Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
Connection for tv cable to hitachi 42" plasma Tv
I just purchased a 42" plasma Hitachi TV and have no idea where to connect the cables inorder for TV viewing. I did however manage to connect my DVD player and that works but I cant find the TV cable slot. Please help ASAP.
Thank you
    Novelist:
  • 148 Answers
There is no cable slot. the monitor is not a receiver. it has no tuner in it. it will need a signal from a tuner box. and that must be fed to the tv with an hdmi cable or a dvid cable for hd to work. see your manual for further information on cables. see your cable supplier for information on hd boxes available in your area. if you do not buy hd service, you will not get an hd signal. so you will see little difference from a non hd device. your dvd player may have hd capabilities, but will also need the same cable to deliver true hd signal.
the good news is that its fixable by using the right equipment.
good luck
mark
Posted on Dec 28, 2007
How to connect hitachi tv 42" to internet inorder
A computer and a VGA computer cable. The TV has to have the computer VGA hookup in the back of the set. Once hooked up you will need to get the proper input on the TV to VGA or PC.
Jun 23, 2011 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi ultravision model number 42hds69 cable problem.
Usually you need a decoder to receive "Cable" With your "Cable" usually you connect the Cable antenna, to the Cable "Box" form the "Box" to the Audio Visual EXTERNAL inputs, in the back of the TV. Now IF your TV can receive the "Cable" directly, then you would have to connect the Antenna, into the rear of the TV, now you would go to the "Tuning" section, and, the TV, would automatically "Search" for any available channels. They would then, be displayed at the end of the scan. Please find a user manual below, this will help you tune in, IF you can. If you cannot, you will have to get a cab;e "Box" and a remote. Hookup to the TV, from the "Box" to the TV, via, Audio and Video cables. You use the "Box's" remote to change channels and volume. You first must set the TV's Volume, & picture setting, the TV, is basically just used as a "Monitor" for the "Box". Hope this helps..
http://tv.manualsonline.com/manuals/mfg/hitachi/42hds69_55hds69.html
Apr 23, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Just bought blue ray player I have a hitachi plasma tv model pw1 32pd5000 how can I get blue ray to work with tv theres no hd outlet at the back of tv but it is hd compatible
The TV most likely will have component and a DVI connector on it if it doesn't have a HDMI connector. If the Blu-ray player has component connectors on it use them as they will give you up to a 1080i picture which is all this model of Hitachi supports anyway. If the player doesn't have component connections then you can get a HDMI to DVI converter cable so you can connect it to your TV. You will need a cable that looks like this...
http://www.kmart.com/shc/s/p_10151_10104_25000PCM-2296-06P?vName=Computers%20&%20Electronics=&cName=HomeTheater&Audio=&sName=Accessories&psid=FROOGLE&aff=Y&sid=KAx20061023x272xTier3
Nov 11, 2009 | Hitachi P42A202 42 in. Plasma TV
Random 3'' vertical red line on 42'' Hitachi Plasma TV
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
Sep 04, 2017 | Hitachi 42HDS69 42 in. Plasma Television
Hi can u hep? i connect my hdtv connector from my x box to a hitachi plasma 42 " tv which also acts as the pc port, but get no sound?
make sure that the connection you are using is providing audio to the tv. If it is VGA, or DVI, those cables do not carry audio, only video.
Sep 07, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi Plasma TV _ AV300E
Depending on the way you hook up the media or cable box, this is what you look for, if you are in the video area then look for V1, V2, V3 or the right one if you are on the RF connection then it also has an A and B side. Try each
Feb 27, 2009 | Hitachi 42PD3000 42 in. Plasma Television
My husband moved the tv from one table to another, and now the color is all screwed up. Mostly purple and green. What's the problem? It's an Hitachi 42" plasma tv.
Usually this is caused by unproperly hooked up component video cables. Check the green, blue and red component video cables on the tv and on the device (cablebox) to hopefully solve the issue. Sometimes one just pulls loose also
Jan 10, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Is there someway to hook up our Hitachi 42HDS69 to our laptop
Your computer should have a DVI port to make this possible since your TV dont have a VGA port. If your computer have a DVI port then an HDMI/DVI cable is all you need. This allows you to connect you computer or laptop to you tv through the HDMI connection on your tv.
Dec 31, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi Plasma screen flickers
Got sound but the picture intermittendly flickers on and off. checked all cables and connections had the tv about 3 years now.
Thx
Sep 06, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
384 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
