Question about RCA P60921 60" Rear Projection Television
RCA 46" Rear Projection TV
It looks like it is projecting in double. Is there a way to adjust to solve the problem?
  • bgp2 Dec 11, 2007
    Thank you for your help.
  • 4,402 Answers
I would say convergence drivers, IC's if it has them, transistors if it does not.
Posted on Dec 07, 2007
Fixphillips rear projection tv is showing double text with red on top
the set uses two stk-392-120 convergence chips, both will need to be replaced and the set sells kits for this based on brand and model number.
Oct 26, 2012 | Philips 60PP9352 60" Rear Projection...
I can see double images red and green it just started on its own is there a away to realign the lamps??
I am going to assume that you have already tried to do the convergence adjustment. If not open the menu, choose setup, look for convergence and follow the instructions on the screen. If this does not solve your problem you probably need new convergence ICs. They control the position of the beams and are run very hard and hot. Over time they will dry out the heat sink compound (used to enhance heat flow from the ICs to the heat sink) which causes heat buildup and failure. If the convergence adjustment will not solve the problem new ICs are in order. You will need some help replacing them and I can help with my tip at which explains how to identify the ICs and the procedure to replace them as well as where to purchase them.
Thanks for using FixYa and please consider a maximum rating. Maximum ratings and testimonials keep the experts helping solve everyones problems. Thank you.
Oct 29, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Just fixed the convergence chip problem.$534.00. Now 720p and 1080 1 signals are showing double images and colors. Also the componentinput #2 is showing double images on any format
many of these sets need the convergence adjusted in the 480 and the 1080 separate-- the set most likely if looks good in 480 needs to be adjusted with the original remote in the 1080 mode.
Whoever charged you 534 got you---if you did it yourself you paid way too much--with 1080 signal--enter convergence mode and try to adjust in customer menu--if 480 is ok---it needs to be adjusted in the hd mode.
Oct 31, 2009 | Pioneer SD-643HD5 64" Rear Projection...
The picture looks double with the red convergence adjustment will not work took back off all color lights seem to be working
Go to menu setup look for convergeence,see no convergence adjustment.U have an open Fuse at (FL231)located right side of the Flyback Transformer.There is 3 in a roll small
brown rectangle looking caps,but they are Fuses,it will be in the one in the middle.
Aug 20, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Looks every thing is double like 3d and curve in the middle
Your CONVERGENCE needs adjustment.
All TVs are different - please consult your owners manual on the procedure.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 11, 2009 | RCA P46924 46" Rear Projection Television
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
May 24, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Picture distorted and double vision
adjust the convergence..........push mute 1 8 3.....and it will take you into it. pnce in 2 will change the adjust mode, and 7 8 9 change color options
Dec 22, 2008 | Akai PT4298HD Rear Projection Television
PT4298HD Double image
BINGO thats exactly what i get paid to do same price 285.00
Nov 30, 2008 | Akai PT4298HD Rear Projection Television
Double images
You need to replace both convergence ICs they are STK392-560 you can get replacement ICs at the following link and they provide free installation instructions with pictures so you can install them yourself. Heres the link.
Jun 07, 2008 | Sony KP-65WS500 65" Rear Projection...
Double- Vision
More than likely your akai has defective stk392-040 Convergence chips . it also may have open resistors generally 3.9 ohm flame proff. this board is attached to the top left looking from the back of the set it is screwed on by 1 screw black in the center . after installation this will probably half to be converged dinamically. which means you will half to get to the grid this is done by using the remote press mute 183 quicly to enter numbers on thew remote 2 to adjust red 4 to adjust blue horizonta 6 to adjustred vertical and 8 to adjust red vertical using center button to go up and down
Feb 20, 2008 | Akai PT4298HD Rear Projection Television
RCA P60921 60" Rear Projection Television Logo
50 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
