Question about Mitsubishi VS-50805 50" Rear Projection Television
Audio - No Video
My old reliable VS-50801 has suddenly begun to go black during viewing. If turned off for a bit, it's okay again, but is happening more frequently. What could be the problem? Is it worth fixing? NONE
  • yoyomama Dec 30, 2007
    Same problem. Trying to get a copy of the mitsu vs-50805 Service manual. Will take off the chasis and look for pools of liquid or dried up remnants as a first pass.
  • 3 Answers
VS 50801 and VS 60801 mitsubishiAudio - No Video - 2.gif models (I have one each) have both had this problem develop after about 10 years of service. The picture simply started "Blinking" off after collapsing to a horizontal line - audio was still present. A simple fix to this problem is to space the yoke connector (7-pin white "Molex-type") away from the neck of the CRT (~1/8 ") . I used a plastic insulator. My 60" set had a problem with the center CRT (green) connector and thye 50" set had the same problem on the connector on the Left (red) yoke connector. The TV senses an open yoke circuit and shuts down all deflection drive. I only want a few more years of service from these sets, otherwise I would resolder the connector on the PCB for a correct and permanent solution.
Posted on Oct 23, 2009
I had that problem last year. Found the remains of some insect inside, with goo over several connectors. I used some isopropyl alcohol and q-tips to clean most of it, then an eraser for the corrosion. It was on the front left hand side, at the connections between the green and brown (audio and video) boards. Just be careful of the connecting cables. The audio cable especially has to be disconnected to get the chassis out far enough to get to the front of the chassis out enough to see and clean the boards.
Posted on Feb 08, 2008
Trying to find the manusl for the Mitsu VS-50801
Posted on Jan 01, 2008
  • Max Rosenthal Jan 01, 2008
    I am trying to find a manual for the VS-50801 also. Where did you find it?
After 6-years, my Samsung HL-S5687W DLP TV picture & audio has begun to freeze, tile over, & blank out during the first 5 to 10 minutes after powering on. After it warms up, everything is fine. If I turn...
Yeah one of the circuit boards is getting bad, they do wear out overtime and this seems to be the number one breakdown on new TVs. It's a pretty simple repair to fix and to acquire the new boards but you might as well just buy a new TV at that point it's not worth it to fix a 6 year old TV and spend that much on it when you could have other issues with it at this point. I would put it on Craigslist for 25 bucks and just get a new TV I know it's sad to say but it's not like the old TVs were you could fix the parts that were bad and make it worth your time and effort but these new ones the parts that go bad are the expensive ones and you can buy a new one for so cheap you're just better off
Feb 09, 2018 | Televison & Video
On Pinnacle Studio 12 plus, during the 'Make Movie', some of my still photos go black for several seconds and then reappear in time for the transition or just before the transition. This is then burnt like...
Hi and Welcome,
Click on set up>video and audio preferences>unchecked background rendering>click on "used this codec for background rendering>click and choose MPEG2 for best output to disc. Now click on project preferences>click on delete button and then choose delete auxiliary files for all project and then click okay.
Setup again video and audio preferences enable full resolution preview and click okay.
Another is,
click on the completed project in the timeline, go up to "Edit," click on "select all" in the dropdown menu, then RIGHT click anywhere in the now-highlighted project and select "Copy."
Now go back up to "file" and click on "New Project." Your current timeline will close (don't worry. It's saved,) and a new blank timeline will open. Left click anywhere in the new timeline, then right click and select "paste."
After a terrifying period when you think nothing is happening, your entire project will suddenly appear in the new timeline.
Save it with a new name, then try rendering again.
Regards,
Oct 09, 2010 | Pinnacle Studio Ultimate 12 for PC
VS 50801 service mode access code (the correct one)!
Turn the tv off then enter menu 2359 power see if this works.
Oct 23, 2009 | Mitsubishi VS-50801 50 in. Rear Projection...
Tv screen goes black
VS 50801 and VS 60801 mitsubishi models (I have one each) have both had this problem develop after about 10 years of service. The picture simply started "Blinking" off after collapsing to a horizontal line - audio was still present. A simple fix to this problem is to space the yoke connector (7-pin white "Molex-type") away from the neck of the CRT (~1/8 ") . I used a plastic insulator. My 60" set had a problem with the center CRT (green) connector and thye 50" set had the same problem on the connector on the Left (red) yoke connector. The TV senses an open yoke circuit and shuts down all deflection drive. I only want a few more years of service from these sets, otherwise I would resolder the connector on the PCB for a correct and permanent solution.
Oct 23, 2009 | Televison & Video
Screen turns black suddenly
Hi guys!
I think your problem is one of the following:
1- AC Device or Batteries.
2- RAM.
3- Graphic Card.
So, plz check them by order.
I hope this problem is solved.
Nov 04, 2008 | HP Compaq Presario V2000 Notebook
MITSUBISHI VS-50801 50" TV
Bad convergence IC possible - It's cheap if you do it your self, expensive if you take it to a repair shop. My Toshiba finally came on and stayed on after the IC's burned completely up and smoke poured out the back. Then mine stayed on with a distorted image. A good place for parts -> http://www.electronix.com/catalog/default.php/cPath/6
Apr 29, 2008 | Mitsubishi VS-50805 50" Rear Projection...
UNIT TURNING ON BY ITSELF
check and see if the power button is not binding tightly on the body of the set.if everything is okay call a tech you are having a short in the power supply good luck.
Apr 11, 2007 | Onkyo TX-SV535 Receiver
Mitsubishi VS-50805 50" Rear Projection Television Logo
209 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
