, Subnet Mask and Default Gateway.
Postback result(s) / updates.
Good luck and thank you for asking FixYa.
Oct 14, 2009 | Computers & Internet
Unable to encrypt router
you have to check if you have the wep key enabled. when you put in the wep key, it should also be enabled so that your wireless network should say security-enabled wireless network. make sure to disconnect and connect again on your network after changing the settings to refresh your connection. hope this helps.
Jun 04, 2009 | Belkin (F5D5231-4) Router
Secure Wireless Connection Says It's Out of Range
Follow the steps in the SecureW2 user guide to make sure that "Enable IEEE 802.1X authentication for this network" is enabled.
User guide here: http://www.securew2.org/wiki/UserGuide
Feb 06, 2009 | Dell Inspiron 8600 Notebook
Wireless network problem
go into ur wireless network properties.click internet protocol.check settings .if obtain ip auto is checked.connect to the unsecured network to obtain details..ip,gateway , dns etc.
disconnect go back to wireless properties and select use the following ip/dns in internet protocol and type in the details..this will get u connected..once connected left click on connected icon in sys tray and select repair this should make changes to ip and dns..it may change it may not ..if not it doesnt need to.
Jan 14, 2009 | HP Compaq Evo n610c Notebook
My linksys says it is unsecured. how do i make it secured?
I found a link on how you can secure your wireless network. Click here. Let me know if you will still have a problem.
Sep 16, 2008 | Linksys Wireless-G Broadband Router
New HP laptop will not connect to wireless secure network
Problem solved. I disabled the security on my network. I connected the new laptop to the unsecure network. I saved the settings on the laptop for the unsecure network. I rebooted the laptop. I re-enabled security on the router. I tried to connect to the network. I got an error on the laptop saying the network saved settings did not match. I modified the settings to a secure network on the laptop and saved the 128 bit key. Rebooted everything. All works fine now.
Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Wireless Networking - 2 PC's
ai..McGuywer,
on St. Paddys day and nice to ya.
you'll need a router, maybe you can track down a good one here, where we list the best three?
Mar 18, 2008 | HP Compaq nc6320 Notebook
Compaq NC4000 (DG987AABA) PC Notebook Logo
166 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
