Question about Nokia 6133 Cellular Phone
Lcd screen replacement
How do I replace the lcd screen on a nokia 6133??
I got the new sccreen and the lil tool but I cant figure out how to open it up.
Please please
ABSOLUTELY, Thanka
Posted on Aug 14, 2008
On the front side of the phone above the camera eye you can carefully (either with your fingernail or a small screwdriver) pry the plastic apart. Once you have the top apart a little bit work your way down each side, once the top and sides are loose you can slide the cover up and off. Once open ther will be a green board around and over the lcd, remove two small connectors on the top and one small one on the bottom underneath the board. When the green board is off look on the sides of the LCD and you will see four points securing it into the phone, carefully pry out on each of these and you can then remove the LCD. Replacement is reverse. Good luck.
Posted on Jan 04, 2008
Here's instructions with pictures!
http://www.tebyte.com/2008/03/how-to-replace-nokia-6126-lcd.html
Getting ready to do it myself.
- Michael
Posted on Dec 09, 2008
I'm looking for some self repair info on how to change my screen on my 6133 nokia.
To repair the screen of your nokia 6133, you need to get the appropriate screwdriver and Plastic tool such as a credit card or guitar plectrum, and follow the steps below;
  1. Run your plastic tool all the way around the join of the cover on the front of the phone to release it.
  2. You should now have the cover removed. Next you need to disconnect two ribbon connectors. These attach like a plug and socket. Simply lift each connector up, away from the circuit board, to unplug it.
  3. Another ribbon connector needs to be disconnected. Again, this is a plug/socket type connection. The green circuit board will now be loose.
  4. Lever the LCD out at the four points,
  5. You should now have the LCD screen removed.
  6. You can now replace your screen and,
  7. Reverse the whole procedure for reassembly.
Take care
Jun 21, 2010 | Nokia 6133 Cellular Phone
Won't turn on
go head change the battery thts wut i did get used one its lik $10 i hope i help lil bit
Apr 02, 2010 | Nokia 6133 Cellular Phone
Nokia 6133 screen just went blank for no reason
if the device is fully charged then the screen will need to be replaced this can be difficult to do at home but you can do it with tools made for cell phones and buying the lcd that is compatible for the device
Apr 01, 2010 | Nokia 6133 Cellular Phone
Replacing lcd screen nokia 6111
Have a look at this guide http://www.formymobile.co.uk/Dismantle/6111disassembly.html
Nov 29, 2008 | Nokia 6111 Cellular Phone
Nokia 6133 blank screens and no loudspeaker
I have the same problem two weeks ago. I opened my phone and kept it under the table lamp to dry off some moisture and my screen came back and working good.
Also tried to reset it by taking out Sim card press *3 send button together when turn on the phone ,it will take a while ,but it will reset the phone and will ask for the sim card info.
It fixed my problem ,so hope no harm to try that.
Thanks
Jul 29, 2008 | Nokia 6133 Cellular Phone
LCD Screen
if ur screen remains white or gets white than it could be display connectivity cables fault or if it is broken than it is the displays fault and it can be repaired at Nokia Care
May 23, 2008 | Nokia 6133 Cellular Phone
Nokia 6133 Almost black screen
why not have the phone's LCD replaced.
Apr 10, 2008 | Nokia 6133 Cellular Phone
Nokia 6133 LCD Replacement Trouble
my guess is that you messed with something while you were prying it open.
I have the nokia 6126 (very similar) with a broken screen but i get it open, could you help me with that
Feb 14, 2008 | Nokia 6133 Cellular Phone
STILL NO HELP
try to replace a new LCD...
Jan 22, 2008 | Nokia 6133 Cellular Phone
Nokia 6133 cracked screen
do one thing sir just open up the screws which is at the backside of the phone, and check out the connecter with the main chip of ur phone, if it is a lug out connecter than plug out the old one and plug the new one, with the screen as well there is are screws, which u can open up while changing the screen and than try, if u face any kind of problem while replacing it than consult with the NOKIA CARE.
Oct 18, 2007 | Nokia 6133 Cellular Phone
Nokia 6133 Cellular Phone Logo
491 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
